Lian-Li Lancool the 2nd
35 (0.01/day)
UK
System Name Phanteks NV7 White
Processor AMD Ryzen 5900X @ 4.7 GHz
Motherboard Gigabyte Aurus X570S Master
Cooling Full Custom Loop CPU and GPU
Memory Team Group 4000Mhz 32Gb x 4 DDR4 MEMORY
Video Card(s) MSI Gaming Trio 7900 XTX 24Gb
Storage WD SN850 4TB x 4TB NVMe PCIe Gen 4.0
Display(s) Asus VGG27W
Case Phanteks NV7
Audio Device(s) on-board
Power Supply EVGA GQ1000
Mouse Razor Balistik v2
Keyboard EVGA Z20
Software Windows 11 Pro 64bit Pro
Specs:
I used the Alphacool Eisbaer Aurora AIO 240 CPU Water cooling Kit - DIGITAL RGB, 240MM to water-cool it but Modded the cooler to change the unsightly rubber tube with 16/10 Hard tubing
Mods:
Cut out a slot in the front panel and cut a slit at bottom of the front panel so you can see the Logo at the bottom. Fitter Metal Black Handles to top of the case.
35 (0.01/day)
UK
Case Phanteks NV7
Keyboard EVGA Z20
So have you been to the Optician because there are a few Mods, the front panel has a mod and if you opened your eyes you would see more, Thanks the Neg feedback though, and Loving all the build you've got on here...oh wait you don't have any, I have been on here for many years and I NEVER slagg off other peoples work because that is not what it is about. PS all my builds are done for fun you should give it a try you might like it.
14,170 (3.81/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
You sound butt hurt.
I don't see where he slagged off your build, he gave it a fair score based on what he saw.
