Liquid Ultra Thermal Paste
226 (0.07/day)
Norway
System Name none
Processor AMD R7 7800X3D
Motherboard ASUS TUF B650 GAMING PLUS Wifi
Cooling ARCTIC Liquid Freezer II 420
Memory 32GB Kingston 5600MT/s @6200MT/s CL32-36-36-28-68 tweaked sub-timings
Video Card(s) ASUS TUF RX 7900 XTX OC
Storage Samsung PM9A1
Display(s) Samsung U28E590
Case Corsair 7000D
Audio Device(s) none
Power Supply Corsair RM750x
Mouse Corsair
Keyboard Corsair K95 Platinum
Benchmark Scores Who cares!
Hello. Does anyone know the life span of Liquid Ultra once applied? I have used it on my delided 4790k @4.6 ghz 1.30 volts which was overheating, even with IC Diamond hitting 80 celsius under full load using WPrime. Now, temperatures stay under 60 celsius! (see screen capture)
9,781 (2.25/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Iirc it never needs reapplication., unless disturbed.
As a matter of fact, im confident of it.
Unless my brands are mixed, in my mind
226 (0.07/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
That goes along with my assumptions. Since it is made of purely metal, why would it need reapplication. But you never know. Its always best to ask :)
9,781 (2.25/day)
Massachusetts
Processor i7-11700K
From what ive pickded up, reapplication is only reqiired if temp dissepation begins to degrade, or what i posted above. But yes, your right, its always best to ask, and im certain its also best to let this thread marinade for a while, as members who are more knowledgable will likely chime in with advice/suggestions.
Welcome to TPU :toast:
226 (0.07/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
Thanks for your opinion. Always welcomed!
silentbogo
5,523 (1.40/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
Not sure about that. There were similar videos in english, just couldn't find those, but here's one of the long-term testing projects:
This guy used Collaboratory Liquid Pro, but similar results were seen on other brands, such as similar Russian ЖМ-6.
Collaboratory Liquid Ultra also "expires" in 18-24 month. My co-worker killed his Macbook Pro with this one (most likely microfractures on GPU die, because there was nothing wrong with it at first).
9,872 (1.87/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
the simple thing is when the temp is getting higher it means thats the time you need to replace them
peche
Thermaltake fanboy
6,709 (1.87/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
coollab does not degrades over the time, no need re-application unless you screw the first application, for example, take out CPU IHS and screw the bond of the previous application sir, also i have noticed that every time that you want to re-paste your delidded processor, due cooler swap or upgrades, general maintenance or sh*t you may re-apply it becase of broken bond on delidded cpu, if you could glue back cpu's IHS again, this will make you never re-paste the liquid metal again, im looking forward a thermal resistant adhesive for my CPU
226 (0.07/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
I watched the video you posted. It almost gave me a headache at how many mistakes were made. First of all, you are not supposed to use it on aluminum. He did not exactly apply Liquid Ultra to the aluminum part of his heatsink next to the copper pipes, but when he sits that cooler on the IHS it will spread a little into the cracks between the copper pipes and aluminum and thus cause damage to his cooler. Also, a common mistake many people make is to apply Liquid Ultra to the side of the IHS that comes in contact with the die. You only need one layer and that is on the core if the CPU is delided, or if applying to a GPU core. One thin layer and it will work great. At the cool laboratory site it mentioned that Liquid Ultra does not need to be reapplied again.
Your co-worker must have surely made a mistake applying this Gallium based product on to his GPU die, which might have shorted out the transistors around the core. Gallium is perfectly safe on most metals, except for aluminum, which it will breakdown like a cracker. I have posted above my temperature results after applying Liquid Ultra to my 4790k core. The stuff works and according to my research, it lasts the life of your cpu or gpu. For between the cooler and the IHS, I do not use Liquid Ultra, but instead either IC Diamond, or another good quality thermal paste. Cheers.
5 (0.00/day)
System Name 5820k
Processor 5820k@4.85GHz/1.33v
Motherboard Asrock X99 Extreme6/3.1
Cooling Swiftech H240x+3x140 rad
Memory GSkill Trident Z@3300/14-16-16-34/1.45v
Video Card(s) MSI GTX 780 Ti@1480/7950/1.118v
Storage Crucial MX100 250GB
Power Supply BE Quiet 750W
Keep it for over a year on my de-lidded 4790K as die/ihs interface without noticing any decrease in thermal perf.
silentbogo
5,523 (1.40/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Hear you on the headache: this guy's obsession with soviet cartoons and stupid audio tracks also hurt my brain, but apparently this is one of the very few long-term testing videos on the net.
In regards to MacBook, it was more like this, but more intense, completely dry and GPU-permanently damaged:
There also was a copper spacer between GPU/CPU die and heatsink and no spillage onto nearby components, so any type of foreign material was out of equation.
226 (0.07/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
Thanks for sharing. Yes, I have seen this video before. My thing I got from it was, bottom line, it does not destroy your CPU or GPU. I understand that once you apply Liquid Ultra, you are supposed to leave it alone unless you notice overheating due to most likely wrong application. I have seen a few people making these videos of them taking off the heatsink after applying Liquid Ultra, and the results are as expected. I just applied Liquid Ultra to my XFX R9 390 gpu yesterday because it was thermal throttling hitting 80c during game play. After applying this stuff, temps stay in the low 70's.
However, I do know that Gallium, which is the base for Liquid Ultra, destroys aluminum. If the original thermal paste is not removed completely, and it is aluminum based or has aluminum in it, it will react with Gallium and leave permanent markings on dies. Notice how Liquid Ultra comes with a scrub pad for removing the old residue from heat sinks? It is to avoid contamination and reaction with left over particles. I have seen other videos also where people take their equipment apart after a year or so of using Liquid Ultra, and there are no markings left on die, and barely some on the IHS. Here is a video addressing this issue:
719 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
Gallium doesn't mark aluminium. It destroys it.
Personally I feels the benefits don't outweigh the risks. Non conductive safe to aluminium thermal pastes like MX-4 will last several years if correctly applied the site says 8 years. And the difference in temps would only be a factor if you are overclocking to the limits of the chip and your heatsinks, And if you are at those limits the lifespan of the chip has already been compromised. For the sake of a very marginal temp difference I'd rather be safe, both to the electronics in terms of conductivity and to the common metals used in heatsinks.
Under review condition MX-4 shows only a 5 degreed celcius temp increase over liquid metal. If 5 celcius is the problem you need better cooling not better thermal paste.
226 (0.07/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
To each their own, I suppose. I would rather have those extra 5 degrees lower. Cheers!
Frick
Fishfaced Nincompoop
19,229 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
WTF HAS HE DONE TO HIS VOICE THIS IS WHY I HATE VIDEOS.
Also, alumnun. LOL
1,125 (0.37/day)
System Name Team Crimson
Processor AMD FX 8320
Motherboard Gigabyte GA-78LMT-USB3
Cooling Corsair H80i
Memory DDR3 16GB Crucial Ballistix Sport
Video Card(s) Sapphire Nitro+ RX 480 8GB RAM
Storage Samsung 850 EVO 250GB / Crucial MX300 275GB
Display(s) AOC 2752H 27" 1080p
Case NZXT Source 220 Windowed
Power Supply Antec Earthworks 650W
Mouse Logitech M510/ AGPTEK T-90 Zelotes
Keyboard Logitech K360/ iBUYPOWER TTC RED Switch Mechanical
Software Windows 8.1 64 Bit
Not having the necessity to reapply this liquid thermal paste will interfere with many users compulsion to do so, and thus ruin their enjoyment of this product.
5 (0.00/day)
System Name 5820k
^ you made my day! :laugh:
