Arctic Freezer Ii 360mm constant speed or pwm
Mattcarbs95
10 (0.01/day)
Quick question as this cooler shares the fans and pump as one header to the CPU is it adviced when using it as PWM to run it at constant speed for example 60% as can’t imagine fluctuations in the speeds will be very good for the pump ?
FreedomEclipse
~Technological Technocrat~
24,020 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Hi.
If you can see here in this picture
You can see that there are two sets of cables. 1x3 wire and 1x4 wire. The 4 wire would be your fans for pwm. The 3 wire would be for the pump motor and 3wire/3pin cables do not support pwm, so when you plug it in. It will be running at its full speed regardless of fan settings in the bios.
The 4th wire is usually there to carry extra data to the pwm controller, but if there is only 3wires (3pins) it's not going to be able to be controlled unless you go out of your way to do it
