Hi all
I spent a lot to build my rig, and I am quite disappointed... it seems to be underperforming. I checked everything I could think of.. Please help, I will take any advice
In Fortnite:
I saw a lot of tests running easily at 250 fps in 1080p with max settings, here:
Drivers are up to date, install is fresh, I have done nothing else than installing drivers after the Windows 10 Pro 21H2 install
I haven't tried enabling DLSS, but even without, it seems pretty low to me...
For the H1 V1 prebuilt, the case included a 10700KF + GeForce RTX™ 3060 Ti and NZXT advertise some guaranteed FPS
for Fortnite:
They say they use the highest graphical presets available in game. No DLSS, no ray tracing
My goal is no to overclock everything to reach higher and expected value, I should reach them with stock settings, shouldn't I?
Plus I have run 3DMark, nothing wrong, excepts it also says I should reach 195+ fps on Fortnite
I also check GPU-Z, it says the gpu perfcapped with vRel and Util (log codes 4 and 16) and once with Pwr (log code 1), I don't know if that can help, I am sure sure to understand what they mean.
So whats wrong?
In Fortnite:
- 1080p epic settings : 150-170fps avg
- 1440p epic settings: 120 fps
- 4K epic settings: 60 fps
Fortnite Battle Royale avec RTX 3080 et Intel Core i7-11700K à Qualité ultra des repères de performance
Nous repères Fortnite Battle Royale avec Qualité ultra et Intel Core i7-11700K à des RTX 3080 paramètres
www.gpucheck.com
Core i7-11700K and GeForce RTX 3080 | Fortnite: Chapter 2 FPS Calculation | PC Builds
Frames per second (FPS) calculation for Intel Core i7-11700K and NVIDIA GeForce RTX 3080 in Fortnite: Chapter 2 video game.
pc-builds.com
- NZXT H1 V2 including 750W PSU and 140mm AIO
- Asus ROG STRIX Z590-I GAMING WIFIi7-11700K (Stock settings + Asus Multicore Enhancement MCE enabled in BIOS)
- Kingston 2x16GB DDR4 KF432C16BB1AK2/32 (Dual Channel and XMP I @ 3200MHz 16-18-18-36 1.35V enabled in BIOS)
- Gigabyte GeForce RTX 3080 GAMING OC 10G rev 2.0 LHR ("prefer maximum performance" is set in NVIDIA Control Center, Re-size BAR is enabled in BIOS and I verified in NVIDIA System Info)
- Freesync/Gsync is off
for Fortnite:
- 183fps@1080p
- 159fps@1440p
Checking FPS Guarantee
Firstly let us break down how our FPS Guarantee works. When we measure our FPS Guarantee, this is done in an hour-long session at the highest preset graphics setting within a game you selected for ...
support.nzxt.com
So whats wrong?
