M/B Crystal - full custom PC case build
cc customs
12 (0.00/day)
Hello :)
I decided to build my own custom case from scratch because the caces that were on the market did not meet my expectations of both appearance, compatibility, etc, and already somehow found it was awfully expensive. In this way, the idea was that I would create such a case myself;)
The design is mine, all the pieces are done alone and are still under construction.
The decision was that it would be a Miedium Tower. It will be made of PMMA material with the possibility of making changes at any time. It will be made of individual modules twisted together with the cube with threaded holes. If you need to change any item, I modify it or make a new one.
Little data.
dimensions:
Frame + covers 535x460x226 + glass 547x472x250
Fans:
Front x3 120
Top x3 140
Back x1 120
The frame will be made of black acrylic 3mm thick + on it will cover the mirror or black mat also 3mm thick. All this goes for "smoked glass" ie PMMA 5mm separated by sleeves and chamfered edges of 45 degrees and polished diamond cutter.
Below I upload some photos from the prototype of the rack.
Stage 2
All elements already cut from the target material (at all still protective film)
Left to make the nuts to screw "glass" and put the residue.
Next step, look for parts to fill the case inside. Only then will I take up the layout of the interior.
Stage 3
Some photos from sponsors :)
Plans have changed a bit and parts from be quitet! I will use for another project that is already in my head :)
This project will only include Straight Power 10 600W :)
First attempt of custom reservoir
I have also got a motherboard and a processor but I need to take pictures :)
Thanks to the mainboard I can continue to work so you can expect in the next time the progress of the work :)
To be continued...
PS
Sorry for my English
1,019 (0.21/day)
Porto
System Name No name / Purple Haze
Processor Phenom II 1100T @ 3.8Ghz / Pentium 4 3.4 EE Gallatin @ 3.825Ghz
Motherboard MSI 970 Gaming/ Abit IC7-MAX3
Cooling CM Hyper 212X / Scythe Andy Samurai Master (CPU) - Modded Ati Silencer 5 rev. 2 (GPU)
Memory 8GB GEIL GB38GB2133C10ADC + 8GB G.Skill F3-14900CL9-4GBXL / 2x1GB Crucial Ballistix Tracer PC4000
Video Card(s) Asus R9 Fury X Strix (4096 SP's/1050 Mhz)/ PowerColor X850XT PE @ (600/1230) AGP + (HD3850 AGP)
Storage Samsung 250 GB / WD Caviar 160GB
Display(s) Benq XL2411T
Audio Device(s) motherboard / Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Pro + Front panel
Power Supply Tagan BZ 900W / Corsair HX620w
Mouse Zowie AM
Keyboard Qpad MK-50
Software Windows 7 Pro 64Bit / Windows XP
Benchmark Scores 64CU Fury: http://www.3dmark.com/fs/11269229 / X850XT PE http://www.3dmark.com/3dm05/5532432
This is looking insanely good! That case, god damn, good job! Can't wait to see the final build! Keep us updated!
Durvelle27
6,798 (1.49/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700
Video Card(s) ASUS DirectCU II R9 290 4GB
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Sweet
HammerON
The Watchful Moderator
8,400 (1.45/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Sub'd for a nice looking build:toast:
1,778 (0.31/day)
Little Rock, AR
System Name Gamer
Processor AMD Ryzen 3700x
Motherboard AsRock B550 Phantom Gaming ITX/AX
Memory 32GB
Video Card(s) ASRock Radeon RX 6800 XT Phantom Gaming D
Case Phanteks Eclipse P200A D-RGB
Power Supply 800w CM
Mouse Corsair M65 Pro
10/10 would use front panel to grate cheese.
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
Thats one hell of a case. how much would you charge to make a replica of it?
aside from that, thanks for sharing this.
9,910 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
although i prefer steel, your case looks pretty good. looks popping
cc customs
12 (0.00/day)
I present another sponsor who has decided to support the project
And some photos, great motherboard Gigabyte AORUS GA-Z270X-Gaming 5 with i7 7700k
cc customs
12 (0.00/day)
It will not be a replica. This is a 1/1 project. Maybe someday it will be just for sale. At this moment there is still much to do and focus on this :)
1,778 (0.31/day)
Little Rock, AR
System Name Gamer
Memory 32GB
That has got to be the sickest cable routing solution I've ever seen.
1,019 (0.21/day)
Porto
Mouse Zowie AM
Keyboard Qpad MK-50
Totally agree, this build is turning up into something absolutely insane!
1,778 (0.31/day)
Little Rock, AR
System Name Gamer
Memory 32GB
I'm curious, the inlays where the cables go through.... Is that 3D printed? Laser cut? And the back piece too.
cc customs
12 (0.00/day)
CNC milling :) The rest of the cables will not be visible. The view is only to what is most needed :) On the power supply will be the cover :p
cc customs
12 (0.00/day)
First fitting of mobo and custom reservoir behind me. It looks promising :)
And some fun with cable sleeving
more soon...
42 (0.01/day)
Hamburg,Germany
System Name My PC
Processor Rysen 5 2600
Motherboard Gigabyte B450M DS3H
Cooling BeQuiet Dark Rock Advanced
Memory 2x8 G.Skill DDR4-2132
Video Card(s) Gigabyte 1080 turbo
Storage LiteOn 256GB SSD,Seagate 2TB+WD 4TB
Display(s) LG 29UC97C-B
Case Custom
Power Supply XFX Core 750W sleeved
Wow,it's like tech porn!!!The case is looking great.
9 (0.00/day)
System Name TheFlash
Processor Intel - Core i5-8600K 3.6GHz 6-Core Processor
Motherboard Gigabyte - Z370 AORUS Gaming 7 (rev. 1.0) ATX LGA1151 Motherboard
Cooling Enermax ETS-N31 (stand in for water cooling loop coming soon)
Memory G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-2400 Memory
Video Card(s) Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Xtreme Edition 11G Video Card
Storage Samsung - 960 EVO 250GB M.2-2280 Solid State Drive, Samsung - 850 EVO-Series 500GB 2.5" Solid State
Display(s) Asus - ROG Swift PG258Q 24.5" 1920x1080 240Hz Monitor
Case Fractal Design - Define S ATX Mid Tower Case
Power Supply EVGA - SuperNOVA G2 850W 80+ Gold Certified Fully-Modular ATX Power Supply
Mouse Razer - Mamba Tournament Edition
Keyboard Razer - Cynosa Chroma
Software Windows 10 Home
What an amazing build. Is there a particular method to your madness with regards to design process. Did you mock up in a particular program? This thing is just unbelievable!
cc customs
12 (0.00/day)
I create all ideas in my head. then I draw everything in the program and finally mill or cut on the laser :)
cc customs
12 (0.00/day)
some quick shots
completed in 95%. There are a few things left to do, but that's the details.
This is my first project, my first custom loop and my first custom case
Big thanks to
GIGABYTE
AORUS
Alphacool
Aquatuning
Phobya
Samsung
be quiet! PL
Liquid.cool
without you, the project would not look like it looks
Specification
CPU: i7 7700k
GPU: AORUS GTX 1080 Ti Xtreme Edition
MOBO: AORUS GA-Z270X-Gaming 5
RAM: G-Skill Trident Z 16Gb 3200Mhz
PSU: Be quiet! STRAIGHT POWER 10 600W CM
SSD: Samsung 960 Pro 1Tb
Loop: Alphacool
Case: Custom
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
LOVE this... looks like wires emerging from of hot lava:
lol
