Liquid Ultra
239 (0.08/day)
Norway
System Name none
Processor AMD R9 9950X
Motherboard GIGABYTE B650 AORUS MASTER
Cooling ARCTIC Liquid Freezer III 420
Memory 32GB G.SKILL @6400MT/s CL32-36-36-28-68 tweaked sub-timings
Video Card(s) ASUS TUF 4090
Storage Samsung PM9A1
Display(s) SAMSUNG 32" IDK WHAT
Case Corsair 7000D
Audio Device(s) none
Power Supply Corsair HX1500
Mouse Corsair
Keyboard Corsair K95 Platinum
Benchmark Scores Who cares!
Anyone else seeing these results?
4,666 (0.70/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
If I'm not mistaken, Liquid Ultra works well on bare die. You do have to make sure it's not going to touch aluminum though. With Skylake CPUs, people are delidding their processors with temperature drops in the 10-20c range when switching to Liquid Ultra. I think it's not nearly as good when it's on the outside of a heatshield though.
239 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
I have used it on my 4790k. It dropped my temps by 20 degrees. So yes, it works.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.98/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
239 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
Remarkable.......any evidence?
Before delid and replacement of old thermal paste, during this test my temps would reach high 80's. Now, with liquid ultra, this is what it looks like. 1024M test.
CAPSLOCKSTUCK
8,578 (1.98/day)
llaregguB...WALES
Mouse cheap
13,491 (2.00/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I hope everyone noticed at about 23:43 he says if applied correctly, "you never have to do it again!" This is so true for really every TIM which is contrary to what many believe who claim TIM needs to be replaced periodically. It doesn't, unless the bond is broken.
i didnt think those chips would get close to the high 80.s without throttling
Note those were GPU temps in the video, not CPU. GPUs do normally run hotter.
  • Like
Reactions: xvi
239 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
well well, you learn something new everyday, i didnt think those chips would get close to the high 80.s without throttling
check the t case figure from Intel
http://ark.intel.com/products/80807/Intel-Core-i7-4790K-Processor-8M-Cache-up-to-4_40-GHz
Yes, mine would throttle back to 4.0 when in the 80's. When AVX would kick in during prime95, temps would reach the 90's at which point I would stop the test. During WPrime, however, temps would get as high as 82-83.
CAPSLOCKSTUCK
8,578 (1.98/day)
llaregguB...WALES
Mouse cheap
13,491 (2.00/day)
Nebraska, USA
Mouse Logitech M190
i was referring to the HWMon snip
Ah! Thanks for clarifying. Yeah, his comment does say "high 80s" as you note so that is good if it stayed at full clock speeds.
That said, I sure wish the processor industry (Intel, AMD, NVIDIA, Motorola, Via and all the rest) would get together and come up with an industry standard on sensor placement and terminology. And then I wish all motherboard/chips makers and all the hardware monitor software programs would agree to follow those standards too.
I note the ARK says under Package Specifications for that CPU 74.04°C for Tcase but HWMon reports the "core" temps which often are higher than Tcase. But without a direct comparison/sensor reading, it is hard to really know how close those "high 80s" really are to the throttling thresholds.
Even among Intel processors, they are inconsistent. Note with the i7-3612QM, the ARK makes no mention of Tcase or Core temps under Package Specifications but instead, shows a smoking hot 105°C for the Tjunction temp - which is measured "at the processor die" somewhere.
At any rate, a 20°C drop is significant - assuming the previous application of TIM was still intact.
CAPSLOCKSTUCK
8,578 (1.98/day)
llaregguB...WALES
Mouse cheap
A "before and after" would be very useful.
I suspect the OP's AIO was fitted incorrectly to start with, though i may be wrong.
239 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
Yes, the old TIM was still intact during the tests. I bought this chip because I thought the "devils canyon" revision would have better thermal compound and thus better temps than the 4770k. But to my surprise, the temps were not so great after overclocking. And yes, 1.3 volts does not help. But that is what I had to go up to to get a stable 4.6 out of this thing. Using prime95 small ffts during avx the wattage usage would go up to 150 watts, and temps would reach the 90's, causing the cpu to throttle back down to 4.0. After delid and application of liquid ultra, my temps do not go pass 62-63. This stuff works for me atleast :)
239 (0.08/day)
Norway
System Name none
Case Corsair 7000D
Mouse Corsair
No, I installed and uninstalled my H110 GT several times thinking it was an issue with the back plate or how it was sitting on the IHS. But after noticing the thermal compound even spread between the IHS and pump, I was convinced mounting was not the problem. So I delided the cpu and added liquid ultra on die and IHS. Between IHS and pump I used IC diamond. Problem solved!
