Mobo choice for 12600k after returning MSI Tomahawk ( Broken M2 shield standoff )
79 (4.39/day)
After returning my Broken standoff holder I need a need mobo.
This are the options I have currently in my country
MSI PRO Z790-A WIFI DDR4 Intel Z790 Soket 1700 DDR4 5333(OC) = Same mobo but Z790 versionn around 230 $
MSI MAG Z790 TOMAHAWK WIFI DDR4 SOKET 1700 DDR4 5333MHZ(OC) = Tomahawk 790 version = 300 $
MSI MB MPG Z790 EDGE WIFI DDR4 SOKET 1700 DDR4 5333MHZ(OC) = around 350 $
MSI PRO Z690-P DDR4 SOKET 1700 DDR4 5200 (OC) = 230 $
MSI PRO Z790-A WIFI DDR4 Intel Z790 Soket 1700 DDR4 = 230 $
MSI MB PRO Z790-P WIFI DDR4 SOKET 1700 DDR4 5333MHZ(OC) = 220 $
These are the options I saw 5th one is really good reviews but what do you think.?
Please help me :D
1,048 (0.67/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH Z333 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard Laptop built-in keyboard
Software Windows 10 Enterprise 20H2
If you don't race for a "design", go for cheapest MSI MB PRO Z790-P WIFI DDR4 SOKET 1700 DDR4 5333MHZ(OC) = 220 $.;)
If you will put i7/i9 in future then MAYBE "TOMAHAWK" is worth it.:rolleyes:
Won't buy Z690 these days for fckn SAME price as for Z790 - same rule goes backwards - won't buy Z790 if there are Z690 TON cheaper.;)
Are you really OC your 12600K? Will you put i7/i9 in future? If "no", there are B760 options - just, of course, check if they are really worth cheaper than Z counterparts.:)
2,972 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
whatever has enough USB/M.2/SATA Ports for your needs.
nothing else matters in these days except if you want to achieve world record overclocks with liquid helium.
2,690 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Well...from that list I guess you set your eyes on MSI as a brand :D, but it is not possible to answer your question. What are you looking for in this motherboard? Do you need USB-C Gen 2.0 for the front panel of your case? Will you OC? What kind of drives you want to combine? That's all up to you.
1,048 (0.67/day)
Memory 24 GB @ 3200
Mouse Logitech G604
Wonder what difference P and A version
little diff, but usually "A" are better, and "naming" and "what's better" is same for MSI and ASUS LOL:D
I wonder who "snatched" the naming:D
6,151 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
79 (4.39/day)
Will not OC manually. Got Asus Proart pa case
And you say "I won't overclock".
But can u use full potential of the system with 660 cards?
1,048 (0.67/day)
Memory 24 GB @ 3200
Mouse Logitech G604
as much as there is a proper power goes to CPU from MB VRM, you will use FULL POTENTIAL. ;) OC these days is pure "money game", just compare:
back then you could "OC" your Pentium cheapo CPU for a pretty 800+ MHz, now if you try to OC your "hot" 12600K to this, then you will need some N2O stuff to get it cooled and anyway 500 MHz is more realistic...:oops:
6,151 (2.85/day)
Poland
The question should be "Will I utilize the full potential of the CPU/mobo". And you should have asked that when you made a choice to buy 12600k which you don't want to OC.
79 (4.39/day)
So the only difference is extra m2 lots and usbc etc. What about e cores there will be no problem with 660 ?
That's what I was trying to say sorry
Yeah but isn't that upgrade over 12400f?
1,694 (3.91/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
None of these boards are a good fitment for Intel Alder and Raptor Lake processors. You should really consider a DDR5 board so you're not leaving a bunch of performance on the table.
My 2 pennies.
GL!
