Afonsosampaio
- Oct 19, 2022
- 1 (0.00/day)
My name is Afonso.
I need to connect a AM800480R3TMQWTA1H(7´´ display) to a PD10AI-N4200 motherboard.
So far, I haven't found any cables that match the two connectors:
- DF19-20S-1C on LCD side
- ACES88441-40 on motherboard side
I've ordered a custom-made cable with a pinout I designed but, unfortunately, the cable overheated as soon as I connected it. Probably some short-circuit caused by incorrect pinout.
The pins on the LCD side (DF19-20S-1C connector) are labeled as follows:
The pins on the motherboard side (ACES88441-40) are labeled as follows (taken from the manual):
Does anyone have an idea if these two are even compatible?
What pinout would you recommend for another custom cable?
Best regards,
Afonso
My name is Afonso.
Best regards,
Afonso
