Memory Errors G.Skill Trident Z RGB
409 (0.26/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
Haven't attempted any O/C. The first time I removed and reseated modules. Ran Windows Memory Tests. All OK. Then it happened again. So I removed 64 Mbs of the 128. ASUS TUF X570 Plus, AMI UEFI BIOS Ver. 2.20.1271, BIOS Ver. 2607 with a Ryzen 7 3800X. Running again and gaming. ??
4,628 (0.75/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
So what is your question?
409 (0.26/day)
Texass
Why the errors? It's a new build with Win 10 Home 64 bit. It was all good and normal. Then fail. Then fail again after another week or so of normal. Long beep. 3 short beeps.
The only software is MS Flight Sim 2020.
4,628 (0.75/day)
All parts were bought new? Test each stick individually, see if one is bad, if none of them are, either a MB issue or CPU issue. Does it only happen when using all 128GB, or when using 64GB too?
409 (0.26/day)
Texass
I haven't checked each module yet. All new components. It's only the second time it's happened. I just had that with my old computer with all new matching memory and 1 module failed. RMA. Git 'R Done.
4,628 (0.75/day)
My guess is either one or more of the ram sticks is bad, one or more of the ram slots is bad, or your CPU has a hard time, or simply cannot handle 128GB. If it becomes something CPU related, as the IMC is on the CPU, would need to play with volts. Can you link to the RAM you bought? Also, are using using XMP/DOCP?
409 (0.26/day)
Texass
Each module checked OK individually. All 4 modules reinstalled and running Windows Memory Diagnostics Tool 'Extended' tests.
All settings have been on AUTO. None were changed. Still in AUTO/DEFAULT mode.
4,628 (0.75/day)
Try out memtest86 or memtest86+ too, and try one stick in each slot, to test each slot individually.
205 (0.03/day)
System Name Bessy 6.0
Processor i7-7700K @ 4.8GHz
Motherboard MSI Z270 KRAIT Gaming
Cooling Swiftech H140-X + XSPC EX420 + Resevior
Memory G.Skill Ripjaws V 32GB DDR-3200 CL14 (B-die)
Video Card(s) MSI GTX 1080 Armor OC
Storage Samsung 960 EVO 250GB x2 RAID0, 940 EVO 500GB, 2x WD Black 8TB RAID1
Display(s) Samsung QN90a 50" (the IPS one)
Case Lian Li something or other
Power Supply XFX 750W Black Edition
Software Win10 Pro
4,628 (0.75/day)
This usually doesn't matter much, but since you're at the maximum rated amount of memory (128GB) I would check the qualified vendor memory list to make sure your memory is on there. If it's not, check the memory maker's list of qualified motherboards.
IIRC, all those lists are, are RAM that the MB manufacturer has tested, but does not mean that other kits will not work, so doesn't mean much.
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Prior to a retail release. That is correct.
AFAIK they are not updated after the fact.
409 (0.26/day)
Texass
True. It wasn't listed on the ASUS QVL but listed on G.Skill's QVL. Logic is new stuff coming out all the time. Many "kits" to be tested. Like trying an aftermarket HSF for modules as tall as G. Skill's with the heat spreaders. Got to watch for clearances I learned. Noctua NH-D15 for example might not fit. No definitive answer yet on that option.
Passmark Memtest86 V8.4 Pro is now running. Results pending. 0819 10/11/2020
4,628 (0.75/day)
When you are experiencing the crashes, what are you doing? I realized I never really saw that being listed, nor asked.
Edit: also can you update your system specs so we can see your current setup. Thanks!
409 (0.26/day)
Texass
Updated just now and BEEP codes at boot up. Memtest continues @0941.
409 (0.26/day)
Texass
Updated just now and BEEP codes at boot up. Memtest continues @0941.View attachment 171483
It took 26 hours to run and I got the results I was looking for.
ZERO ERRORS.
Checking each module in each DIMM slot and the second module in the seventh slot failed. Then they all failed in all slots. Motherboard. shhttt.
Video card. Remove. Reseat. Reboot. Okay.
ZERO ERRORS.
My bad. I had wrong information on the BEEP codes. 1 long 3 short is video NOT Memory on an ASUS TUF X570 Mobo. Don't you just love learning the hard way? I will now open a beer and try to forget about it for a while.
