Hi everyone. I'm not familiar with technical CPU components; forgive me if something doesn't seem right here. I hope I've been specific enough but feel free to ask me for any clarifications.
I've purchased a refurbished HP xw4400 Workstation back in Feburary '15 and it has a very old card called the ATI FireGL v3350 that isn't compatible with most software anymore, even with the most recent drivers. Video streaming is also a headache as it freezes constantly. I am an animation student and I would like to replace it with a compatible entry-level 3D-rendering and animation specific GPU. My budget is about $250, and I'm purchasing online from Canada.
The workstation is running Windows 7 x64, has an Intel Core 2 6400 @ 2.13GHz processor, 1TB internal storage and 8GB of RAM.
The components in the CPU are standard. It has two Chassis cooling fans. The power supply assembly inputs 100-240VAC, outputs 460-watts and has a wide range, active power factor correction. I also have a 1920 x 1080 monitor.
The card has to be PCI-e x16.
I use a lot of graphic arts software (Clip Studio, Flash, Photoshop, Artrage, Zbrush, Maya etc.) and do a lot of internet browsing on chrome. I also take online instruction so streaming videos on my machine is very important. I don't play video games on my workstation.
Specs of my workstation: http://h50146.www5.hp.com/lib/doc/manual/workstation/xw4400/c00768537.pdf , http://partsurfer.hp.com/Search.aspx?SearchText=2UA7170479
Specs of my current card: http://www.techpowerup.com/gpudb/851/firegl-v3350.html
Thank you in advance for your help,
Nico
Nico
