Hi all,
I have a Sapphire Radeon RX 570 Pulse 4 GB version and it is in a non-functional state.
Currently, it displays a distorted image only over HDMI on a 1920x1080 display and the computer can boot into Windows, but the screen is horizontally tearing/ghosting (not sure how best to describe it)
If I try to plug a monitor into the Displayport, it does not display any picture.
if I boot into Windows with this as a second card, GPU-Z says 0Mhz for the memory and the GPU core as well...
Do you know any sites where one can get schematics for this board?
Examining the board I noticed, that on the back side of the board (right on the opposite side of one of the RAM) modules a few capacitors and resistors are missing.
I am trying to find a schematic or someone who would know the values of the components
The list based on the silk layer codes are as follows:
C2541 (most likely this was not populated)
C2540
C2521
R2502
C2525
C2527
R2509
C2505
R2510
Thank you in advance
C2540
C2521
R2502
C2525
C2527
R2509
C2505
R2510
