Maximum cooling and GPU question
168 (0.11/day)
System Name MonsterBot
Processor AMD FX 6350
Motherboard ASUS 970 Pro Gaming/AURA
Cooling 280 mm EVGA AIO
Memory 2x8GB Ripjaw Savge X 2133
Video Card(s) MSI Radeon 29 270x OC
Storage 4 500 gb HDD
Display(s) 2, one big one little
Case nighthawk 117 with 5 140mm fans and a 120
Audio Device(s) crappy at best
Power Supply 1500 W Silverstone PSU
Mouse Razer NAGA 2014 left handed edition
Keyboard Redragon
Software Win 10
Benchmark Scores none
I wasn't sure if I should put this here or in case mods.
When it comes to cooling I win!
I fear I am blowing static into it tho.
GPU question. How do I take my GPU apart to regoop it? I have had it almost 7 years and never replaced the thermal compound. I can't brick it as I can't afford to replace it.
Currently I am playing ESO and have hit 100% usage. I can't get a stable over clock on it and my temps are in the low 60's so I am probably ok. Either way, I have regooped my CPU twice already. GPU is probably due.
9,781 (2.16/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
it is specific to the GPU. if you take the card out & post a pic of it, front & back, it shouldnt be hard to tell you how to take it apart.
a few things id suggest before doing it , would be .
do you have thermal paste on hand?
do you have .5mm , 1mm, 1.5mm & 2mm thermal pads on hand? (these are the sizes commonly used on video cards, you'll only NEED them if you damage the ones installed now)
are you reasonably good with taking things apart?
do you have rubbing alcohol?
most cards are pretty simple to take apart (nvidia reference Can be a PITA), its usually a handful of screws on the back of the PCB, maybe one or two on the i/o shield. then its a matter of twisting a little gently while you leverage the shroud away from the pcb gently.
9,340 (5.07/day)
Louisiana
Keyboard G710+x3
Yep ghetto mod section :)
I have one on two mora 360's seeing 9 or four fans costs a lot more than one box fan
168 (0.11/day)
Keyboard Redragon
Software Win 10
ok, you win. I like the shroud!
Looks like you have an octopus there.
9,340 (5.07/day)
Louisiana
Keyboard G710+x3
Yeah left some slack so I could drop one or "both if I remove all the 120mm fans" of the mora's into a dry ice or reg ice cooler :cool:
I painted one box fan black too
Toothless
Tech, Games, and TPU!
9,780 (2.44/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Two box fans (push/pull)
Car radiator
Water cooling
Hey look, a new project.
168 (0.11/day)
Keyboard Redragon
Software Win 10
Car radiator
Water cooling
theres a way to make a cooler with a room A.C. too. I read about it on another forum, Tom's maybe.
A non sealed unit would cause me to lose sleep.
I suppose I could attach a pulley to one of the fans and run a water pump. I think I have one off of an old 5.2L Jeep motor around here somewhere...hmmmm
Didn't paint mine, it came that way. What are you doing about noise control? I don't want to have to crank up the volume loud enough to drown it out. The background noise gives me one hell of a headache after about 90 minutes.
1,880 (0.74/day)
Arizona
System Name Space Heater MKIV
Processor AMD Ryzen 7 5800X
Case Phanteks Enthoo Pro M
Mouse Logitech MX Master 3
Keyboard Glorious GMMK 2 96%
LTT did something like this with great results.
Using an aquarium chiller.
Toothless
9,780 (2.44/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
That's just more power to keep a desktop running. There's a reason people don't run air conditioners on their computers
