Liquid metal: only useful for direct die cooling?
1,755 (1.17/day)
I have some conductonaut, it worked really well on my 1080ti, but that was direct die. Is liquid metal really only suitable for direct die applications?
354 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
Is liquid metal really only suitable for direct die applications? = No.
I've had it on my i7 4790K, i7 - 7700K and my current i9 - 9900K all using the original heat spreader and they all had a temp drop of around 22 - 25 dec C from standard.
Mind you my system has customer water loop.
1,755 (1.17/day)
Wow that's excellent Fangio1951. Is your waterblock Ni plated Cu or just plain Cu?
354 (0.09/day)
Oztralia down under
System Name K9
hi 80251,
CPU = EKBW Supremacy EVO copper base with a aftermarket pure copper (After delid (recent purchase)) heat spreader.
Also water cooled VRM's =
