- Aug 9, 2024
- 49 (0.43/day)
Processor | i5 13400F |
Motherboard | Asus Z790 Prime D4 |
Cooling | DeepCool 120MM |
Memory | 32GB Corsair 3200Mhz CL16 |
Video Card(s) | Gigabyte RTX 3070 |
Storage | Samsung 980 Pro |
Display(s) | LG UltraGear 24 165hz |
Case | DeepCool |
Power Supply | CoolerMaster 750W Gold |
Mouse | Logitech G305 |
I have a Logitech G305 mouse that I’ve been using for almost two years now. When I first got it, I used the battery it came with for the first few months. It worked flawlessly for about 4–5 months. After that, I switched to rechargeable 1.2V batteries.
About two months ago, I decided to switch to regular 1.5V batteries so I wouldn’t have to worry about charging anymore.
Now, the problem is that my mouse frequently turns off by itself, as if there’s no battery in it at all. Even in the GHUB software, it shows the mouse as inactive.
Interestingly, when I use my rechargeable batteries, the mouse works perfectly fine, but so far, I’ve tested around 5 regular batteries, and all of them have led to this issue.
Do you think this could be due to the difference between 1.2V and 1.5V batteries?
If so, could you recommend some good rechargeable batteries for me to try? Thanks
