Logitech z506 system behaving strangely
173 (0.06/day)
System Name Bonds silencer
Processor Core i7 5820k
Motherboard Asus sabertooth x99
Cooling Be quiet! Dark rock 3
Memory 4x4gb corsair vengeance(blue)
Video Card(s) Gigabyte Windforce GTX 980 ti
Storage Samsung evo 850 500gb ssd/western digital blue 1tb 7200rpm
Display(s) Asus rog swift pg278q
Case Be quiet! silent base 800 window edition
Audio Device(s) Sound blaster zxr
Power Supply Seasonic platinum 1000w 80+ platinum certified
Mouse Logitech proteus g502
Keyboard Corsair k70 2016 RGB
Hi.I got the following problem. Yesterday my z506 5.1channel system started to behave strangely. The rear right speaker died (lower volume than all the other speakers; it was already weak and it failed completely), but now the front right which is the master is having random lows in volume. When I press the power on/off button it get back to a normal output but it start making noise and then it just shut off. I dont know if my other speaker is affected by this? Will this speaker affect the others? What's happening exactly? If I need new speaker where to get the spare part for this set? What should I do in order to get it back to work properly? The other 3 speakers and the sub is working properly: I don't know for how long. Since the knob and the power button affect this issue I'm turning the set off until I get an answer to stop further damage. Thanks in advance
392 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
If you still got warranty RMA it to Logitech.
If you dont have Warranty anymore ...well its time to move on.
Most of the time when channels die on Audio devices its the caps inside failing due to age.
So what i presume is happening some of the Caps for the Channels you described are slowly falling beyond their rated capacity level and due to that you lose Signal Strength and the channel all together at given time.
But if you really want a precise answer you will have to find someone to Repair or send it to Logitech.
173 (0.06/day)
It's 1 year old only.I still got warranty I'll try to RMA it. Isn't it related to something in the master speaker itself as its linked via a sort of "vga" style cable with 9 pins if I'm not mistaken. I never set the volume higher than 50% on the speaker and 20% in windows.
1,288 (0.21/day)
System Name Firebird
Processor Intel i7 2600K @5.0'ish 24/7 stock core Voltage {5.2 w/102 bCLK}
Motherboard Intel Extreme DZ68BC SkullTrail Z68 Cougerpoint, Excellent MCH !
Cooling Scythe NINJA PLUS Rev.B[skt478] Modded to 1155 Scythe SH12 fan
Memory Samsung 32nm 16Gb 4x4 (@19xxmhz} low profile[ better than 2133 banwidth]
Video Card(s) Gigabyte Aurosus 1080Ti
Storage Intel 512 SSD,Samsung 9701Tb, Toshiba 3Tbx2,Hitachi 320,1TBx2,'Cuda 400 7200.10, WD1TBUSB,to SATA
Display(s) Acer K272HUL 1440 27" WQHD, Samsung 226W, Vizio M60C3 4K 60",Vizio XVT3D554SV
Case CoolerMaster HAF 932
Audio Device(s) Intel 10ch[9+1] HD Audio X540> Pioneer VSX39TX[copper chasis,Rosewood sides 5x6LCD remote
Power Supply Seasonic X750 @ 24/7
Mouse Logictech G300s
Keyboard Saitek Cyborg v7
Software Windows 7 ROG E3 X64 by Neuropass/tweakscene
Benchmark Scores 4642@665/1600 220/GAT F1 4544 220/667strap 2.5/3/2/6 Bliss 650/1500 6490 Q6700 Bliss 690/1500
Mine X540 has had a dirty volume knob for couple years now. Sometimes some will loose volume.
Have you tried swapping the cable from speaker ports to see if it's a speaker or not issue? [will follow if it is speaker]
Also try twisting the RCA jacks while your at it. Could be just dirty connection
9,781 (2.25/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i have the lesser version of that system, and it is kickass...i love it. as far as your issue, Logitech support has always been pretty good ime, you should be golden as long as there has been no tampering etc.
173 (0.06/day)
Tampering? You mean that there's no physical damage right? I'm not in the country I purshased the product from: because it was a gift. Though the guy told me he'll send me the reciept.
I tried the following: I plugged the front audio to my phone and I couldn't get anything out of my speakers. Tried twisting it a bit in the hole and it started giving some noose then bam some music. Through the sound is not crispy like it was.
I did the same with center sub and rear. Again after twisting a little I could get the rear right"death" speaker to get louder. After more fizzing with them I tried plugging in my sound card and could get away without twisting. Sound wasn't crisp through all the speakers gave sound except the sub who gave a quieter than average boom. I repplugged back in the motherboard and I got them all working but again it was noisy as hell.putting some pressure on the 3.5mm Jacks helped a bit but things wasn't crispy
sneekypeet
Retired Super Moderator
29,453 (4.38/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Simply put, if you are having issues, get the receipt and RMA it. The only other option is to try to tear it apart, voiding the warranty, and try to figure out the issue on your own. If it were me, Id be emailing the guy with the receipt and contacting Logitech for a replacement.
173 (0.06/day)
I did: they emailed me with a list of things to try ect. I told them that the problem persist. Let's wait. They aren't replying
842 (0.19/day)
Germany
System Name Perf/price king /w focus on low noise and TDP
Processor Intel Xeon E3-1230 v2
Motherboard Gigabyte GA-B75M-D3H
Cooling Thermalright HR-02 Macho Rev.A (BW)
Memory 16GB Corsair Vengeance LP Black
Video Card(s) Gigabyte GTX 670 OC
Storage 525GB Crucial MX300 & 256GB Samsung 830 Series
Display(s) Home: LG 29UB65-P & Work: LG 34UB88-B
Case Fractal Design Arc Mini
Audio Device(s) Asus Xonar Essence STX /w Sennheiser HD 598
Power Supply be quiet! Straight Power CM E9 80+ Gold 480W
Mouse Roccat Kone XTD optical
Keyboard SteelSeries Apex M500
Software Win10
I hope you'll get it sorted. But do yourself a favor and buy some quality bookshelf speakers instead. A good budget option would be Pioneer's SP-BS22-LR designed by Andrew Jones. Don't buy Logicrap.
peche
Thermaltake fanboy
6,709 (1.87/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
i have one Z506 for moar than 3 years or so, incredible durability, if yours is giving you hard time or malfunction ju might RMA as soon as possible...
Regards,
9,781 (2.25/day)
Massachusetts
Processor i7-11700K
yeah, anything that would cause logitech to not honor the warranty...ime their speakers, and other devices are real durable, so i figured id mention it ...
173 (0.06/day)
Actually there's 3 small scratches but on the metal casing of the subwoofer. Nothing is broken though. I told them that it worked when I applied pressure on/twisted the connection. They said that they think it's a hardware issue and they asked me for my PID (or reciept)my S/N and M/N. I don't know what those mean. PID is used to know the manufacturing date though I don't know how to decrypt it. I provided those to them. They asked for my adress and those stuff. They said they would ship during business days. Do they ship a prepaid box to send my item back? Or an actual new system? Any previous experience with their speaker RMA? I heard that sometime they let you keep the old mouse but never heard about the same being true for speakers
I liked those. Might get them when I get some cash flowing along with the pioneer sub
Now the speakers are working with random volume over each channel. I don't know if it's still viable for RMA. The rear right don't output any bass when tested compared to the others. They didn't get back to me so I guess it will go for monday
501 (0.16/day)
Skopje, Macedonia
System Name The Tesseract Cube
Processor AMD Ryzen 5 3600
Motherboard MSI X570A-PRO
Cooling DeepCool Maelstrom 240mm, 2 X DeepCool TF120S (radiator fans), 4 X DeepCool RF120 (case fans)
Memory 2 x 16gb Kingston HyperX 3200mhz
Video Card(s) Sapphire Radeon RX 6800 Nitro + 16GB
Storage Corsair MP400 G3 1TB, Western Digital Caviar Blue 1TB
Display(s) MSI MAG241C Full HD, 144hz FreeSync
Case DeepCool Matrexx 55
Audio Device(s) MB Integrated, Sound Blaster Play 3 (Headset)
Power Supply Corsair CX650M Modular 80+ Bronze
Mouse Corsair Dark Core Pro Wirless RGB
Keyboard MSI GK30 Mecha-Membrane
Benchmark Scores CPUZ: Single Thread - 510 Multi Thread - 4.050 Cinebench R20: CPU - 3 500 score
Sounds like bad regulation on treble, mid and bass from the amp.
Try this for a change:
Get a good working home amp and run the speakers on it and see if you get the sound you want.
That way you can eliminate the posibility of blown out speakers.
1,288 (0.21/day)
Sounds like there is still some corrosion keep twisting and plugging in and out to get the jacks to grip some fresh metal.
Also keep playing some sounds and turn the volume knob up and down fast, to see if it also had bad contact.
I've had this same issue with my X set over the years, it just dirty connections, but my volume knob needs cleaning inside desperately
173 (0.06/day)
It seems that they nonetheless want to send a replacement. Maybe replacement cables; maybe replacement of some" I don't know what". Or maybe a full set. Here what they sent me after 2 days:
"I understand that you would like assistance with your Surround Sound Speakers Z506. At this time there is no need for you to return your speakers. I will need your phone number and a valid shipping address to submit the RMA. Thank you!"
So I don't know what they will do. I already gave them the adress and phone number. I resent the adress and phone back.
I did what you asked for. Checked the Jacks but 1 year isn't enough to get such kind of wears. I tried the volume knob and I noticed that the volume didn't go up and down progressively. My knob isn't dirty though. I though that "miracle" happened and I got a better sound on them after this but seems like a bad connection.crossing my fingers. Hope they won't go into the "it's working you're not getting a replacement" sh*t. I'm noticing that some songs that used to have bass in them early in the first 10 secs or so don't get to be heard on the speakers.
edit: to see if the right rear speaker is faulty or not I swaped it with the rear left speaker and vise versa. I got the same unresponsiveness on the initial rear left and a crisp bass on the rear right speaker. So I guess it's the sub is the problem.
1,288 (0.21/day)
Well darn !
Even though you had it a short time, it may have been sitting a long time, like in a cargo container or such but it may have been around a environment like close to ocean that can accelerate the dirty connectors thus after twisting that you got better connection, but limited amount of time. You mentioned the small input connector also changed when you twisted it. maybe try that some more.
Also twist the bass adjust knob fast with medium loud sound. It still sounds like there is some issue of dirty connections involved.
This may have been first purchased from a B-grade/ Overstock seller because of that very issue, a Stock of them found/recovered from a shipping company ect.....it happens a lot that an entire shipping container is found in the back of a Port or where ever and usually the insurance company had already paid out, so the lot is auctioned off
We can keep hoping that your seller will send you the invoice and that Logitech will repair it or exchange it.
173 (0.06/day)
I hope so. I tried to do that with the bass knob. Ithe went from high bass to no bass without intermediary steps (by a chock) tried to do the same with the speakers connext or but it didn't change anything.i guess its from circuitry.
For future reference. Do you think that putting a dehumidifier(passive dehumidifying box) near the sub would give it a longer life if there's some humidity?
1,288 (0.21/day)
Are you playing music with the windows volume turned up ?
When you said before that turning the Logitech volume knob up and down real fast it actually played better. Same s twisting the speaker connections and even the 3.5 input jack all had some effect, so it just seems that as mine there is a dirty connection at least partly in play. Now this could also be an electrical issue in the unit also.
Be sure that the windows mixer volumes are turned play some music and keep twisting the Logi volume knob to see if it can scratch off the resistor pad to get a cleaner connection.
As far as the possible humidity issue, if it happened to be exposed to it, that damage was done long before you got it or even the previous owner. so the only thing that can really be tried now is to use something like scotch brite to clean all the RCA speaker jacks, and not too sure what to use to clean inside the small 3.5 jack holes.
This is just a 50/50 shot as from the way you have reported so it can still be an electrical issue in the amp also. As for cleaning the Logi volume knob, I have yet to do anything after 2+ years of it being scratchy. But it would need an electrical spray clean at the least to fix it. I sometimes turn it all the way up then use windows control at 50% and then use say YouTube volume control to adjust the volume watching a clip
173 (0.06/day)
They think I'm a spam because : you know my adress is not in the US. I will never get logitech speakers another time. They are not replying to my mail and they closed the case and told me that if I had issues to reopen it.
sneekypeet
29,453 (4.38/day)
System Name EVA-01
So reopen it! If they do not work as intended, are under warranty, and you have proof of purchase, keep on them until you are satisfied.
2,910 (0.51/day)
Riverside, California
Motherboard AsRock X670E Phantom Gaming Lightning
Cooling Be Quiet! Dark Rock 4
Memory G.SKILL Trident Z5 Neo DDR5-6000 32GB (2 x 16GB)
Video Card(s) Sapphire Radeon RX 7900 XTX
Storage Samsung 980 PRO Series 1TB, Samsung 980 PRO Series 1TB, Crucial P3 NVMe M.2 2TB
Display(s) LG OLED55G2PUA
Case Lian Li O11 Dynamic XL ROG Certified
Audio Device(s) Digital out to high end dac and amps.
Power Supply EVGA GQ 1000W
Mouse Logitech G600
Keyboard Logitech G413 Carbon
VR HMD Oculus Rift CV1, Oculus Rift S, Quest 2, Quest 3
Yeah re-open it. Logitech have always treated me right. I owned a 5.1 speaker system of theirs once before and it died within warranty. They send me a brand new 5.1 system at no charge to me and all I had to send back was the cut cables from my original 5.1 system. That saved me some coin in shipping for sure.
173 (0.06/day)
I tried reopening but they aren't replying anymore.probably the last set I get from them. They just send me some bot based answers.
2,910 (0.51/day)
Mouse Logitech G600
call them. That is what I did.
173 (0.06/day)
Can you furnish the number you called them at? Also do you remember how long the call was? I mean telecommunications is costy here. It might cost more than their price
2,910 (0.51/day)
Mouse Logitech G600
The last time I called them was back in 2007. I remember it being painless but not how long it took.
Support / Warranty Claims
+1 646-454-3200
