Memory problem with Asus P6x58d-e
69 (0.03/day)
System Name NOT Dell Precision T3500
Processor X5650
Motherboard Asus P6X58D-E
Cooling Cooler Master 212X
Memory 12GB DDR3
Video Card(s) MSI GTX660
Storage 320 GB and 2 TB
Case Golden Field G9
Power Supply Corsair CX 650 m
I have a Memory problem with Asus P6x58d-e . Six slots populated ( 12 gb ) , and they now read as 4gb . CPU-Z shows 12gb Dual channel . Speccy show 12gb dual . Task manager 4gb , Bios 4 gb , and Aida64 also shows 4gb . I have tried swapping the modules around but keeping the triple modules together . Any thoughts and help greatly appreciated . One thing also is that on restarting , the computer shuts down and restarts either once or twice before the post beep .
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Had the same issue in multiple boards (X58), its a memory failure
44,136 (6.81/day)
Check cpu socket
2,011 (0.62/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Decrease DRAM clocks to 800MHz, increase QPI/DRAM Voltage to 1,3V. When 12GB is visible try increasing Frequency step by step to 1066 first, then 1333 and lastly 1600.
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Check cpu socket
That looks like the problem , will try tomorrow , PSU shopping today .
Thanks , will give it a go
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Still have a memory issue , Apart from "get a new board" does anyone have any ideas ?
A single Dimm works - single channel .
2 Dimm works dual channel .
3 DImm works but only shows 4 gb and computer restarts twice before booting up .
Same with all 6 slots populated .
I have swapped out the modules and reseated the CPU and heat-sink ( new one ).
Are there any other memory configurations apart from the ones in the Asus manual ?
2,348 (0.43/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Regeneration
NGOHQ.COM
3,149 (0.44/day)
Intel introduced on-chip integrated memory controller (IMC) with Nehalem.
There are several rules when it comes to memory on X58:
1. All memory modules must be from the same vendor, brand and timings.
2. Uncore clock must be at least x2 of DDR frequency for Nehalem and x1.5 for Westmere.
3. Uncore shouldn't be higher than QPI data strap.
4. More DDR modules require more Uncore voltage (QPI/VTT).
5. DDR RTL values change slightly on reboot.
Missing RAM on X58 is usually because of the CPU not sitting well, bent CPU socket pins, insufficient DDR voltage, insufficient QPI/VTT voltage, wrong slot placement, damaged DDR circuit caused by over-tighten CPU cooler, and damaged IMC.
In AIDA64, you can see exactly which modules and slots are populated (Computer > DMI > Memory Modules).
Get contacts cleaning spray, alcohol, cotton swabs and clean everything, then install 3 modules, reset CMOS and configure the BIOS manually.
1,088 (0.34/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Cooling Noctua NH-D15S + Second Fan
Memory G.Skill 64GB @3200MHz XMP
Video Card(s) ASUS Strix RTX 3090 24GB
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a
Display(s) Dell U4320Q; LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Corsair K95 Platinum XT Brown Switches
Benchmark Scores Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855
Another thing is- you are running 64-bit OS, right? 32-bit Windows is limited to 4GB only.
phill
17,392 (3.45/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Have you checked each slot functions with a single stick of ram in and boots ok? I find this can tell you if there's a problem with the socket/ram/memory slots :)
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
That's some sort of initialization boot reset. I have the same board (that just apparently died).
I'd try three match pairs in the recommended configuration and see if you get 6GB to show up. X58 chipset is picky for ram slots, there are certain configurations where it won't even boot, I ran across that in my X58 EVGA board. The manual should tell you what those are.
That's a good point, falls under the category of "check the cables" first
Why it shows 12GB in CPUz and Speccy, I can't say. The fact that BIOS only shows 4GB may rule that out.
The other obvious thing to try is remove the CMOS battery, and use the reset button on the I/O header.
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
For your tri-channel ram setup try running ram at 1333Mhz and manually setting ram timings and voltage. Voltage may be low.
Is the memory a mixed set... not all same brand and speed? If so, use the slowest set as the baseline for all ram timing.
EDIT: have you the most recent BIOS with tweeks from here: https://www.techpowerup.com/forums/...tre-patched-bios-for-x58-motherboards.246101/
Memory is all Kingston ,one kit of 3 and 3 matched compatible modules from Kingston all 1333 Mhz .
Of course , board has 12GB - 6 x 2GB .
There are only certain memory configurations that can be used on these boards , cannot just use 1 stick in any slot , only Dimm A1 .
Aida seems to have the best info regarding memory , the other ones see more memory while Aida has the same info as the computer .
2,348 (0.43/day)
Keyboard Dell
@david carey : With all 6 slots populated you need to bump memory voltage.
Like Sasqui said above, get 3 sticks to boot first. I ran 6 x 2GB of Gskill 2000mhz ram and had to bump voltage. I later switched to 3 x 4GB of GSkill 2133mhz, no bump needed.
With a Xeon chip on the right board you should be able to run 8GB sticks. Do the Bios update.
Kingston is just plain hit or miss on X58. Would not be my first choice. If you have access to another brand try and see if it boots and shows in Bios.
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Did
2 modules shows 2040 MB
3 modules shows 4088 MB
6 modules has 2 restarts ( auto ) before booting up .
Settings in Bios are auto and stock . 8GB modules are expensive - $66 for a single 8GB budget Kingston module . If only I could run registered memory , I had 3 8GB modules offered to me for $44 ( for all 3 not one ! ) .
I don't think it is a Kingston memory issue , they were working fine on this board and my T3500 ( waiting for a new M/B ) .
Did this platform have memory issues like this one when it was new or are these issues age related ? What was going through the engineers minds when they imposed memory limitations such as limited slot configurations ?
I now have 8 GB of memory shown in Task manager / BIOS and Aida . Strangely Aida shows it as triple , while CPU-Z shows 12 GB triple and the same for Speccy . 8 GB is a lot better than the 2 GB I was using yesterday ( i was back and forth in task manager closing things ) . This after cleaning the contacts with an eraser
1,088 (0.34/day)
Processor i9-10940x
Case Corsair A540
Ah, you most likely have some contact issues with the ram slots (or with the memory. Perhaps corrosion or oxidization. Did you pull the board and look at the slots closely? Did you try to use compressed air and blow out any dust from the ram slots?
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
I don't have a can , almost certainly cannot get one locally - I just went on a 6 hr round trip to get some half decent thermal paste . Will try and get some later . Not sure I want to "pull the board" , it took an effort shoehorning it in - no spare clearance at all .
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Anyone have an additional information on this ( regarding the two auto restarts before booting) ?
Regeneration
NGOHQ.COM
3,149 (0.44/day)
The motherboard restarts during POST due to a memory initialization error.
You were given plenty of tips, but you don't seem to follow.
Clean the contacts with cotton swabs mixed with alcohol. You can get that stuff in almost every grocery store.
Then start with 3 memory modules.
Try to configure the DDR timings in the BIOS manually. Make sure to set command rate to 2T.
Increase QPI/VTT voltage to 1.25v and DDR voltage to 1.6v.
Try four DIMMs configuration, if the BIOS reports 6GB of RAM, it means the system fails to utilize the entire 3rd channel, possibly damaged motherboard.
The manual says you can use single DIMM but only on blue slots. If its correct, test all slots to ensure its not a physical damage.
If you want more tips, post photos and screenshots, maybe someone on the forums with a sharp eyesight could determine the source of the problem.
phill
17,392 (3.45/day)
Somerset, UK
Can you get away with two Dimms and try it that way? Or do you have any other ram you can try in the board? I've a Gigabyte X58A-OC, it will run ok with a single dimm.. Surprised yours has issues.. What CPU are you using in the board? :)
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Actually yes, two dimms in the right slots will run in dual channel. It's buried somewhere in the manual
phill
17,392 (3.45/day)
Somerset, UK
I remember testing my X58A-OC and it was working with single sticks (ebay purchase so wanted to check everything worked!!) so went with single slot to check it posted.. Worked fine with my Classified boards as well so I'm surprised it doesn't with your Asus board.. (now reading you have an Asus board might make a bit of a difference.... but I don't think it really should...) Any chance of a change of CPU or any other DDR3 memory at all? :)
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Sorry , bit late in replying , internet problem .
I have just spent an hour swapping memory sicks around , cannot say i feel any wiser though ( apart from feeling the M/B is damaged ) .
DIMM A1 single stick OK , B1 single stick OK , C1 single stick OK .
A1 , B1 + C1 shows 2040 MB .
A1 , B1 , C1 + A2 ( triple channel ) shows 4088 MB .
All 6 slots populated shows 8184 MB .
I have the X5650 installed , I could swap it for another X5650 or a W3565 . I only have the 6 sticks of memory . Will try to clean out the memory slots tomorrow .
phill
17,392 (3.45/day)
Somerset, UK
Sounds like it is I'm afraid to say..
But I would try the W3565 and see if the same error happens with that CPU as the X5650.. Also just check the underside of the CPUs to see if there's anything on the pads or in the socket. But be VERY careful if you try to remove anything from the socket, those pins are very sensitive..
It might be something to do with the socket or the CPU... If you're putting 3 sticks of 2Gb it should be showing 6Gb of ram as I'm sure you know... :)
Regeneration
NGOHQ.COM
3,149 (0.44/day)
Try another X5650 before replacing the M/B. Could be a damaged IMC.
69 (0.03/day)
Processor X5650
Memory 12GB DDR3
Thank you for all your assistance - And patience . I have now got all 12 MB showing , I cleaned out the Ram slots . I was expecting a motherboard failure or processor malfunction being a pessimistic individual .
