LIAN LI, a leading manufacturer of computer chassis and accessories, unveils the EDGE GOLD series power supply, the latest addition to its T-shaped PSU lineup. Tailored for dual-chamber and tower cases with its longer cables than the original EDGE PSU, the EDGE GOLD redefines connectivity and maintenance with innovative features such as the world's first removable USB/PWM expansion hub, and a removable magnetic dust filter. This fully modular PSU is equipped with industrial-grade EPCOS capacitors, ensuring stable and reliable power delivery, and is compliant with ATX 3.1 and PCIe 5.1 standards. The LIAN LI EDGE GOLD PSU, backed by a 10-year warranty, is available in black or white in 1200 W, 1000 W, and 850 W models, and in black only for the 750 W model.
Centralized Connectivity
The EDGE GOLD has a removable USB/PWM hub that can be attached directly to a power supply or placed inside the case using an 8-pin PCIe interface. It offers four USB 2.0 headers for up to eight downstream ports and has a total output of 2.5 A, along with six 4-pin PWM connectors supporting up to 2 A each for UNI FAN groups. Enhancing the LIAN LI Wireless ecosystem, the hub features strong magnets for easy mounting. It comes with the EDGE GOLD 1200 W and 1000 W models but is also available for separate purchase. Included are a fan PWM Sync cable, an internal USB to USB header cable, and a USB header to USB Type-A cable.
A Refined Form Factor
The EDGE GOLD retains the T-shape of the EDGE series, presenting an outward-facing modular strip for easy cable accessibility. The new removable magnetic dust filter replaces the previous intake grille, making cleaning a breeze. The filter detaches via the pull tab, and the embossed design of the mesh still fits mounted with the mesh side down, with a high 66.9% porosity for excellent airflow. The 120 mm fluid dynamic bearing PWM fan supports zero RPM mode for completely silent operation. EDGE GOLD models up to 1000 W have a max fan speed of 2000 RPM, with the 1200 W model reaching 2400 RPM, for maximum performance and quick heat dissipation.
Stable, Durable Performance
The EDGE GOLD employs industrial-quality EPCOS capacitors and Japanese capacitors. The small and robust EPCOS capacitors can better handle temperature spikes, broader temperature ranges, vibration, and harsh environments. With an 80 Plus Gold, Cybernetics, and PPLP Gold rating for great efficiency, the series includes OCP, OVP, OTP, OPP, SCP, and UVP protections. The EDGE GOLD is built to last, coming with a 10-year warranty for dependable performance.
Longer Premium Cables
The EDGE GOLD PSU features extended and braided textured cables compared to the first EDGE, and the added length ensures clean routing of cables for larger or complex PC builds. The motherboard 20+4 pin, CPU, PCIe 6+2 pin, and 12V-2x6 cables have a pre-installed cable comb, with additional ones provided to ensure a clean-looking setup. Two sets of custom SATA power cables are included, a Y-Type and Extender Type, to minimize cable clutter when connecting multiple devices.
Availability
The LIAN LI EDGE GOLD PSUs are available starting January 3rd, 2025.
Availability
