Monitor issue
149 (0.16/day)
System Name Main PC
Processor I5 12400F
Motherboard MAG B660M MORTAR WIFI
Cooling Noctua NH-U12S
Memory Corsair Vengenance LPX 2x8 GB DDR4 3000 MHZ C16
Video Card(s) EVGA RTX 2060 KO
Storage WD SN550 500GB M.2-2280 (Main drive)/ Crucial MX500 500 GB 2.5" SSD/ SanDisk Ultra 2 TB 2.5" SSD
Display(s) Main: AOC C24G1 24.0" 1920 x 1080 144 Hz 1ms, 2nd: AOC 24B2XH 23.8" 1920 x 1080 75 Hz
Case Fractal Design Pop Air
Audio Device(s) Razer Kraken 7.1
Power Supply Be quiet System Power 9 500 CM 500 W 80+ Bronze Semi-modular
Mouse Razer Deathadder Chroma
Keyboard Corsair strafe (Cherry MX Silent)
I have the AOC C24G1 24.0" Curved Monitor as my primary monitor. It's 1920x1080 144 Hz with a VA Panel and i bought it around October of 2020. The monitor has been great for me so far but I started having this issue show up for me for some reason. If I haven't used the montior in a while and I turn it on, this bleeding starts to happen. This issue usually happens when i return home from traveling and I turn on the monitor after a couple of weeks of no usage i.e generally just after some time of no usage. This bleeding only happens when the refresh rate is at 144 Hz, if I drop the refresh rate down to 120Hz the bleeding stops, rarely sometimes though the bleeding happens even at 120 Hz and I have to drop it down to 100 Hz. After a couple hours of the monitor being on, if i try to revert the refresh rate back to 144 Hz, it works and there's no bleeding.
Any ideas on how to fix it or is it a sign that my monitor is going to die soon.
FreedomEclipse
~Technological Technocrat~
24,185 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Step 1 - reseat the GPu, also give it a clean and visual inspection. Also check the contact points in the PCi-e slot on the MB.
Step 2 - Try a different cable.
Step 3 - Try a different monitor (if possible)
Step 4 - The GPu is cooked and im sorry for your loss.
Step 4.5 - Pull out your wallet and buy GPu
Merry Christmas GIF by filmeditor
::EDIT::
That does look to me that the GPu is cooked but im crossing my fingers.
If you can test the 2060 in another computer, It will also help you see if its really the GPu that is cooked.
13,357 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Assuming the cables are securely fastened and the card fully seated, you need to isolate the problem to the monitor or the computer. I would try that monitor on another computer or another monitor on that computer and see if the problem persists, and where.
If it appears the problem is in the computer and not the monitor itself, I would swap in a known good power supply to see what happens. Since EVERYTHING inside the computer depends on good, clean, stable power, you need to verify you are providing it.
149 (0.16/day)
System Name Main PC
Processor I5 12400F
I have a 2nd monitor that i use in combo with my main monitor. That one has been running fine constantly with absolutely no issues what so ever, so i think it is mainly a monitor problem more than a GPU problem because the 2060 hasn't really shown any signs of erratic behaviour like crashes or erratic temps that would indicate problems. I cleaned the fans and heatsink with an airgun last week as well and temps are all fine with no erratic stuff. I might do a stress test on it just in-case.
I'll still recheck everything regardless, unfortunately I don't have a spare displayport cable so it'll be a couple of days before a new one arrives if i were to order.
I don't have another computer near me right now that I can use except if i rebuild my system with my old 9400f and B365 motherboard, however one of my friends has an old GTX 970 that he still has after upgrading to a 6700 XT, perhaps I can ask him if I could borrow the GTX 970 or If I could test my 2060 in his PC, he's on vacation though so no idea when he'll be back lol.
I run a 2nd monitor in combo with my main one. The 2nd one works fine with my GPU, albeit my 2nd monitor is a cheap 75 Hz monitor. I'll be testing my GPU in my friend's PC when he gets back or borrow his old GTX 970 and test it in my PC.
13,357 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Do both monitor connect via the same type data signal? That is, are both HDMI or both DisplayPort? Or do they use different types. I would still swap just to verify it is the monitor and not the graphics solution.
If it does conclusively point to the monitor, there probably is nothing you can do to "fix" it. The only option may be to go with a work-around by switching ports/inputs on the monitor.
2,032 (0.63/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Warranty or e-cycle monitor if you lack the skills and resourceful nature to determine if it can be repaired.
13,357 (1.99/day)
Nebraska, USA
Mouse Logitech M190
It is not likely the cost to repair a 4 year old monitor would be economically feasible unless the fault was visibly obvious and the replacement parts readily available at an affordable price.
But at this point, it has not conclusively been determined it is the monitor. So recycling at this point would be premature.
@Ayhamb99 - got a laptop?
149 (0.16/day)
System Name Main PC
Processor I5 12400F
I do have a laptop, regardless though the only issue with this is that it prevents me from running my main monitor at its native refresh rate of 144 Hz, if i just leave it at 120 Hz the thing doesn't bleed, so like the worst case scenario if i can't fix it is that I have to play at 120 Hz from now on which isn't really something that warrants me to have to buy a whole new monitor lol, also too poor rn to buy a new one anyways.
13,357 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Yes, I understand the issue. My point is, at least from here you have not yet determined if the problem is a fault with the monitor, or if the problem is a fault with the computer/graphics solution. But hey! It is your system.
Good luck.
42,682 (6.68/day)
