- Apr 26, 2022
- 4 (0.00/day)
Motherboard | Asus TUF Gaming B550M-E |
Memory | Corsair Vengeance LPX DDR4-RAM 3600 MHz 4x16GB |
Hi all,
my build is composed by 4 slots of Corsair Vengeance LPX DDR4-RAM 3600 MHz Kit 2x16GB (CMK32GX4M2D3600C18), 64GB of total available RAM.
The CPU is an AMD Ryzen 7 5700G mounted on an ASUS TUF Gaming B550M-E motherborad.
I'm experiencing some system crash with my Proxmox Virtual Environment so I run a MemTest to exclude memory errors and I got very strange results:
I've tested the 4 slots populated (I've just enabled the XMP profile in the UEFI that is 18-22-22-42 @ 3600Mhz) and I got 1 error.
I've repeated the test with 2 slots only with the same RAM settings and I've got any error (All 4 slots has been test at group of 2).
I read that some motherboard can't supply enough current in the 4 slots configurations so I tried to:
Do you have any suggestion to slove this issue? I spent a lot buying memories that could reach 3600Mhz and I don't want to decrease its speed too much but, at the same time, stability is the first characteristic that I would like to achive.
Many thanks for your help.
- Increase the RAM voltage from 1,350V to 1,360V
- Lower the speed from 3600Mhz to 3400Mhz
