Meshroom S V2
7,039 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Does anyone have this case? I am interested in building a workstation/office computer and I find this design appealing. I'd be running an ATX motherboard. Does it do okay with a small form factor air cooler?
135 (0.13/day)
This post on Reddit shows a Meshroom S V2 crammed to bursting point with cables and components.
Not much room for airflow with bigger components, e.g. large GPUs.
https://www.reddit.com/r/sffpc/comments/1ag9iuj Check components carefully before ordering. They might not all fit.
Unless you're determined to go SFF, consider a larger case.
41 (0.02/day)
Processor AMD Ryzen 7 5800X3D
Motherboard ASROCK B550 Phantom Gaming ITX
Cooling Corsair H115i Elite Capellix
Memory 32GB G.Skill Trident Z RGB 4000
Video Card(s) EVGA RTX 3080 FTW3 Ultra
Storage 1TB WD_Black SN850 + 2TB Samsung 860 Evo
Display(s) LG 32UP83A
Case SSUPD Meshroom S
Power Supply Seasonic Focus GX-1000
Mouse Logitech MX518 Legendary
Keyboard Corsair K70 RGB PRO Cherry MX Blue
I don't have the V2, but do have a Meshroom case. ATX board will be cramped. You will need to double check both PCI E riser length to make sure it will reach around the longer ATX board to your GPU, and make sure your power supply will fit. I don't think this fits both ATX PSU and ATX board, but you should double check the manuals on the website.
If you take your time this case can be built well. At first glance, cabling can look messy like the above picture, but with patience you can manage to create an air channel for GPU and CPU radiator to breathe fairly well.
