- Apr 1, 2008
- 4,680 (0.76/day)
- Portugal
System Name | HTC's System |
Processor | Ryzen 5 5800X3D |
Motherboard | Asrock Taichi X370 |
Cooling | NH-C14, with the AM4 mounting kit |
Memory | G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB |
Video Card(s) | Sapphire Pulse 6600 8 GB |
Storage | 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III |
Display(s) | LG 27UD58 |
Case | Fractal Design Define R6 USB-C |
Audio Device(s) | Onboard |
Power Supply | Corsair TX 850M 80+ Gold |
Mouse | Razer Deathadder Elite |
Software | Ubuntu 20.04.6 LTS |
As expected of a highend motherboard like this, ASUS has set the bar very high to create an even better board than the prior one. The board features a 16-phase power connection for the processor, three for the Northbridge, and two for the DDR2 memory. According to ASUS this ensures a very reliable solution that allows excellent performance under all circumstances.
We find another option at the two additional SATA-ports that are attached through a Silicon Image-controller. When you add two hard disks to these ports they are automatically configured in RAID 0 (striping), however this controller can easily be configured differently.
This motherboard comes with a Supreme FX soundcard featuring gilded connections. Surprisingly, (ASUS has it's own Xonar soundcards) this card is compatible with Creative's X-Fi. The card is based on an ADI HDA-chip and is connected through a special connector and can also be used as a PCI-Express x1 port. This soundcard is incompatible with other motherboards.
Other remarkable details are the red on/off switch (under the bottom PCI-slot) and the detailed heatpipe cooling. It is expected that ASUS' Maximus II Formula will hit shelves next month.
Source: HardwareInfo
