Monitor goes into sleep mode while gaming
114 (0.02/day)
Waterford, Ireland
System Name This one!
Processor AMD Ryzen 5 3600
Motherboard ASRock B450 Steel Legend
Cooling Stock Cooler
Memory Crucial Ballistix 2x8gb DDR4 2400Mhz
Video Card(s) KFA Nvidia GeForce GTX 1080 EXOC 8GB
Storage SAMSUNG 840 SSD 250Gb + Crucial MX500 500GB SSD + Western Digital 3TB HDD + Hitachi 320 GB
Display(s) ACER KG281K 4K
Case Corsair Carbide 270r
Audio Device(s) Creative Sound Blaster Z - Edifier 1280t - Beyerdynamics DT990 Pro 250ohms
Power Supply Seasonic M12II Bronze 850W
Mouse Corsair Vengeance M65 RGB
Keyboard AFX
Software Windows 10 64-Bit
Well lads, my problem is a real puzzler to me.. while gaming my computer seems to crash? although I am not sure.. as I still hear everything running inside the computer.. although there is no sound coming from my speakers, and my monitor just seems to turn off and then it displays a message stating it's entering sleep mode.
I've no idea what's going on here, but it's really depressing me of late :p
6,270 (0.91/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
IS this happening to the system listed in your specs?
Solaris17
Super Dainty Moderator
27,198 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I was going to respond with a joke but it wasnt that great; So moving on, do a clean install of drivers and install the latest AMD WHQL drivers apparently they fixed the black screen issue with them. Things to consider.
It may be the monitor if you can try a different one.
It might be the game causing a driver problem does it happen with more then one?
AsRock
TPU addict
19,152 (2.98/day)
UK\USA
Sounds like your video card is crashing maybe to a bad driver or heat and it's not recovering.. you checked the GPU fan for dust build up ?.
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
Cheers for the responses lads.
This is indeed happening to my current system that I've listed on my profile.
As an Irish man it's always easy to start with a lame joke! tis a great laugh ;)
I have the latest AMD drivers, but I'll reinstall it for the sake of trying ;)
The only other game that I have been playing is Bioshock Infinite, but this game crashes due to a lack of system memory apparently.. which is impossible ^^ so I am clueless there.
The game that I have this current problem with is The war of the Vikings, it's in it's beta stage and I play it through Steam.
I use MSI Afterburner to monitor my GPU, the heat never goes above 60 degrees, and I only purchased it a few months back, I have checked the fans and they are clear of dust..
AsRock
TPU addict
19,152 (2.98/day)
UK\USA
Bioshock crashing might be due to a currupt HDD \ pagefile or having the pagefile turned off or fixed amount although only time i have pagefile issue's is either having it turned on with a fixed amount so i just keep it off.
Try checking for errors on all your hard drives in case that's the issue.
Try using GPU-Z as it tends to give more temp readings if they are available. Like for example on my 6970 i have 4 just on the GPU alone and if contact's not good it shows me. All so known that some times that contact can become bad over time which is what i like about my card and wish they did it more often.
I have had 3 good readings on my gpu and 1 terrible one being 25C difference so the reading 60 another part of the gpu still could be hotter.
6,270 (0.91/day)
New York
Has it always had this issue?
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
the screen is powering off because the system has hard frozen, instead of bluescreening. that tends to imply the video card is at fault, or possibly the PSU.
Solaris17
27,198 (3.83/day)
Alabama
VR HMD Quest 3
im banking on PSU personally.
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
After using GPU-Z I can now safely assume that it's definitely not an over heating issue, all is fine in that department.
This issue started about five days ago, roughly around the installing of TeamSpeak and the latest Catalyst drivers, could it possibly be due to these?
I'm thinking it's probably my PSU as I've had it for a good six years now.
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
Try removing the CPU overclock and see if it still crashes
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
I've already tried that, no change.
259 (0.06/day)
Processor Intel i7-4770k
Motherboard ASUS MAXIMUS VI HERO
Cooling Deepcool GAMMAXX S40
Memory Kingston HyperX Beast Black 8gb @ 1600 cl8
Video Card(s) MSI GTX 670 POWER EDITION
Storage Samsung 840 EVO 250GB / WD Caviar Black 500GB
Display(s) BenQ XL2420T
Audio Device(s) Asus Xonar U3
Power Supply FSP 650w
check out your power plan in windows, or gpu drivers. there 95% is your answer
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
I'm two steps ahead of that one ;) I've fiddled around with everything in the power settings the moment this problem occurred, all is as it should be, I was desperately hoping that I'd find the answer in here too believe me :L
Mussels
58,413 (7.87/day)
Oystralia
what PSU do you have?
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
It's a Corsair 650Watt
Mussels
58,413 (7.87/day)
Oystralia
i can see why you wouldnt suspect it then. it could be faulty, but being a good brand does give it some credence.
got a spare PC/spare parts? being able to swap PSU or GPU would really help here.
AsRock
TPU addict
19,152 (2.98/day)
UK\USA
Uninstall the newer drivers and install the ones you had on before and remove your overclock on the cpu and maybe underclock the gpu just to see if the issue goes away.
And i been getting worried about my PSU as that's been around just as long.
2,417 (0.40/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
C
I had the same problem with Bioshock Infinite. It was caused by my mobo switching my ram to single channel.
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
Well I've underclocked my GPU and stopped the overclock on my CPU, still the same crash :/
I've the pagefile turned off on the hard drive that I use for Bioshock, I don't have any spare parts to mess around with though :/
Funny thing, my computer freezes whenever I launch CPUZ, so I can no longer use it now ;s
259 (0.06/day)
reinstall OC. Maybe HDD issue
114 (0.02/day)
Waterford, Ireland
Keyboard AFX
Unlikely a HDD issue, Bioshock is on a HardDrive, Vikings on an SSD.
934 (0.15/day)
Texas
System Name Dell inspiron 5570
Processor Intel® Core™ i7-7500U Processor
Motherboard Dell Inc.
Memory SK Hynix 4GB DDR4 SDRAM PC4-19200
Video Card(s) Intel(R) HD Graphics 620
Storage Intel Optane+932GBHDD w/ External Crucial M500 240GB ssd
Display(s) 15.6" w/ Extended display Samsung 27"
Audio Device(s) Realtek Audio
Mouse ONN Wireless
Software Microsoft Windows 10 Home (x64)
Benchmark Scores HaHa yeah right :p
Have you checked the resolution settings? Years ago I had the same issue but the game setting was calling for a resolution not supported . I doubt this will be the issue but you might check the game vs the video card settings vs what the monitor supports.
6,270 (0.91/day)
New York
I find turning the page file off can with some apps cause troubles. I would turn your page file back on and set appropriately.
1,400 (0.30/day)
78°55' N, 11°56' E
System Name -aLiEn beaTs-
Processor Intel i7 11700kf @ 5.055Ghz
Motherboard MSI Z490 Unify
Cooling Corsair H115i Pro RGB
Memory G.skill Royal Silver 4400 cl17 @ 4403mhz
Video Card(s) Zotac GTX 980TI AMP!Omega Factory OC 1418MHz
Storage Intel SSD 330, Crucial SSD MX300 & MX500
Display(s) Samsung C24FG73 144HZ
Case CoolerMaster HAF 932 USB3.0
Audio Device(s) X-Fi Titanium HD @ 2.1 Bose acoustimass 5
Power Supply CoolerMaster 850W v2 gold atx 2.52
Mouse Razer viper 8k
Keyboard Logitech G19s
Software Windows 11 Pro 21h2 64Bit
Benchmark Scores ► ♪♫♪♩♬♫♪♭
Try cpu-z as admin.
That screen problem is typically a gpu driver reset or TDR or bad gpu OC.
Try different driver and try not to run gpu-z in the background or any other monitoring tool other then MSI afterburner, to eliminate any possible suspects.
And did you dobule check gpu cables? and maybe gpu needs to be reseated.
