Lian-Li Launches Red ARMORSUIT PC-P50R Mid Tower Chassis
malware
5,422 (0.74/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
Lian-Li Industrial has launched the ARMORSUIT SERIES PC-P50R Mid Tower chassis ideal for gaming systems. The hair-line brushed all aluminum chassis features advanced thermal dynamics, using one fan on the front (1x 120 mm@1200 RPM), plus dual vibration reduced top mounted fans (2x 140 mm@1000 RPM) and one rear 120 mm@1500 RPM extraction fan. The 8x PCI expansion slots enable CrossFireX and Tri-SLI graphic card setups. The chassis front face has 9x 5.25" ODD bays which have filters that are washable. The front panel clips off easily and conveniently. The entire chassis is designed for tool-less implementation, so installing your hardware and getting your system up and running is extremely quick and easy. The dimensions stand at 210x490x490 mm (W, H, D). The top and front panels are clipped via special plastic kits which reduce metal on metal contact wear as well as prevent vibration. The red parts are individually anodized before assembly to ensure a quality look and feel.
Complete Tool-Less Design
The first of its kind unique Power Supply Bracket allows the PSU to be secured using only the tool-less clasp which is ideal to hold the PSU securely without the need for securing screws. The ODD 5.25" bays have a patented mounting bar which secures your optical drives safely and securely. The PCI brackets made of solid aluminum have a special tool-less clip to secure your graphics and daughter cards with the utmost of ease. Similarly the HDD drives are secured in a tool-less bracket and mounted with rubber grommet struts to prevent movement and vibration from today's fast moving and highly specialized HDD components. The front panel and top panel are easily detachable for access to fans and air filters. The ARMORSUIT PC-P50R chassis is imbued with all the functional and user friendly design aspects users have come to expect in a Lian Li case.
Thermal features
Lian Li engineers have optimized the airflow to enter from the front mounted fans, directly cooling the HDD's and ODD's and thereafter refreshing the CPU region. The hot air generated by the CPU and GPU is directly extracted via the rear 120mm Fan and the dual top mounted fans. Both top mounted fans have special vibration free kits, which allow for silent operation as well as easy and safe removal of the fans should you wish to do so. The volume of airflow is more than sufficient to keep your gaming rig cool and conveniently silent.
General features
The chassis supports 9x 5.25" Optical drive bays and 3 additional internal 3.5" bays for HDD's in an anti-vibration movable cage. Each HDD has its own clip in bracket. The ARMORSUIT PC-P50R case is for Micro-ATX or ATX motherboards and has 8 PCI expansion slots, which are well ventilated with special vented brackets when not in use. The top panel is removable with the multimedia I/O ports on the top panel consisting of 2x USB2.0 as well as HD+AC97 Audio. The PSU has an advanced flame-retardant vent built into the bottom of the chassis. This uniquely designed vent prevents the possibility of heat and flames from exiting your case via the vent should something catastrophic like a short circuit occur to your PSU or other equipment inside.
Traditional Durability
The classical stylish functional design is the Lian Li goal. The essence of Lian Li products is the craftsmanship of the engineering. Intrinsic to the workmanship and quality is the customization which includes a whole host of optional extras that can be purchased to add more features to an already feature rich product.
For more details on features and extras available for the ARMORSUIT PC-P50R please go to the Lian Li website: http://www.lian-li.com.tw/v2/en/pro..._index=332&cl_index=1&sc_index=25&ss_index=62
BradleyKZN
1,146 (0.20/day)
South Africa
Processor AMD Athlon II X4 635
Motherboard Asus M4N78-SE
Cooling Stock
Memory 2x2GB G.Skill DDR2-800
Video Card(s) XFX 7900GS
Storage Samsung 5000GB 7200RPM 16MB cache
Display(s) Samsung 22'' T220
Case Coolermaster 590
Audio Device(s) Onboard Realtek audio
Power Supply OCZ fatal1ty 550w
That looks pretty sweet!
5,739 (0.96/day)
Wakefield, UK
I'd have that, maybe change the red... I'm guessing it costs alot though...
BradleyKZN
1,146 (0.20/day)
South Africa
Cooling Stock
Yeah its probably going to cost a fortune, and probably even more so in this country:-(
438 (0.07/day)
Oslo, Norway
System Name Water
Processor Q9550 Stock
Motherboard Asus P5Q Pro
Cooling Noctua big ass cooler
Memory Corsair Dominator PC8500 4 GB
Video Card(s) Sapphire HD7950
Storage Velociraptor 300 GB, Samsung 500 GB, MyBook 300 GB
Display(s) 1: Eizo 23" LCD Foris FS2331-BK 2: Samsung 226BW
Case Cooler Master ATCS 840
Audio Device(s) Asus STX
Power Supply Corsair HX520
This could be an interesting case for watercooling with minimal to no modding, provided that the dual fans on top have 15mm spacing.
Edit:
Oh yeah, seems like it :)
Parad0x
58 (0.01/day)
Bucharest ROMANIA
Any other brand that makes cases with more then 7 PCI expansion slots?:D
InnocentCriminal
Resident Grammar Amender
6,477 (0.89/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
Not keen on the window graphic, but otherwise that's a pretty smart case.
1Kurgan1
The Knife in your Back
10,421 (1.78/day)
Duluth, Minnesota
System Name My Comp | Fiancees Comp
Processor i7 5820k @ 4.6Ghz 1.285v| i5 2500k
Motherboard MSI x99 SLI Plus | AsRock Z77 Pro 3
Cooling Watercooled
Memory 16GB DDR4 2400 @ 2666 | 12GB DDR3 1600
Video Card(s) AMD R9 290x | MSI 5850 OC
Storage 128gb SSD + 2x 2TB | 2TB
Display(s) Asus 27" LCD | 25" Hanns G
Case CM Storm | CM Elite 430
Audio Device(s) Creative Recon 3D PCIe
Power Supply Enermax Galaxy 1250W | Rosewill 630w
Mouse Logitech G700s | Logitech G100s
Keyboard Logitech G901 | Logitech G105
Software Win 8.1 Ultimate x64 | Win 8.1 Ultimate x64
Benchmark Scores 3D Mark - Fire Strike Extreme - 4403
Windows is meh, but this is a far better looking case than most Lian Li's I like it.
FreedomEclipse
~Technological Technocrat~
24,165 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
this case is butt rapingly awesome!!! I want one!!!
h3llb3nd4
3,323 (0.57/day)
Durban, South Africa
System Name My mobo is Laughing at me
Processor E7400
Motherboard P5KPL-E Bios flashed to 0601 (Piece of poo!!)
Cooling Thermalright Ultra 120a
Memory GENERIC 2 GB DDR2 800
Video Card(s) NONE!! Beat that!!
Storage 500GB SAMSUNG SATAII, 250GB SAMSUNG SATAII and o'l crappy 4gb maxtor
Display(s) ACER X223W Q
Case AEROCOOL ZERODEGREE (planning to mod)
Audio Device(s) REALTEK ONBOARD
Power Supply GIGABYTE 460W
Software Win 7 x86 build 7022
Benchmark Scores Super Pi 1m 17.000 :(
LOts of areas to change and modify:)
Awesome! I want:D
HellasVagabond
3,376 (0.52/day)
Athens , GREECE
System Name SECONDARY RIG / PRIMARY RIG / THIRD RIG
Processor i920@3.6GHz / i920@4GHz / AMD Phenom II 955
Motherboard Gigabyte EX58-UD4P / Gigabyte EX58-UD7 / ASRock 890GX3
Cooling CoolIT Domino ALC / Thermalright Silver Arrow / Thermalright VenomousX
Memory 12GB DDR3 @ 1800MHZ / 6GB DDR3 @ 2250MHZ / 4GB DDR3 @ 1600MHZ
Video Card(s) XFX ATI RADEON 5970 / GAINWARD NVIDIA GTX 580 / 2xGEFORCE GTX295
Storage 1550GB / 6TB SAS - SSD / 160GB SSD
Display(s) NEC 26WUXi2 / NEC 3090WQXi / SONY 55A2000 (1080P 55inch)
Case COOLER MASTER HAF 932 / COOLER MASTER ATCS 840 / ANTEC DARKFLEET DF85
Audio Device(s) Soundblaster X-Fi Xtreme Music / SoundBlaster X-Fi Fatal1ty Pro / Realtek Onboard
Power Supply CWT 1200W / Enermax Revolution 85+ 1250W / Ikonik Vulcan 1200W
Software Windows 7 x64 / Windows 7 x64 / Windows 7 x64
Manchester and Olympiakos fans rejoice !!! :)
K
kyle2020
Excuse me whilst I return my jaw from the floor to my face :eek:
Ill be watching pricing of these over here in the UK. Gorgeous if you ask me.
WarEagleAU
Bird of Prey
10,812 (1.60/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
I love it. Id take that and use it over my HAF ::Cringe:: Did I just say that? This may be my next case for the Phenom 2 rig I build :)
h3llb3nd4
3,323 (0.57/day)
Processor E7400
I would take it home and spray it blue:D
So much features in this case!!
K
kyle2020
WarEagle, I was going to say it looks nicer than the HAF, but then I remembered I dont want to be murdered haha.
Honestly, next to the HAF 932 and 922 and the antec 1200 / 902, this is possibly one of THE nicest cases I have seen in a long time.
h3llb3nd4
3,323 (0.57/day)
Processor E7400
All these comments makes me want to rush back ASAP and get this case!:(
Deleted member 24505
The 490mm depth might be a tad short for them long graphics cards though,500+ would be better.
2,668 (0.43/day)
Earth
i have to say, i have been big on the haf, but this one makes me wonder.
love it
Braveheart
1,115 (0.18/day)
System Name mystie
Processor intel Q9450
Motherboard gigabyte EP45 UD3P
Cooling coolit domino ALC
Memory 4GB DDR3 1333
Video Card(s) sapphire 4870x2
Storage 250GB barracuda, 1.5TB barracuda
Display(s) 15" phillips, HannsG HD 28"
Case custom built plexiglass cube
Audio Device(s) Creative audigy SE
Power Supply Silverstone Strider 700W
Software Vista home premium 64/ Ubuntu 10.04 Beta 64
i almost bought one of the old black ones on craigslist...it was missing the side panel and all the screws but he was selling it for $40..man i wish i would have bought it :( i could have painted it and made it look just like these.
5,106 (0.80/day)
Kansas
Processor Core i5 3570K
Motherboard AsRock z77 Pro4
Cooling Zalman CNPS10X Extreme
Memory 2x4GB GSkill Sniper
Video Card(s) MSI GTX970 Gaming
Storage 240GB OCZ ARC 100, Samsung Spinpoint F3 1TB
Display(s) LG 23" 1920x1080
Case Antec P100
Power Supply Antec Edge 750W
Software Windows 8.1 Pro 64
This case is sexy. I'll never be able to afford one, though.:(
375 (0.06/day)
United Kingdom / Poland
System Name FlowTI
Motherboard MSI MAG B650 TOMAHAWK WIFI
Cooling Arctic Liquid Freezer II 240 RGB
Memory Corsair Vengeance DDR5 32GB 6000MHz/CL30 RGB
Video Card(s) Gainward GeForce RTX 4070 Ti
Storage Main: Crucial P5 Plus 1TB | Data: Crucial P3 Plus 4TB
Display(s) DELL S2721DGFA 165Hz
Case NZXT H5 Flow RGB
Audio Device(s) Audioquest Firefly Black DAC | Beyerdynamic DT 700 PRO X | Shure MV7 Microphone
Mouse Logitech Pro X Superlight
Keyboard Logitech MX Keys
Benchmark Scores Don't care
Simply the most beutiful case in teh world. :X
DeathTyrant
47 (0.01/day)
System Name Stratofortress
Processor i7 920 @ 3.8GHz
Motherboard Asus P6T6 WS Revolution
Cooling Noctua NH-U12P
Memory 6GB Geil Ultra Series DDR3
Video Card(s) 2x 2GB GTX 285 in SLI
Storage 2x 750GB
Display(s) 37" HDTV + 3x Eizo Flexscan S1931 with Matrox TH2GO Digital
Case HAF 932
Audio Device(s) Asus Xonar Essence STX
Power Supply Enermax Revolution 1250w
Software XP Pro x64
I want them to make a Revision 2 of the PC-80 Armorsuit with the new features that the PC-50 has (mobo cutout for one).
apheX?
121 (0.02/day)
England
System Name Evolution X
Processor Intel Core i7 920 2.66GHz
Motherboard Foxconn Blood Rage X58
Cooling Coolermaster V8 / TT TunderBlades
Memory Corsair Dominator 1600MHz DDR3 3x1GB
Video Card(s) XFX 8800GTS 512mb
Storage Western Digital Black 500GB 7200rpm 32mb
Display(s) Samsung T200 1680x1050
Case Thermaltake Armor+MX (Black Interior)
Audio Device(s) SONAR X-Fi Audio Card (Onboard)
Power Supply Corsair HX620w
Software Windows Vista 32bit
Benchmark Scores Coming Soon!
Loving that paintwork!!
If i had to criticize i would say they could of done a better job on the exterior looks.
HAF looks with this... maybe even a 230mm on the top and front? yummy!
How much is it?
