M1 Impact
4,520 (0.71/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
Specs:
Intel Core i7 4770K, Liquid Pro TIM @ 4.4Ghz 1.2v
ASUS Maximus VI Impact
Corsair H60 + 1x Cooler Master Excalibur
Kingston HyperX Beast 2400mhz 16gb
EVGA GeForce GTX 780 TI SuperClocked w/EVGA ACX Cooler
2x Samsung 840 pro 256 SSD in RAID 0, Western Digital WD Black 1TB,
MyDigitalSSD 128GB M.2 NGFF
NCASE M1
Silverstone ST45SF-G 450W
This build took a long time to put together around 7 hours just to install every think, To save on space so i can get the most air flow though it as possible, Custom brackets where made up so RAID SSD could be mount to the front normally they wouldn't fit behind the front shield, I only used the molex power cable for all my drives and made custom molex to SATA cables to save on even more room, I think it turned out good but would love to have water on both CPU and GPU using a H220 just don't have the money and already have spent to much so this will have to do for now.
4,520 (0.71/day)
Perth AU
How do i edit this i want to add more photos?
9,907 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
pretty tight inside. and the tubing looks painful. im afraid for long term it would leak somewhere
6,765 (1.38/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
I really want that case for my impact. I have special secret plans I could use to add watercooling. I could not justify $200 for case though no matter how awesome it is. I love your build. 780ti on a 450w psu, must be cutting it close.
4,520 (0.71/day)
Perth AU
Yer i had that thought as well thats why ill be picking up a custom loop very soon.
Yer i thought the same till i started testing how much power my system really used on my UPS and also on a power monitor and its never went over 370w with my cpu overclocked @ 4.7Ghz.
