Memory in Dual Channel??
1,526 (0.28/day)
System Name Custom Built
Processor AMD Ryzen 5 3600
Motherboard Asus PRIME A520M-A
Cooling Stock heatsink/fan
Memory 16GB 2x8GB Corsair Vengeance LPX 2400MHz
Video Card(s) MSI 1050Ti 4GB
Storage KINGSTON SNVS250G 256GB M.2 + 2 data disks
Display(s) Dell S2421NX
Case Aerocool CS103
Audio Device(s) Realtek
Power Supply Seasonic M12II-520 EVO
Mouse Logitech MX Master 2S
Keyboard Logitech
I upgraded to 6 GB by buying a 4 GB stick plus my existing 2GB one and noticed any program like Aida64 or CPUZ says dual channel mode? Is this a glitch or something? I understand Dual Channel requires two identical modules.
Also AIDA64 memory benchmarking is inconstistent sometimes is higher and sometimes is lower (maybe by speedsteep?).
Both modules are Kingston Value RAM
Thanks
3,427 (0.64/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
Both modules are Kingston Value RAMView attachment 54750
Thanks
It isn't a bug necessarily, some motherboard chipsets allow you to have a mismatch in capacity. Having identical brands and model isn't always a necessity either.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Thanks I always read that it requires exactly the same module brand, model and capacity for dual channel, is this something changed recently.
Also I've checked this old AIDA64 screenshot I posted long time ago and noticed the numbers increased a bit but I thought it was due to the bigger capacity or Windows 8 or something
9,914 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
i think its normal since your os using the rams too, if you do benchmark you should kill any background process that may affect it
just repeat several times and take the average score
3,427 (0.64/day)
System Name My baby
Ideally it should match to increase compatibility and increase likelihood of dual channel working, but it doesn't always have to be. For example some motherboard chipsets support FLEX mode or similar which allows a mismatch of capacities.
Dual-channel with three DIMMs
Dual-channel with four DIMMs
http://www.intel.com/support/motherboards/desktop/sb/cs-011965.htm
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Thanks I've done it several times with everything closed and idle and I get widly varying results, sometimes I get 8000 and sometimes 14000, Maybe has to do with this weirdo "dual channel" mode?
ahhh Understood, so in my case I get dual channel for first 2GB and the remaining 4GB is single channel, maybe this explains the AIDA64 Benchmark anomalies??
3,427 (0.64/day)
System Name My baby
Your abnormality isn't because of dual channel. Your results should be consistent all the time (within margin for error)
I think its a background process that is infrequently eating up CPU whilst you're running the benchmark.
Run MSonfig and un tick any start-up applications which are not essential, also run Administrative Tools and set not essential applications to manual or disable it.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
Thanks but I made sure nothing is running (killed every non essential app) and the computer is fully idle. Sometimes I get 8000 and sometimes 14000 with in-between numbers too!
3,427 (0.64/day)
System Name My baby
That isn't normal. if you're sure it isn't software then it must be hardware. You've just dropped in more sticks, maybe you need more voltage to sustain the RAM's performance.
1,526 (0.28/day)
Case Aerocool CS103
Keyboard Logitech
According to Hwinfo and AIDA64 the DIMM voltage is 1.524 should I increase it?
3,427 (0.64/day)
System Name My baby
Maybe, I don't know what the specification for your RAM requires. But I would increase it by small increments of 0.50v and benchmark at every change. I wouldn't take it past 1.7v.
