Memory upgrade for an eMachines T3256
Bekkler X
11 (0.00/day)
Chicago Suburbs
System Name rentbouncer
Processor Intel E8400 oc 3.6
Motherboard P5Q Pro
Cooling Cooler Master Hyper TX 2
Memory Corsair TWIN2X4096-6400C5DHX
Video Card(s) HIS Radeon HD 3850 oc 864/1080
Storage Western Digital WD Raptor 10k rpm sata
Display(s) Samsung SyncMaster 226BW 22" WS LCD
Case HAF 932
Audio Device(s) on-board audio
Power Supply MadDog 600w modular psu
Software Windows Vista Ultimate 64-bit
Benchmark Scores http://valid.x86-secret.com/show_oc.php?id=430143 http://www.techpowerup.com/gpuz/ubcru/
bought a set of Crucial Ballistix ram ddr 400 (BL6464Z402.16TGY).
Anyone know why this is showing up as pc2700@333?
Please Help
Thanks
Bekkler X
43,602 (6.53/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
What is your FSB and memory divider set at?
Bekkler X
11 (0.00/day)
Chicago Suburbs
Motherboard P5Q Pro
Case HAF 932
fsb set to 400 for processor, no memory adjustment available that I can find.
5,105 (0.75/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
If you have put them in with your older, PC2700 RAM they will downclock to the PC2700 speed.
43,602 (6.53/day)
Storage WD m.2
Keyboard Tester84
On your board it's listed as DRAM Clock (Mhz) The Cpu Host Clock Control is the "fsb"setting. You need to set the ram divider to DDR400
Or the post above me. ^^
5,105 (0.75/day)
Sydney, Australia
System Name UltraPC
Exactly.
Bekkler; Im not too sure on that board though. Generally speaking, if you havent changed it in the past it will be set to auto or something, and will automatically change with the new RAM (Again, not on all boards, and I am unsure of yours)
Of course, its always worth a try :D
JrRacinFan
Served 5k and counting ...
20,119 (3.12/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
Bekkler X
11 (0.00/day)
Chicago Suburbs
Motherboard P5Q Pro
Case HAF 932
allrighty, thank you for the posts, as it turns out the stock mobo only supports pc2700:mad:
what a dog lol
Bekkler X
