Mem timings after restart
1,977 (0.30/day)
Fremont, Ohio
System Name The Darkside
Processor Ryzen 5 3600
Motherboard ASRock B550 Extreme4
Cooling OEM
Memory 16gb G.Skill Fortis
Video Card(s) MSI Seahawk 1070
Storage 500gb Mushkin Pilot NVMe
Display(s) 55" Samsung 4k UHD
Case Corsair iCue 465X RGB
Audio Device(s) Onboard Reltek
Power Supply Corsair AX860i
my mem timings go to this after restart:
is this ok or should I clear CMOS again?
Tatty_Two
Gone Fishing
25,889 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
How come you are only running them at 116Mhz...surely thats not right, are they PC3200? You can try bringing all but the CAS latency down, thats good, try one at a time by one each and test stability for each one with either memtest of run the SiSoft Sandra Memory Benchmarking test after each drop to save time and then run Memtest afterwards.
If you can get down to 2-3-3-6 that would be good, they may go lower or not but you wont know until you have tried. There is also voltage to take into consideration, as you tighten timings some sticks require a little extra voltage, what is the stock BIOS voltage now?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
when I put them in, the timings were 2-2-2-5, then I did the timings at 2.5-3-3-6 and divider at 1:1 then rebooted and they went to 2-5-5-15 and a divider at 5:4. the bios has them at 2.7v, about 2.8v good? but I overclock my proc better at these timings but I lose mem performance right?
and yes PC3200
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
and Im O/C'ed at 4144Mhz at 144Mhz mem
1,042 (0.16/day)
CT, USA
Processor q6700 @ 3.2ghz
Motherboard Asus p5w DH Deluxe
Cooling Scythe Andy Samurai, 4x80mm silenx, 2x120mm silenx fans
Memory 2x2gb G.Skill 4-4-4-12
Video Card(s) xfx black edition 6870
Storage 250gb seagate sata, 2x250gb seagate perp (raid0)
Display(s) dell 24"
Case Coolermaster atc s4000 sx-1
Audio Device(s) Creative Audigy2 Platinum
Power Supply Antec True Power Trio 650w
Software winXP pro x64
hold up - is your memory @ 144mhz or 116.1mhz?
I'm confused. I know this is a 533fsb board, and ddr400...but I must be misunderstanding something?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
I know its very confusing
when I restart my computer at 140Mhz fsb set in the BIOS, CPU-Z says its at 116.1Mhz mem freq and timings of 2-5-5-15 and divider of 5:4 and when I O/C further with my utility here at 180 fsb it goes up to 144Mhz mem freq.
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
that makes sense: 140fsb = 116mhz memory @ 5/4 ratio
I know little about the 533 boards...what fsb does it use for stock speed anyway?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
but what about those timings? stock is 2-2-2-5.....
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
133 fsb
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
do your OCing in the bios, not windows.
set the mem timings to stock in the bios @ 140fsb, reboot.
tighten one setting down a notch, reboot.
tighten next setting down a notch, reboot.
etc. to find the best timings that are stable.
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
133? damn, what is the multi on that chip?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
ok will get back in a bit
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
well it seems that I cant change the timings from BIOS, cheap board lol
but all it says for Memory is the freq and it has a drop menu with 2.50, 3.00, 4.00
and the freq below it say 333, 400, 533
and when I set it to 4.00 and reboot it says: OC fail, please correct OC and reboot
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
weird. I don't know what those settings mean.
oh well.
So now you get to bench it at 4144ghz with the fsb/mem @ 5/4
then see what max stable OC you can get at 1:1 and bench that
and then see what is best for...whatever you need!
You might get better overall system performance with a lower fsb @ 1:1, but I really don't know for sure - so it's up to you to test it out!
:toast:
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
say - can you bump up the mem volts?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
though BIOS it says DIMM Voltage *drop menu* +.1,+.2,+.3,
+.4,+.5,+.6 and I think stock is 2.7v, should I leave it where it is?
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
Does anyone else have 2X512MB Kingston Hyper-X memory that can help me?
With my old Blitz one-sided Value RAM seemed to get better performance on the net and applications but not on benches or games. Im kinda disappointed with this performance:shadedshu
