Monitor to Graphic card
ilmonstrum
4 (0.00/day)
Hello!
Have problems connecting my monitor to my graphic card. Screen is working but is a little yellow and is not so bright now.
Monitor has these ports... DVI D, Display Port, Mini Display Port, USB
The graphic card has.. 2 HDMi, 2 Display port, USB-C.
I must use two monotors. Is there any adapter that may work?
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Display Port is the “best connection“ so if both your monitors have DP then that is your best bet
ilmonstrum
4 (0.00/day)
It is connected with Display port right now. Its working but screen is yellow. On my old graphic card everything worked fine, but it had to be connected with Dvi-d and the Display port to work.
217 (0.13/day)
System Name PowerSpec 1720 (Clevo PB70EF-G)
Processor i7-8750H (UV)
Motherboard PB70EF-G
Cooling SYY 157
Memory 32GB 3000MHz 15-18-18-36 1T (OC)
Video Card(s) 115W RTX 2070 8GB GDDR6 (OC/UV)
Storage 500GB WD Black SN700 NVME, 1TB Samsung 980
Display(s) 144Hz G-Sync 17.3" IPS
Case PowerSpec
Audio Device(s) Sound Blaster Pro-Gaming X
Power Supply 230W
Keyboard Redragon K556/DITI K585
Software M$ Windows 10 Pro, Throttle Stop 9.5, MSi Afterburner, ParkControl
What monitor are you using specifically? What graphics card?
If you slightly move the cable on both monitor and graphics card ends does the image color change or distort at all?
ilmonstrum
4 (0.00/day)
ASUS GeForce RTX 2080 Ti 11GB​
HDMI-DISPLAY PORT-USB.C
EIZO 27 Inch FlexScan SX2762W​
DVI D-DISPLAY PORT-MINI DISPLAY PORT
Nothing happens when I move the cables...
846 (0.12/day)
Terminus GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) RX 9070 XT Hellstone OC
Case Rocketfish (Lian Li) e-ATX (2006)
Audio Device(s) Harman Kardon HK695 2.1
Mouse HP HDX wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
I would first go to the monitor's on screen display, tools menu, & All Reset just to make sure no settings got tweaked in the monitor.
Next, I would move the Display Port cable to the other Display Port output on the 2080.
If it is still yellow & dim, try a new Display Port cable or Display Port to mini DP cable.
Also try to connect the monitor to a different PC or laptop with the new DP cable.
217 (0.13/day)
Cooling SYY 157
Case PowerSpec
Power Supply 230W
I have seen Windows Night Light feature act up and only tint 1 monitor. Is that feature on for you?
Your monitor also has this feature; is it on?
  • Simulation of two types of red-green (protanopia and deuteranopia) and one type of blue-yellow (tritanopia) color blindness.3 This allows designers to ensure their color schemes can be recognized by people with all types of color vision.”
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
have you tried resetting the setting from your control panel and the monitor too?
