Grab HDD_MOUNT.dxf.zip attachment. Unpack, lasercut it in 1mm stainless steel. Powdercoat it.
Find 3 short motherboard standoffs. Screw them like this:
Screw drives to the lasercutted plate.
Mount the plate with fastscrews. BOOM! Now you can put up to 6 drives on the back.
Check the clearence.
Want to hide cables on the bottom and improve airflow at the same time?
Take SHROUD_EXPORT.blend.zip. Unpack, export to format of choice and 3D print it.
Remove drive cage and the front fan. Put the shroud in.
Screw it in.
BEHOLD
The back side fitting is the biggest issue that I've found.
120mm fan fits very tightly. And on the right there is a visible gap. This, and the bend on the back is already corrected in the blend file I've attached.
There's still a lot of room for cables and optional 2,5' drive. Didn't check with 3,5' though.
Disclaimer: Provided materials (models and drawings) come without warranty.
Screw it in.
BEHOLD
