Maximum upgrades for Dell Inspiron 530s (C2D)
329 (0.19/day)
System Name myPC
Processor i5-11600k @ stock
Motherboard Asus TUF Z590 Gaming Plus
Memory Corsair Vengeance LPX 2x8GB DDR4 3200
Video Card(s) Asus Dual RTX 3060 ti
Storage Boot: WD Black SN770 1TB - Game Storage: WD Black SN770 2TB - Other Storage: 4TB
Display(s) Samsung Odyssey G5 curved 27" 1440p 144hz
Case Thermaltake v100 perforated
Audio Device(s) Some headphones and some speakers
Power Supply Gigabyte UD750GM
Mouse Logitech G203
Keyboard Redragon K509
Software W11 Pro
After it came up in conversation about another system, I was reminded of this PC I'm looking to get maximum performance from. It still gets daily use for light gaming, YouTube, and general browsing. This is the specs:
Mine has a Core 2 Duo E6600, although the motherboard (Foxconn g33m03) officially supports up to a Q9650.
General W10 usage and web browsing is very slow. The games played on it run well enough, once they load. Roblox, Torchlight 2, and games with similar hardware requirements.
I know there are also some Xeon CPUs that can work in the system. What I'm looking to upgrade first is the boot disk, which is currently a very slow old HDD, to a 240gb sata ssd, and the CPU, which I think could benefit the general usage in W10. Memory is already maxed out at 4gb of 800mhz ddr2, and it has an R7 260X, which is good enough for the games it plays. I'm thinking a PSU upgrade might be needed too if I go to a quad core, with the default 250W it has already being less than the recommended for the GPU.
CPU Options:
Q6600 - cheapest and widely available quad core
Q9650 - best officially supported (non-extreme) CPU?
Xeon e5450 - Xeon I see used on my motherboard on userbenchmark
E8600 - fastest C2D (non Extreme)
I assume I would also need a better CPU cooler than the stock c2d Dell Intel one for a quad core.
@Retrorockit, this is the c2d system I was talking about.
1,533 (0.40/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
Yeah SSD first definitely, but not being able to go past 4GB of RAM is rough, especially when you can't run a nvme drive and are limited to SATA 3g... I don't expect you will get that much out of a quaddy for just browsing, though might help for e.g video playback, definitely for games.
Though if you are considering changing out the PSU, I honestly think you should just consider an entirely new mobo/CPU/RAM set to go with it... Dunno what you can fit in that case but you might just be able to find someone nearby trying to get rid of some old mATX or ATX tower...
5,240 (0.88/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
I would definitely look into if a BIOS update can let you bump you RAM amount up. An SSD isn't going to give you a ton of noticeable performance improvement, outside of boot times, if your system is hamstrung by running out of memory all the time.
https://www.userbenchmark.com/System/Foxconn-G33M03/125107 is showing a bunch of bench's with 8GB of RAM.
1,533 (0.40/day)
Grunn
Case FD Define 7
SSD makes a crazy difference for loading programs and stuff lol, yeah if you don't mind sitting for a minute while Firefox or Chrome loads up go for it, keep your spinning rust, but most of the responsiveness you get out of a system is by it doing something when you click on it.
Not to mention even on 8GB you'll almost certainly be running into the pagefile left right and centre...
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
If it was my primary PC I would definitely straight up replace it, but it's the hand me down PC my kids use, and when it's time to do that, I'll get the new parts and they'll get my old PC. I don't mind spending a little money on the SSD and PSU because I can reuse them down the road.
1,610 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
From what I can see, the Core 2 Duo was the fastest CPU available on the 530s series. Higher SKUs may not be supported by your vendor-specific BIOS. I'd start by updating it to the latest version. If you find a Core 2 Quad for peanuts, you may try your luck with it. I wouldn't go for the Xeon though, the board is very unlikely to support it.
4 GB RAM is tight today, but you can get by on it by running a single app at a time. In any case, definitely get a cheap SSD. I would also strongly recommend downgrading the system to Windows 7. It's lighter on the resources, runs much better on older hardware and can still be used in a family PC.
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
Core 2 Quads are officially supported up to Q9650. Multitasking isn't the worst, it can play Roblox and play 1080p YouTube in popup at the same time. The biggest noticable slowness is opening apps, and waiting for the web elements of apps to load. For example, Epic Games launcher takes forever (minutes it feels like) to fully load, and it can even take up to 10 seconds for the W10 notification panel to pop up after clicking on it when there are new notifications. As for Xeons, there are anecdotal reports of them working, and there are Xeons on that motherboard on userbenchmark. The BIOS I updated to the latest version when I thought about upgrading this to a C2Q a couple years ago (ended up buying a different PC.) I agree about W7, it may be worth going back to that. The main reason for installing 10 was I had an extra key and wanted to see how it ran. Not great, but also not my worst Windows 10 PC.
41,922 (6.61/day)
Go as high with it as a quad or scrap it
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
For about $30 CAD I could get a Xeon X5460 and LGA 771>775 adapter, which looks to be on par with the Q9650, if it works. Or for $70 I could get the Q9650, pretty much guaranteed to work. Or, for $100, a QX9650, which at 130W would almost certainly require a new PSU as well. The improvement in performance doesn't look like it's worth an extra $30 plus a new PSU. That leaves me with the X5460 or the Q9650. I guess the question is, am I feeling lucky?
1,085 (0.34/day)
South Florida
System Name BTXTREME
Processor QX6800 SLACP Core2 Extreme
Motherboard Dell 0WG864 LGA775 BTX
Cooling Dell T9303 heatpipe cooler, Delta GFB1212VHG 2 motor fan.
Memory 8GB Dell DDR2@800
Video Card(s) Sapphire Dual BIOS R9-285 ITX O/C 2GB DDR5
Storage Crucial M500 240GB SSD
Display(s) Dell 22" LCD
Case Dell Dimension E 520 MT
Audio Device(s) onboard sound with Logitech Z523 speakers
Power Supply EVGA B2 750W semi modular
Mouse Logitech wireless (two installed)
Keyboard Logitech wireless backlit
Software Win7-64, Throttlestop 6.00 overclock
Benchmark Scores 3DMark 11 P7644 (52% )In Win7 64, Firestrike 6892 ( 58% ) http://valid.x86.fr/l2j5p1
One mod you haven't mentioned is the old Q6600 tapemod (which is obsolete for C2Q) but works on the E7500 C2D for 3.67GHz 2 core performance. It bumps the FSB rom 266 to 333x11.
Sometimes the E7600 works ,usually it doesn't due to not enough Voltage. But that depends on the individual CPU. 333x11.5=3.83GHz then. Either one of these will spank a Q9650 in single thread apps. and games, and will be in the easily cooled 80-90W range. Intel actually sold some 80W, 3.5GHz 2 core Xeons, so it's not actually a huge stretch for that CPU.
Yes it's that simple, and yes it works. It looks like that computer has the usual Dell 90W CPU limit. I don't think the Xeon swap is worth the trouble unless you can get the 130W X5470, and even that comes up short against the E7500 mod in many situations.
You can see a few OC E7500 at Geekbench. About 20% faster than normal.
If I could find the Geeknemch 4 charts I could show one beating My X5470 swapped Optiplex 380 in single thread by about 10% They were the 2 fastest Opti 380s on the chart.
The mod would probably work on your E6600 also But might not equal a stock E7500. But the 45nm CPU runs cooler and has newer instruction sets.
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
That's a very specific thing I'd never heard of. Why is it obsolete on a q6600? E7500 is cheap enough I could do it just for the heck of it. Single thread performance was my thought when I suggested the E8600 (3.3ghz) as a possibility, but of course you'd know another way to OC a locked down old Dell. Thanks for the suggestion, I will definitely give that a try, first probably.
5,047 (3.80/day)
Colorado, U.S.A.
Software Windows 11 Home
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
I can't remember if I have 2 or 4 ram slots. I'll check after making breakfast, and grab another 4gb if I have the one with 4.
Well, good news and bad news. Bad news is my memory is terrible. Good news is this PC is running 4x1GB at 667, I thought it was 2x2GB at 800. I must have been thinking about my Pentium D PC (Dimension 5150), which I also upgraded the ram to 4gb on. So I will get 4x2GB DDR2 800. I already ordered the e7500. It is also running the latest bios, which I do remember updating to a couple years ago.
So, something like this should be a major improvement, in addition to the SSD and cpu:
I am confused by the specs I am seeing for the C2D e6600. Intel's website says 2.4Ghz with 4mb of L2 cache, my bios says it has 2mb of cache and is running at 3.06GHz. I think even though the sticker on the machine says C2D, this CPU is actually a Pentium e6600, not sure what difference that makes, if any.
1,533 (0.40/day)
Grunn
Case FD Define 7
C2D E6600 is Conroe, Pentium E6600 is wolfdale (same as C2D E7000/8000). Wolfdale is basically 45nm Conroe but with some minor config changes...
The memory looks expensive, I'd look around locally to find some..
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
I am looking locally too, found 4gb of crucial (2x2gb)for $15 so far. I'm ok spending a little more to get matched pairs. This is only $20cad for 4x2GB 800, but they're random sticks.
1,533 (0.40/day)
Grunn
Case FD Define 7
JEDEC DDR2 should be easier to run in non matched sticks than XMP stuff from late DDR3 and DDR4 era... Mainly just make sure it's the same timings.
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
I pulled the trigger on the local 2 2GB 800 matched pair for $15, so I just need to find another couple. I could run 6gb until then, and it will all just run at 667 right?
1,533 (0.40/day)
Grunn
Case FD Define 7
It should, don't know what bios options you have, worst case you'd need to manually set it.
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
Thanks for the input everyone. I'll update once I get the parts.
1,085 (0.34/day)
South Florida
The E6600 has the 266fsb, and 11.5 multiplier of the E7600, But they took out the SSE4 suppport. It supposedly has higher OC potential than the E7500. I would throw a piece of tape on it and see what happens. But yes they did recycle some CPU numbers.
If you has 2x4GB of Dell compatible DDR2 you would know it. They are very rare and very expensive. Vaya Memory had some DDR2 modules that were CL5 latency. You may have to call and ask. they're not listed on the site. In Intel only the X38 chipset supports them. Intel went with FBDIMMs for 4GB workstation modules, and the cheap AMD stuff won't work
2,844 (0.65/day)
System Name BoX-Server | 775PC
Processor I3 3.5GHZ (3150) | Modded Xeon E5450 (OC @3.60)
Motherboard ASRock B85M-ITX | ASUS P5Q-EM
Cooling OEZM HSK | 120MM Heatsink (2-FANs)
Memory 8GB DDR3 (2x4GB) | 8GB DDR2 (4x2GB)
Video Card(s) Onboard | NVIDIA Quadro K2200 4GB
Storage 120GB SSD 1TB WD | 120GB SSD 1TB Seagate 500GB HDD <<
Display(s) DELL 17" LCD 1280x1024 | ASUS 24" LCD IPS
Case CoolerMaster 110 | DIYPC N1e-SPORT
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Input-Director| RoseWill FUSION C40
Keyboard Input-Director | RoseWill FUSION
Software WiN1124H2/WiN11ET
I have the Xeon E5450 which is a Modded to work for 775 but for only certain chipsets. Please read after and see if your MB supports it LINK
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
I will try the tape trick on the e6600 when I have it out for the swap. I don't have 2x4gb ddr2, it's 4x1GB 667 ddr2. 2GB is still the maximum size module that will be recognized by the motherboard I am pretty sure.
I'm still curious about Xeons, I may go that route if I'm not happy with the e7500. I see that CPU on my mobo on userbenchmark, but the link you sent me says my chipset (g33) is unsupported. It also has two versions, SLBBM and SLANQ, and I'm not sure what the difference is and if that matters on compatibility with my board.
2,844 (0.65/day)
Google is your Friend LINK
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
That post was just my initial reaction to the information. I was indeed talking to my friend Bing after posting that. Thanks for the link too though.
1,085 (0.34/day)
South Florida
The only reason I did the Xeon swap in my Optiplex 380 was it somehow supported the 3.3GHz 120W CPU, and the 2x DDR3 slots could support 2x4GB RAM. The 380 was a bottom feeder when new and only sold with 2 cores, and 4GB RAM. But the modded BIOS was hard to come by without Dell's Digital Signing scheme, and the socket mod took down the MB when I installed a Pentium E6500K CPU the wrong way. If you do the Xeon mod, notch the CPU, don't mod the socket. At 90W CPU limit there is no performance advantage to the Xeon swap.
The SLBBM is a CO stepping, and the SLANQ is an EO. In an overclocking environment the EO is better. But at base speeds there is no advantage.
I paid $20 for the Opti 380 with a Win 7 license just to get the Xeon swap under my belt. With a Dell t3400 PSU it ran a GTX1060 3 Gb GPU
I stuck another MB in it and am running a 65W Q9505S quad core that with my BTX cooling mods barely breaks 50* when running Prime 95.
For Dell RAM you will need low density x64 RAM. AMD had an integrated memory controller that could handle x128 high density modules. So you may see AMD RAM, and PC RAM.
Crucial modules have that x64 in the part #.
