Daisy chaining mixed 4-pin fans
5,303 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
When one daisy chains 4-pin fans, only one has the tachometer pin active (to avoid mixed signals), but what if one was to daisy chain mixed fans, say 120mm and 140mm, should one take the tachometer signal from the smaller or larger fan?
I have a case that takes a 120mm exhaust fan and on top can carry two 140mm fans, all to be controlled by a single 4 pin connector on the motherboard.
43,537 (6.77/day)
Whats the max rpms for the 120 and the 140 mm?
5,303 (3.73/day)
Colorado, U.S.A.
2200 RPM for the 120 mm
1500 RPM for the 140 mm
2,122 (0.65/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
He suggests a set of these were recently purchased. Yet to further an explanation of how "daisy-chaining" will be handled.
Short of it this doesn't work well if at all on a lower end board. BIOS will express it's disregards in one of a few highly suggestive manners.
5,303 (3.73/day)
Colorado, U.S.A.
Will the BIOS even know? it is getting a speed reading from one fan alone.
7,512 (4.98/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
No, and yes, it is. The problem with fans that while the voltage supply from the motherboard is the same, the speed that each motor will run at different speed.
Assuming a linear response to voltage supply, similar blade design and air throughput with a 12 volt input, a theoretical fan A runs at 2000 RPM and fan B at 2200 RPM, at 8 volts fan A will run at 1320 and fan B at 1450, this will obviously result in mismatched noise levels and possibly, a pressure imbalance. It's best to get similar fans that work as a set if it can be helped, or use a fan controller that allows for individual setting for each port.
2,122 (0.65/day)
Storage 1TB 980 Pro
Software W11 Pro
BIOS handles the fan controller even if programming it is being overruled by third party software. The issue is cascading electrical responses the board doesn't expect will only extrapolate with mixed fans. Honestly, lower end boards are questionable powering and feeding a signal into even two identical fans drawing less than .5A peak.
Legacy board designed to barely support intake/cpu/exhaust are not a good platform to control amount of fans modern cases will mount.
43,537 (6.77/day)
Well to reach those faster speeds requires different input voltages.
You migh consider a fan controller that can handle those fans
407 (2.00/day)
System Name AM4_TimeKiller
Case Corsair 7000D Airflow
Mouse Logitech wireless mouse
PWM control will work fine, that's independent of fan size. As for RPMs, this may or may not work properly.
I did similar thing years ago and the reporting results from BIOS were sometimes correct, sometimes badly inaccurate.
Even if you have "same" fans, their RPM will not be the same. Every manufacturer states kind of limits for RPMs (+/- speed % tolerances).
Thus, daisy chaining RPM signal from multiple fans of "same" type will not yield the most accurate results.
Pin for RPM speed does not work as 1-wire bus, fans are not addressable.
To get most accurate results, pick one fan and remove RPM pin connection from others.
