low flow
1,002 (0.21/day)
Memory 2x24gb Gskill 8800c38
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
I have replaced all the tube to black tube so they dont twist like before but the flow is still low. Its only 1.5 L/min. If I run the loop only on the Mora, the flow is 1.5 L/min to 6.5L/m. No idea why its not contant then I connect it to my pc and the flow stays 1.5 L/min . I tried to install 2 more d5 pumps but flow is still low.
Ruru
S.T.A.R.S.
12,744 (2.92/day)
Jyväskylä, Finland
System Name 4K-gaming / media-PC
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-A
Cooling Arctic Freezer 50 / Thermaltake Contac 21
Video Card(s) RTX 3080 10GB / RX 6700 XT
Storage 3.3TB of SSDs / several small SSDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
Maybe a stupid question, but have you cleaned your blocks that they're not full of gunk or other crap?
983 (0.69/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
That memory thing on one module looks very restrictive.
1,002 (0.21/day)
Case Dynamic XL
Mouse Model O-
cpu block is new, GPU block is 1 and a half year without cleaning.
1,864 (0.72/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
Whats ID of tubing?
pump rpm what it should be for what you set?
Ruru
S.T.A.R.S.
12,744 (2.92/day)
Jyväskylä, Finland
1½yrs without cleaning is pretty long time, there may be crap which is restricting the flow.
1,002 (0.21/day)
Case Dynamic XL
Mouse Model O-
2,208 (1.25/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
Are you having temp issues and that's the cause of your concern?
What does the entire loop consist of? Include block model#s, what your using to gather flow data etc... so we can figure out where your restrictive components are located in the loop and if you may be looking at a false positive.
When your coolant enters your reservoir does the flow look normal?
1,002 (0.21/day)
Case Dynamic XL
Mouse Model O-
temp is fine. just don't know why flow is so low compared to before. I used to have 240 L/h now its like 1.5 L/min. Different flow sensor.
2,208 (1.25/day)
Software Win11pro
42,160 (6.63/day)
