Processor | faster at instructions than yours |
Motherboard | more nurturing than yours |
Cooling | frostier than yours |
Memory | superior scheduling & haphazardly entry than yours |
Video Card(s) | better rasterization than yours |
Storage | more ample than yours |
Display(s) | increased pixels than yours |
Case | fancier than yours |
Audio Device(s) | further audible than yours |
Power Supply | additional amps x volts than yours |
Mouse | without as much gnawing as yours |
Keyboard | less clicky than yours |
VR HMD | not as odd looking as yours |
Software | extra mushier than yours |
Benchmark Scores | up yours |
System Name | EVA-01 |
Processor | Intel i7 13700K |
Motherboard | Asus ROG Maximus Z690 HERO EVA Edition |
Cooling | ASUS ROG Ryujin III 360 with Noctua Industrial Fans |
Memory | PAtriot Viper Elite RGB 96GB @ 6000MHz. |
Video Card(s) | Asus ROG Strix GeForce RTX 3090 24GB OC EVA Edition |
Storage | Addlink S95 M.2 PCIe GEN 4x4 2TB |
Display(s) | Asus ROG SWIFT OLED PG42UQ |
Case | Thermaltake Core P3 TG |
Audio Device(s) | Realtek on board > Sony Receiver > Cerwin Vegas |
Power Supply | be quiet DARK POWER PRO 12 1500W |
Mouse | ROG STRIX Impact Electro Punk |
Keyboard | ROG STRIX Scope TKL Electro Punk |
Software | Windows 11 |
Unless they use a proprietary connector, as said, fan will run without RGB connected.besides not connecting the fans LED 5v cable to the mobo?
Many thanks. I thought those cables were just for controlling the colour - didn't realise they get power from them too.Unless they use a proprietary connector, as said, fan will run without RGB connected.
the fans have a 4 pin connector for power and the LED connector for controlling colorMany thanks. I thought those cables were just for controlling the colour - didn't realise they get power from them too.
4 pins for motor power right? But RGB power from the other cable?the fans have a 4 pin connector for power and the LED connector for controlling color
yes4 pins for motor power right? But RGB power from the other cable?
Well that's what I was afraid of - LED power coming over the classic fan connector and the RGB connector being used only for data / control (so disconnecting the RGB connector resulting in default lighting as opposed to no lighting due to power being cut).Hopefully this should explain "typical" fan motor wiring, but I do have several 3-pin fans which light up with blue LEDs all the time. The LEDs are not controllable and the only way to turn them off is to snip the wires leading to the LEDs, whilst keeping the wires to the fan motor intact. You won't have to do anything this drastic if the Lian Li fans have a separate control input for lighting.
https://computermesh.com/3-pin-vs-4-pin-fan-difference-between/
System Name | ASUS TUF F15 |
Processor | Intel Core i7-11800H |
Motherboard | ASUS FX506HC |
Cooling | Laptop built-in cooling lol |
Memory | 24 GB @ 3200 |
Video Card(s) | Intel UHD & Nvidia RTX 3050 Mobile |
Storage | Adata XPG SX8200 Pro 512 GB |
Display(s) | Laptop built-in 144 Hz FHD screen |
Audio Device(s) | LOGITECH 2.1-channel |
Power Supply | ASUS 180W PSU |
Mouse | Logitech G604 |
Keyboard | SteelSeries Apex 7 TKL |
Software | Windows 10 Enterprise 21H2 LTSC |
yeah, Corsair fans use one cable for RGB and fan motor, their proprietary connector, "usually", *many* fan manufacturers go "traditional" way of having RGB cable separately and normal 3 or 4-pin fan connector.4 pins for motor power right? But RGB power from the other cable?
