Looking for specifics in a case....
74 (0.22/day)
I am looking for a case with very good general airflow for future builds, WITHOUT a million fans or giant loud fans, with mesh or mesh-like construction in a mid-tower size.
Something like an ASUS Prime AP201 or Silverstone Sugo-14 (M-ATX and ITX sizes), but in an ATX size case. Both of these are very well ventilated and run reasonable temps with air cooling and only a quiet exhaust fan behind the CPU. But when I look for an equivalent that will take a full size ATX board, everything I find is all fans and I can tell will be loud under any kind of load.
I'd use the ASUS case in every future non-SFF build if someone made a mid-end M-ATX board with PCIe 5 and good audio with rear panel jacks for 5.1, but there is no such beast (at least not in AM5) - this only comes in ATX (and ITX without the 5.1 rear jacks).
Anyway, I'm looking for suggestions. No "this has fans but they're really not that bad" suggestions, please. I already have a nice Lian Li 216 that is great, but still gets louder than I want.
2,251 (2.65/day)
Brazil
Processor AMD Ryzen 7 5700X3D
Case Lian Li Lancool 216
Mouse Razer Viper Ultimate
If you already have a 216, how would it be if you took its front fans off?
4,798 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
pick one
1) replace the fans with ones that have lower RPM
2) get a fan controller
3) lower RPM via BIOS)
freeagent
9,404 (4.05/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
You can’t get away from fan noise, or the sound of air moving.. in a high performance system.
There is always going to be some..
74 (0.22/day)
Yes you can. I have 2 of them sitting here that don't get very loud and perform very well at reasonable temps.
34 (0.01/day)
Norway
System Name ExcaliBuR
Processor Ryzen 7 7800X3D
Motherboard Asus ROG STRIX X670E-I Gaming
Cooling Lian Li GA II LCD 280MM
Memory G.Skill Trident Z5 Neo 32GB x 2 6000C30
Video Card(s) Sapphire Radeon 7900 XTX Pulse!
Storage 2x4TB Samsung 990 Pro
Display(s) Samsung G8 OLED 34"
Case Ssupd Meshliciuos
Audio Device(s) Edifier SPIRIT STAX S3
Power Supply Corsair SF750
Mouse SteelSeries Aerox 3 Wireless
Keyboard Steelseries Apex Pro TKL Wireless
VR HMD HP Reverb G2
Software W11
Check out Ssupd cases.
74 (0.22/day)
HELLO - I'm not looking for suggestions to talk me into a different direction - I'm looking for a case that's mesh without fans except for the exhaust fan behind the CPU. Kindly keep your contrary opinions to yourself, they're not helpful.
4,798 (0.96/day)
Antec had mostly mesh type case maybe ten years ago (if not more)
28,694 (6.80/day)
I'm a system builder too and @freeagent is correct. There is no avoiding at least some fan noise. Many can be very quiet but none are perfectly silent. So good enough is the best you can expect without very expensive passive cooling equipment.
That said, it would be wise and perhaps very productive to hear out input about what might be "good enough".
That's a tough one. There are a lot of good cases that can do this, but as far as fans, Noctua is the brand you want to look at, they are the most silent and push the most air while being very quiet.
2,251 (2.65/day)
Brazil
I'm not messing with my current PC - this is for future builds, either for myself or customers.
Ah, alright, this wasn't clear for me from your opening post.
I think that today it's a bit hard for any ATX mesh case not to come factory-loaded with fans. So I'm actually short of recommendations other than taking the front fans off any of the usual airflow/temp champs and seeing how they perform.
9 (0.04/day)
System Name Fuzzi0n
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 AORUS ELITE
Cooling Scythe FUMA 2
Memory TEAMGROUP Dark Pro 8PACK Edition 32 GB 3800 CL16
Video Card(s) MSI SUPRIM GeForce RTX 4070 Ti
Storage Samsung 970 Evo Plus 500 GB | Samsung 980 Pro 1 TB | Samsung 860 Evo 1 TB | Samsung 850 Evo 1 TB
Display(s) Dell AW2723DF 240Hz | ViewSonic XG2703-GS 165Hz
Case be quiet! Silent Base 802
Audio Device(s) Creative AE-5
Power Supply SeaSonic PRIME GX 650 W
Mouse Logitech G403
Keyboard Ducky Shine 2 | White Backlight | MX Blues
You could look at some of the darkFlash cases, the DLC29 is full mesh for example.
3,383 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
This one is on my wish list. Lian Li 011 Air? Comes with 3 fans but I guess you could get rid of two if you wanted.
74 (0.22/day)
I'm a system builder and @freeagent is correct. There is no avoiding at least some fan noise. Many can be very quiet but none are perfectly silent. So good enough is the best you can expect without very expensive passive cooling equipment.
If I hadn't built a zillion PCs myself and had no idea what was a reasonable / necessary level of noise is, I would perhaps be looking for advice on that. But I have, and I'm not.
Notice I did not say "silent", I said "quiet". This implies that I expect to be able to hear the thing in a dead silent room, however I also do not want it to sound like I have a jet in the room with me. My SFF PC is very quiet (not "silent"), even stuffed on a chair under a dining room table, and still runs perfectly acceptable temps while turning out very high FPS. I just want to be able to do this in a larger case, which shouldn't be that difficult.
I'm looking for a case that accepts ATX boards with high natural ventilation and no fans except the CPU exhaust. Think ASUS AP201 except in mid-tower.
I thought about that one when building my SFF PC - ended up going with the Silvertone Sugo 14.
But for this question I'm specifically looking for ATX size.
28,694 (6.80/day)
Fair enough.
Ok, I'm getting your vision. I have a case in mind, depending on where you live you'll have to figure out if you can get it. BRB.
EDIT:
Ok, remembered the reviews I've been reading and I think these might fit what you have in mind;
This one is my choice as it a very solid case, not too expensive, has fan exhaust behind the CPU, mesh front and top and will take upto an EATX board.
There's also these but they're a bit pricey.
3,383 (1.69/day)
Mouse Logitech M575
What do you mean by ATX size? It fits ATX. Another one that's ATX that's pretty small is Corsair 220T (I have one), it's light weight good construction but comes with 3 fans (removable of course) and mesh removable front filter.
freeagent
9,404 (4.05/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Maybe.. if all you do is play games. Not very difficult these days.
250 (0.18/day)
System Name Silicon Graphics O2
Processor R5000 / 180MHz
Cooling noisy fan
Memory 384 MB
Storage 4 GB
Case the one with the old logo and proud of it ;)
Software IRIX 6.5
You might want to take a look at the Jonsbo D41 Mesh. It's the ATX version of the Jonsbo D31, which is basically a knock-off version of the AP201.
However, you only get mesh in the front, bottom, back and on the top, not on the side panels, those are glass and solid. I got one in white with the optional front display and one in black with the full mesh front. Both systems have 360mm AIOs and use the chimney effect for cooling. The only air intake in my systems happens via the 850W PSUs in the front and what the three GPU fans of the 4070 Ti Supers suck in, while exhaust happens via the three AIO fans. You can also add up to three bottom fans or an optional exhaust fan on the back if you use an air cooler. Overall manufacturing quality is okay, but doesn't match the AP201.
74 (0.22/day)
It's the same running stress tests. It's a 7800x3d with a Thermalright Phantom Spirit SE cooler and one fan on the back in a Sugo 14 ITX case with 7900XT. I replaced the stock exhaust fan with a Thermalright PWM fan like the ones in the CPU cooler, and that's the only mod. It's audible - I never said "silent" - but it's way quieter than most comparable spec PCs, even in full size cases and the CPU never gets over 80C in stress tests due to the mesh-like areas of the case in all the right spots. The PC in the ASUS AP201, a high-airflow mesh case, is the same way, 5800x with a Scythe Fuma 3 and stock case exhaust fan - cool and quiet.
The AP201 is a marvel, isn't it? It's built like a tank, has the coolest high-quality no-tool removable panels, insane airflow, and costs $70. As you can tell, I am in love with that case!
The Jonsbo looks promising, can you get it with a mesh side cover as opposed to the glass? I think it would fit the bill with the screen and mesh top, sides and bottom (like the AP201)! I'm definitely going to look deeper at this one.
1,052 (0.67/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH Z333 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard Laptop built-in keyboard
Software Windows 10 Enterprise 20H2
Corsair 3000D is okay case, although a lil overpriced, doesn't included ssd cages.
I am fan of Deepcool Matrexx 55 Mesh. It has a "restyling" these days. It's great for it's reasonable price.
16 (0.15/day)
System Name My NV9 build
Processor 14900KS
Motherboard Z790 Aorus Master X
Cooling Full custom loop with 2 420MM EKWB RADS and a 360MM EKWB RAD.
Memory 32 gb's TeamGroup SK Hynix A-die running at cl 38 8000 mt.
Video Card(s) MSI Suprim X RTX 4090
Storage 10 TB's of a GEN 5 Aorus nvme and GEN 4 Hynix P41 and Samsung 980 Pro's.
Display(s) OLED
Case Phanteks NV9
Power Supply Super Flower Leadex VII XG 1300W
Mouse Wireless Logitech G502
Keyboard Roccat Vulcan Pro
VR HMD Headset is SteelSeries Arctis Nova Pro Wireless
Software Win 11 24H2
The Phanteks P600S case would fit your needs nicely. I quite enjoyed building in it and the air flow is pretty impressive for keeping those temps down.
