- Mar 18, 2024
- 4 (0.02/day)
- Colombia
Processor | Intel Core i7 11700K |
Motherboard | Aorus Master Z590 |
Cooling | DeepCool Castle 240EX A-RGB |
Memory | 32GB Aorus GP-ARS16G44 RGB DDR4 8GB (4 x 8GB) |
Video Card(s) | PowerColor Red Devil AMD Radeon RX 6700 XT |
Storage | Western Digital Black SN850X NVme 2 TB / Western Digital Black SN770 NVme 1 TB |
Display(s) | Samsung Odissey G3 LS24AG32X 165hz |
Case | Antec NX800 |
Power Supply | EVGA Supernova 220-G5-0750-x1 750 G5, 80 Plus GOLD |
Mouse | Razer Basilisk V3 |
Keyboard | Trust GXT 808 |
Software | Windows 11 Pro |
Benchmark Scores | https://www.userbenchmark.com/UserRun/66869448 https://www.userbenchmark.com/UserRun/64796320 |
Greetings, I have a concern, I currently have 4 RAM modules, which I have running at 3600 Mhz, GEAR 1, 16-20-20-40, CR1, with an Intel Core i7 11700K, my motherboard (Aorus Z590 Master) was automatically VCCSA at around 1,320v and when It needed more, I think it went up to 1,332v, but I noticed errors in games or applications in the event viewer, like "RADAR_PRE_LEAK_64" although the applications did not hang or gave errors, otherwise the PC works fine, So I think maybe the voltage is insufficient? I raised the VCCSA to 1.35v and the VCCIO2 to 1.4v (I understand that this is usually 50 mV lower, but in some videos I have seen it is 50 mV higher, I am not sure which is correct) in HwINFO, the VCCSA notifies me actually at 1.368v and goes up to 1.38v under load, I haven't been able to test yet if with this the errors and warnings disappear, but I want to know if it is a safe voltage and if I can really find a slightly lower voltage that is still stable, in forums I have seen people who handle more aggressive memory values with lower voltage, but I don't know if it is because I have 4 RAM modules and they only have 2?
In the memories I assigned 1.4v, I know that the Hynix-D or DJR memories can work up to 1.6v, in fact the XMP profile is 1.5v, but since there are 4 modules, I did not want to put more voltage in them, I have read that Higher temperature makes it unstable and since there are 4 modules it could heat up. Will those 1.4v be to blame for the errors and not so much the VCCSA and VCCIO2?. Because it seemed stable and I don't have blue screens or things like that.
My Modules
Sorry if you don't understand it very well, I don't speak English, thank you.
PD: I just checked and I'm still getting those messages. Maybe it's the command rate? I also found that when more modules are handled, a CR of 2 is more stable.
My Modules
