Mitsumi FA404A 1.44 MB 3.5" Combo Drive 7 in 1 Card Reader, where do I stick it?
384 (0.05/day)
Just finished my first new build since Devils Canyon back in 2014! I jumped 4 generations to the Z390 and i7 8000 series. It appears that FDD's have gone the way of the Dodo bird. I have a Mitsumi FA404A in my Z97 retro system that works fine. My new Z390 system ought to have a place to connect the 4pin cable to the FDD drive, if only for Card reader functions. Here is the Mitsumi. I have two USB 2.0 Z390 motherboard connectors occupied at present. I may need an adapter for this FDD drive or may be able to plug in the 4pin FDD cable to another set of pins on my motherboard. I'm NOT going to " stick it There" but any legit suggestions are welcomed and appreciated.:confused:
  • Mitsumi-FA404A-144-MB-35-Combo-Drive-7-in-1-Card-Reader-D63119_149116__35797.jpg
  • Mitsumi-FA404A-144-MB-35-Combo-Drive-7-in-1-Card-Reader-D63119_149117__53110.jpg
  • Mitsumi-FA404A-144-MB-35-Combo-Drive-7-in-1-Card-Reader-D63119_149118__22324.jpg
  • Mitsumi-FA404A-144-MB-35-Combo-Drive-7-in-1-Card-Reader-D63119_149119__42271.jpg
98 (0.03/day)
So the problem is not enough USB2 headers?
Haven't tried any of the following, but I guess they might do:
Either a USB3-to-USB2 adapter:
Or a USB2 "internal" hub:
Or a USB3 card reader, or a PCIe USB2 card (but maybe USB2 would be more likely to be PCI rather than PCIe).
384 (0.05/day)
OK, thanks for the possible options. My Z97 FDD connection is not available for examination at present. This looks promising for a solution with the Z390 in the near future. Thanks for your input.
