Minisforum Announces HX90G Mini-PC Featuring Ryzen 9 5900HX & Radeon RX 6650M
1,519 (0.84/day)
The new mini PC will be listed in the Minisforum's new product series - Neptune Series, which is for all their mini PCs with discrete graphics. Some of the upcoming products including AMD Ryzen 9 5900HX with AMD Radeon RX 6650M, AMD Ryzen 9 6900HX with AMD Radeon RX 6650M and Intel 12th gen Alder Lake with AMD discrete graphics. The first one will be HX90G, which is equipped with Ryzen 9 5900HX and Radeon RX6650M. It is also the world's first mini PC with AMD discrete graphics.
The HX90G will have the latest body design which is only 2.8L. It will have 7 heat pipes (3 for CPU and 4 for GPU) and dual smart fan inside, liquid metal for both CPU and GPU, The excellent heat dissipation design enables the HX90G to maintain relatively low noise even in full load. Besides CPU+GPU under 100% usage will consume 50 W and 100 W separately. It will use a 260 W power adapter. According to Minisforum, Radeon RX 6650M can run at 100% without performance loss.
Specifications
44,062 (6.81/day)
Strap a BDburner to it and it be a modern console lol.
They are mobility parts, perhaps a bigger heatsink fan would keep it cool with a chunkier case.
ppn
1,231 (0.35/day)
I believe a similar Ryzen 7 7700HX +RX 7700 XT can be built in the future.
853 (0.32/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
Good to see a real AMD system, not a another Nvidia system with AMD cpu.
1,846 (0.60/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
I want to see the mini PCs they'll build with Rembrandt desktop APUs and RDNA2 iGPU,, also can't wait until Zen4+RDNA3 APUs come out with v-cache. Hope they'll make low end dGPUs obsolete
599 (0.38/day)
Connecticut, USA
System Name "Terra Nova" // Inspiron 16 Plus 7630
Processor R7 9700X @ 110W| Mfg Wk24/2024 // i7-13620H @ 50-90W | Mfg Wk25/2024
Motherboard ASRock B650I Lightning Wifi // Dell 006JN2
Cooling Thermalright AXP90-X53 FULL, MX-6 // Stock (4x heatpipes & 2x Elepeak radial fans), MX-6 GPU & CPU
Memory 2x32GB Klevv CRAS V @ 6200C30-36-35-40-75-450-1T // 2x16GB Kingston Fury Impact H16A @ 4800C36
Video Card(s) Acer Predator Arc A770 @ 252W // RTX 4060 Mobile @ 70W
Storage WD SN850X 8TB (boot), SK Hynix BC901 1TB // Patriot VP4300 Lite 2TB (boot)
Display(s) Acer XV273K V3BMIIPRX, Gigabyte M27Q, Dell E152FPg // Dell AUO30A5
Case Fractal Terra (Jade) w/ 1x Arctic P12 PWM PST Slim // Dell Inspiron Plus 7630
Power Supply Corsair SF1000 (2024) // Lite-On 130W
Mouse Cherry MC 2.1
Keyboard Redragon Devaraias (brown switches)
Software W10 Pro // W11 Pro
458 (0.10/day)
Existence
System Name Workstation
Processor Ryzen 9 5950x
Motherboard Msi B550-A pro
Cooling D5 Pump + 250ml res + 2 x 360mm rad + Ek cpu bloc + 6 x 120mm Artic P fans
Memory 64 GB DDR4 3200Mhz
Video Card(s) Amd Radeon pro W7700
Storage WD SN 850X 2 TB m2 + Seagate Exos 4 tb + WD 2tb Gold
Display(s) LG UltraGear 32GP850-B
Case Lian Li 011 DX
Audio Device(s) Hifiman Arya + Fiio Q15
Power Supply Seasonic 1050W Snow Edition
Mouse Razer Basilisk V3 X Hyperspeed
Keyboard Gskill Ripjaws KM 780 MX
Software W 11 pro 64
Benchmark Scores It works.
Agreed, removing the keyboard, touchpad and screen you have a " laptop less" with a different geometry.
The idea is not bad at all, but if you don´t ad a desktop cpu or gpu, or even liquid cooling and some better ram, it becomes redundant from practical matters.
965 (0.45/day)
The New England region of the United States
System Name Gaming Rig
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Software Windows 11 Pro x64
Benchmark Scores Nope
It's a nice concept, but I'd like to see more USB ports on a desktop replacement. There is easily space for at least two more if not four more on the rear I/O.
44,062 (6.81/day)
There will always be Display adpaters what are you going to do if the igp craps out? Not everyone can afford to upgrade everything at once.
I built an AMD Ry7 5800 Rig, with a XFX R7 250X Ghost. Person doesn't game, but person just came from a P4.
Runs perfectly fine with the last released driver for 11...
6,500 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Overall, I like the design & aesthetics, however, I would also like to see a few moar USB ports, but once they build one with DDR5/pcie5 onboard, then I would probably jump on on one of them, and it even has 2.5G ethernet, so there's that too :D
phill
17,334 (3.45/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
I wanted to like these machines but sadly it seems I should not and just build something small.. Kinda takes the point out of wanting something small to carry about really...
