Loop flow back pressure won’t release
AJ847.63
10 (0.01/day)
Hi all,
just wanted to see if I can get some advise on a issue I’m having with a new loop I’ve put together. Issue is there seems to be extremely low flow to the point where I’m having trouble filling the whole loop up. When I turn the pump on you can see the levels try to move than slosh back in place so it seems like there’s a extreme amount of back pressure that the pump can’t overcome. The pump is definitely working as I can see it spinning and hear it vibrating as well.
Loop layout is: res to cpu, cpu to ek rad, ek rad to GPU, GPU to Corsair rad and Corsair rad back to ek res. According to the ek manual for both the res and cpu block are directional so I have hooked them up matching their manuals. The GPU block and both rads did not mention so I assumed it did not matter.
ive tried removing a hose and trying to fill the radiator directly but again there seems to be extreme back pressure so it just sprays back out. I’ve got one of the rad fittings open and the fill port in the res open to try give a path for the air to come out but the pressure just will not release. I’ve tried opening every fitting in the system but nothing will release the pressure.
im thinking I need to go buy a dedicated more powerful D5 pump but I don’t want to go buy something and it not solve the issue. Not to mention no one in Sydney stocks em and being Christmas shipping I’d be lucky to get it by New Years
components are: Corsair 420 rad, ek 360 rad, ek quantum kinetic 360 res and pump and I’m using soft tubing thank god. Wanted to use hard but talked myself out of it luckily otherwise this would of been even more of a nightmare!
thanks for your assistance.
824 (0.27/day)
Riverwood, Skyrim
System Name Storm Wrought | Blackwood (HTPC)
Processor AMD Ryzen 9 5900x @stock | i7 2600k
Motherboard Gigabyte X570 Aorus Pro WIFI m-ITX | Some POS gigabyte board
Cooling Deepcool AK620, BQ shadow wings 3 High Spd, stock 180mm |BQ Shadow rock LP + 4x120mm Noctua redux
Memory G.Skill Ripjaws V 2x32GB 4000MHz | 2x4GB 2000MHz @1866
Video Card(s) Powercolor RX 6800XT Red Dragon | PNY a2000 6GB
Storage SX8200 Pro 1TB, 1TB KC3000, 850EVO 500GB, 2+8TB Seagate, LG Blu-ray | 120GB Sandisk SSD, 4TB WD red
Display(s) Samsung UJ590UDE 32" UHD monitor | LG CS 55" OLED
Case Silverstone TJ08B-E | Custom built wooden case (Aus native timbers)
Audio Device(s) Onboard, Sennheiser HD 599 cans / Logitech z163's | Edifier S2000 MKIII via toslink
Power Supply Corsair HX 750 | Corsair SF 450
Mouse Microsoft Pro Intellimouse| Some logitech one
Keyboard GMMK w/ Zelio V2 62g (78g for spacebar) tactile switches & Glorious black keycaps| Some logitech one
VR HMD HTC Vive
Software Win 10 Edu | Ubuntu 22.04
Benchmark Scores Look in the various benchmark threads
I suggest trying to reverse the flow directions into the rads and GPU blocks and see if that solves the issue as that seems like the most likely issue that I can see for it not wanting to flow (do it one a time and see) as I can't see why you would have so much back pressure that you can't fill the system. The only other thing I can think of is that there's a blockage somewhere in the loop that's causing the issue.
58 (0.03/day)
System Name CS Prime
Processor i7-5775C @4ghz eDRAM @ 2ghz
Motherboard Z97 Sabertooth USB 3.1 Mk1
Cooling Corsair H90
Memory Kingston HyperX Fury 32GB DDR3L @ 2ghz x2
Video Card(s) Gigabyte Windforce GTX1080
Storage 512GB NVMe MyDigitalSSD BPXP, 4TB SATA WD Blue
Display(s) Q900RB
Audio Device(s) Denon AVR-X3700H
Power Supply Seasonic PRIME 650
Mouse MX Master
Keyboard MX Keys
Take the res/pump out and put it on top of the case until it's bled out. You need it at the highest point.
AJ847.63
10 (0.01/day)
Thanks for the advise. It’s not a blockage I’m able to blow through the loop myself to get a full rotation through the loop so it seems like a back pressure/weak pump issue. Dunno if the tubes will be long enough but I’ll try take the res out if I can and pop it on top of the case. I should of thought of that you should always have the pump at the top of the loop and in this case it’s closer to the bottom.
9,916 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
too crowded, why you not make it in line, from processor to gpu then to rad and res
and i agree you need to test to fill it up from the highest point or you need to place fill in port at highest point
OneMoar
There is Always Moar
8,802 (1.63/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
your rads are upside down
inlet\outlet on the bottom
you have created a airlock you need to flip the rads so the column of water works for you and not against you
with the inlet/outlet at the top you are constantly fighting gravity with it on the bottom the pressure will equalize and once bled the pump will only need to work half as hard
3,822 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Rad ports can be top or bottom, that orientation doesn't really matter. Gravity isn't a big concern as whatever goes up must come down, and in a loop it is equalized on the way down. Now just pushing it up will require one has enough pump and with that mess of routing... it looks like not enough pump. Fyi, I'm running the ports on my 480s on the top just like that and I don't have his issues.
And I would cut out all that extra tubing. Run the rads in series one after the other, ie. plumb them together so they form one unit. The way you have it setup creates a lot of extra complexity for negative gain.
3,547 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
does the pump power connector plugged into the motherboard or a modex to 4pin power ?
OneMoar
8,802 (1.63/day)
Rochester area
I am a fan of having as much of the Colum of water as you can get feeding the pump a
all things being equal if there is air in the system id rather it not be trapped in the bottom but at the top where it wont do as much harm
and yea his tubing is a cluster
9,916 (1.83/day)
Jakarta, Indonesia
Case Icute Super 18
oh one more, he needs to fill the highest point first
so if he wants to keep the setup he needs to fill the rad first
OneMoar
8,802 (1.63/day)
Rochester area
or just turn it the other way and then the only thing he needs to bleed is the res which is likely going to bleed easier
either way he needs to fix that plumbing
AJ847.63
10 (0.01/day)
thanks. I’ll try flip the rads since I think it is the pump struggling to fight the air lock so that might help give it some oomph. Otherwise I’ll go get a dedicated pump.
Moving the res on top of the case has not helped unfortunately. I’ll try flipping the rads and if that doesn’t fix it, which I doubt it will, I’ll go get another pump. Though I doubt that will help as well because I already did this with the bitspower zxy res/pump combo. I really need a dual seperate pump with high head pressure but as usual no one sells em here so I’d have to import them.
9,916 (1.83/day)
Jakarta, Indonesia
Case Icute Super 18
have you tried to test the pump, just make sure the pump is ok
what about try to fill it outside the case so you can move it to remove the air then plug it back to the case
AJ847.63
10 (0.01/day)
Yeah I have. Pumps ok as I can see it spinning. I’ve removed everything from the case so I can move things around and inverted both res as recommended but it’s still not flowing through much. Dunno if it’s moved much more or not. Both tubes coming out of the GPU and into the rads are filled on both ends but only a third of the way. The rest of those tubes are empty. The cpu block is also maybe 5% full but it’s tubes are full.
14,234 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Too much air in the system, try laying the case on it's side, just remember to close any fill ports.
8,226 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
with those long hoses, take the radiators out and lay them down flat until the system is bleed fully.
11,880 (2.18/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
As others have said there's too much pipe work, your defeating the head pressure of your pump.
Down size your pipe's so the runs are not extreme.
In the past when facing this issue I have at times removed half the loop leaving the second half, get it filled then add in the rest of the loop, this still isn't easy but once filled the pump might be fine pushing it around.
But to ultimately solve this I went dual inline pumps, they'll fill stuff easier.
AJ847.63
10 (0.01/day)
Still struggling to get the air lock out of the Corsair rad which is the one on the top in the new pic. Both have now been removed from the loop and all tubes removed from them only fittings connected. Ek filled easily but the Corsair one still has either a partial block, and it’s only partial as I can manually hack out a lung and blow past it, or a air lock still. It does not make sense though, removing the Corsair rad from the loop and disconnecting all the tubes so it’s just the rad by itself should of removed the air lock.
ive gotta get some more tubing so I can re run the loop, but there’s no point doing that and re connecting things till I break the air lock and finish filling the Corsair rad. If I can’t blow it through the pumps got no hope.
What’s funny though is I connected the ek rad to the Corsair rad connecting port 2 to port 3 just now. Blow into the left port so port 1 on the ek rad and coolant comes spraying out of the 4th port , so second port on the Corsair rad. But between the 2nd port and third port there is no coolant flow the tube is dry, so air is getting through but the air lock is stopping any coolant from flowing through the ek rad and into the Corsair rad it’s only letting air through.
58 (0.03/day)
Cooling Corsair H90
Display(s) Q900RB
Mouse MX Master
Keyboard MX Keys
You need the res on the top and you need to get the air moving out now that it is. The pump alone won't do it, too much air in the system. Because of how you have the loop configured, you're going to have a hard time bleeding it out.
I would remove the radiators and res, manually manipulate the whole thing to get it as bled out as possible, then reassemble.
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
If you have the d5 pump pwm wiring connected to the mother board or really anything disconnect it system via 24 pin cable is not connected to the board.
24 pin cable you're not using the jumper to fake the psu out to run the molex or sata power to the pump so how is the pump powered ?
How long the piping is does not matter it's just more fluid.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
That last point is not right, pipe length plus restrictions = head pressure (too little makes no flow).
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
Not in this case
Running to a different room maybe.
I've seen no issues at all I have two external mora 360mm rads too.
Dude just doesn't have his d5 powered correctly or has pwm wiring hooked to a dead board and it's not giving signal to run properly.
11,880 (2.18/day)
Manchester uk
VR HMD Oculus rift
Not in this case
Why are the physics different where he is?
He said the pumps running so I assumed it is.
Well I'll leave you to it , good luck op.
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
Wiring looks like a spaghetti factory and he's obviously powering or leak testing without the furnished ek psu plug on the 24 pin main connector which I also pointed out
I've already gone through pwm d5 and again if it's connected to a dead board it will not run very long if at all so the whole pump wiring deal is not known atm
If it's a vario 5 speed manual d5 it would be best set at it's highest setting for filling.
Hosing just looks like an octopus which I kind of like but I also use two d5 pumps and have lots more tubing
3,822 (0.74/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Dude, is that plumbers tape on the OP's picks??
