Monitor turns on, then off.
DrPepper
The Doctor is in the house
7,482 (1.20/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
Hello everyone I've got a samsung p2450 and when I turn it on, it immediately turns back off. I've replaced what looked like a burnt out resistor but it still turns off very quickly. Doesn't look like there are any damaged caps at all.
brandonwh64
19,542 (3.47/day)
Sounds like the LCD inverter is damaged. Same thing happened to an old sony laptop and I replaced the inverter and had no further issues
DrPepper
7,482 (1.20/day)
System Name Rusky
That's what I thought. Where can I get a new one.
1,056 (0.21/day)
System Name Prodigy
Processor i5 2500K
Motherboard AsRock Z77e-ITX
Cooling Liquid
Memory 2x4GB Samsung LV
Video Card(s) Zotac GTX 680
Storage OCZ M-SATA 120GB SSD/OCZ Petrol 120GB SSD/Intenso 240GB SSD/500GB Seagate HDD
Display(s) Samsung 32" HDTV
Case BitFenix Prodigy
Power Supply OCZ Elite 500w
ebay isnt a bad choice.
also aswell as looking for the monitor's manufacturer number,look on the circuit board for any identification numbers etc as most manufacturers will use the same parts suppliers,so one board will be available from different source monitors.
DrPepper
7,482 (1.20/day)
System Name Rusky
Can't find any replacement inverters on the web for it :(
1,539 (0.27/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
I hope your warranty was over before you open it up to change the resistor...
Samsung & others have a 3 years warranty on their monitors + free shipping
Anyhow i hope you can fix it for cheap , because usually it cost more to fix then to buy a new one but since you're doing yourself you'll save the labor cost ;)
DrPepper
7,482 (1.20/day)
System Name Rusky
It's not my monitor my friend said that the warranty was over so that's why I opened it up.
95Viper
Super Moderator
13,152 (2.21/day)
What is the part number of the inverter board?
Should be printed on it like this:
DrPepper
7,482 (1.20/day)
System Name Rusky
95Viper
Super Moderator
13,152 (2.21/day)
Your board may look something likes these...
Edit: Sorry was having some technical problems.:)
Yes, it is part of the power supply board.
Thanks, dr emulator (madmax)...
2,270 (0.39/day)
the uk that's all you need to know ;)
System Name not very good (wants throwing out window most of time)
Processor xp3000@ 2.17ghz pile of sh** /i7 920 DO on air for now
Motherboard msi kt6 delta oap /gigabyte x58 ud7 (rev1.0)
Cooling 1 green akasa 8cm(rear) 1 multicoloured akasa(hd) 1 12 cm (intake) 1 9cm with circuit from old psu
Memory 1.25 gb kingston hyperx @333mhz/ 3gb corsair dominator xmp 1600mhz
Video Card(s) (agp) hd3850 not bad not really suitable for mobo n processor/ gb hd5870
Storage wd 320gb + samsung 320 gig + wd 1tb 6gb/s
Display(s) compaq mv720
Case thermaltake XaserIII skull / coolermaster cm 690II
Power Supply corsair hx 650 w which solved many problems (blew up) /850w corsair
Software xp pro sp3/ ? win 7 ultimate (32 bit)
Benchmark Scores 6543 3d mark05 ye ye not good but look at the processor /uknown as still not benched
Erm is the inverter the part connected to the actual display or another part that is either the power supply or the board with the display on it.
it more than likely will be part of the powersupply ,in my dealings with monitors they usually are ,laptops however usually have a seperate inveter , i have seen some with replaceable mosfet chips, but alot are surface mounted ,which would be a royal pain in the ass to remove
hopefully they won't be ;)
DrPepper
7,482 (1.20/day)
System Name Rusky
Pictures aren't appearing. I'l get detailed pictures in the morning.
The power supply has a massive burn mark on the resistor that I replaced which should be repaired now.
2,270 (0.39/day)
it'll be conected to the inverter by the pink and white partially sleaved wires (usuall covered by some silver coloured metallic tape)
2,270 (0.39/day)
more than likely one or more of the transistors have blown or shorted out (you'll have to get your multimeter out ,but wait for the mains capacitor to disharge or you''ll be frying tonight :laugh:)
take pics of the board
DrPepper
7,482 (1.20/day)
System Name Rusky
I'l remember. I thought that board was the power supply since the power cable went to it. I'l get pictures and get it sorted out, got a lot on my plate tonight.
2,270 (0.39/day)
well we can guide you to the part that might have shorted out (with enough pics), but then it's upto you to test it and what not ;)
ye the inverter is usually intergrated onto the psu board ,not to complicated a circuit, but as i've said to others the parts might be hard to get a hold of :(
1,056 (0.21/day)
System Name Prodigy
Processor i5 2500K
Cooling Liquid
In all honesty,a photo of the OP's board should allow us collectively to source a replacement,as long as the board model number can be ID'd.
I'm looking at a schematic of the pcb now but navigating it is painfully difficult due to only having a half gig of ram in my pc :roll:
DrPepper
7,482 (1.20/day)
System Name Rusky
Here are the pictures. Please excuse my shitty soldering I have insanely shaky hands.
DrPepper
7,482 (1.20/day)
System Name Rusky
2,270 (0.39/day)
hm this kinda sounds familiar but sauce :laugh::D
seriously though i'd like to see the diagram (if you've got the exact one ;))
@the Dr, label your cables first before dismantling it ;)
DrPepper
7,482 (1.20/day)
System Name Rusky
I can remember it all off by heart now :)
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
I was gonna say that this all sounds like an awful lot of bother and possible expense for an old monitor and recommend just buying a new one, which is likely to have better specs anyway.
However, as you've already bought the part, I hope it fixes it for you. :)
DrPepper
7,482 (1.20/day)
System Name Rusky
It's only a year old though.
