Mobo supports led strips
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
So I bought a mobo which supports led strips but not sure how this works as I have never used led strips before. What kind of led strips should I buy?
The mobo model is gigabyte B450M gaming.
18,062 (2.44/day)
Most addressable 4-pin 12V LED strips should work as per the manual.
Something like this maybe?
128507
1,890 (0.77/day)
Cusp Of Mania, FL
Processor Ryzen 9 3900X
Case NZXT H710
Keyboard HyperX Alloy Pro
Most will work fine... just don't plug them in backwards!
Personally I like phanteks strips. They're cheap, stick decently well and look great. The only issue I've had on one board in particular is the color channels are mapped to different pins from the mobo output... so to get red light I set blue. Or to get green I set it to red.
