Logitech G Pro wireless owners
utk4
4 (0.00/day)
Hey guys,
I've got a questions for the Logitech G Pro Wireless mouse owners. Couldn't find this anywhere.
If you remove the dongle (unifying adapter) from the PC and connect it via charging cable. Will it work as a wired mouse?
I would appreciate it if someone who has it could confirm it.
18,584 (2.67/day)
System Name AlderLake
2,207 (0.78/day)
You don't need to even remove the dongle, just plug the mouse into a spare USB port to charge. This can be on an external 5v supply, the mouse will still work.
& yes, I think it will work as a wired mouse, but I have never found that I have to remove the wireless dongle.
100% wireless user (all Logitech Devices).
utk4
4 (0.00/day)
& yes, I think it will use the USB to communicate, but I have never found that I have to remove the wireless dongle.
I know I don't need to remove it.
The reason I'm asking for owners is to get an exact answer. Does it work without a dongle?
I don't want to sound rude but speculation is no good here because if it doesn't work like that I can't return it to the store just because of that.
2,207 (0.78/day)
EDIT: Let me check. ..AFAIK it should work as a wired mouse or keyboard.
EDIT2: Confirmed both mouse & keyboard can be used as a wired product.
13,566 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Umm, did you RTFM? Perhaps on page 4 where is says,
Your mouse will operate in data‑over‑cable mode whenever it is plugged in directly to a PC
AsRock
TPU addict
19,150 (2.98/day)
UK\USA
You can do it with the G700s how you would not want to with that one as the cable is terribly bad for wired use.
EDIT:
And going by their site it's charging and data so yes it should work.
On a side note that looks like a real bad place for the battery to be in, what if it expands some ?.
3,441 (1.10/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Yes, can be used wired and wirelessly.
