- Oct 9, 2007
- 46,896 (7.61/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Micron Technology, Inc., today announced it is now sampling its multiplexed rank dual inline memory module (MRDIMMs). The MRDIMMs will enable Micron customers to run increasingly demanding workloads and obtain maximum value out of their compute infrastructure. For applications requiring more than 128 GB of memory per DIMM slot, Micron MRDIMMs outperform current TSV RDIMMs by enabling the highest bandwidth, largest capacity with the lowest latency and improved performance per watt to accelerate memory-intensive virtualized multi-tenant, HPC and AI data center workloads.1 The new memory offering is the first generation in the Micron MRDIMM family and will be compatible with Intel Xeon 6 processors.
"Micron's latest innovative main memory solution, MRDIMM, delivers the much-needed bandwidth and capacity at lower latency to scale AI inference and HPC applications on next-generation server platforms," said Praveen Vaidyanathan, vice president and general manager of Micron's Compute Products Group. "MRDIMMs significantly lower the amount of energy used per task while offering the same reliability, availability and serviceability capabilities and interface as RDIMMs, thus providing customers a flexible solution that scales performance. Micron's close industry collaborations ensure seamless integration into existing server infrastructures and smooth transitions to future compute platforms."
By implementing DDR5 physical and electrical standards, MRDIMM technology delivers a memory advancement that allows scaling of both bandwidth and capacity per core to future-proof compute systems and meets the expanding demands of data center workloads. MRDIMMs provide the following advantages over RDIMMs:
"By leveraging DDR5 interfaces and technology, MRDIMMs provide seamless compatibility with existing Xeon 6 CPU platforms, giving customers flexibility and choice," said Matt Langman, vice president and general manager of Datacenter Product Management, Intel Xeon 6 at Intel. "MRDIMMs provide customers a full choice of higher bandwidth, lower latencies and capacity points for HPC, AI and a plethora of workloads, all on the same Xeon 6 CPU platforms that also support standard DIMMs. Our customers will benefit from Micron's broad portfolio of MRDIMMs ranging from 32 GB to 256 GB densities and in standard and tall form factors that will be validated with Intel Xeon 6 platforms."
"As processor and GPU vendors have given us exponentially more cores, the memory bandwidth required to deliver balanced system performance has lagged. Micron MRDIMMs will help close the bandwidth gap for memory-intensive workloads like AI inference, AI retraining and countless high-performance computing workloads," said Scott Tease, vice president and general manager of AI and High-Performance Computing at Lenovo. "Our collaboration with Micron is stronger than ever, and laser-focused on delivering balanced, high-performance, sustainable technology solutions to our mutual customers."
Micron MRDIMMs are available now and will be shipping in volume in the second half of calendar year 2024. Subsequent generations of MRDIMMs will continue to deliver up to 45% better memory bandwidth per channel over similar-generation RDIMMs.6 For more information on Micron MRDIMM innovations, visit: Micron MRDIMM memory.
- Up to 39% increase in effective memory bandwidth
- Greater than 15% better bus efficiency
- Up to 40% latency improvements compared to RDIMMs
