Monitor wont work with 144hz on Windows 10
3,352 (0.61/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Hi guys.
I bought a new monitor, the Omen 25 and it works perfectly with games.
The weird thing is that the 144hz wont work on windows, but in all games I have tested, it holds 144hz perfectly.
I dont know if I am missing something or an issue with Windows 10.
Can anyone help?
I think it is not a problem of my GPU, neither a problem of the monitor, since it can work 144hz in games.
FreedomEclipse
~Technological Technocrat~
24,169 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I think its something to do with your graphics card being 7 years old and maybe not supporting higher refresh rates. I think high refresh rates also need a HDMI v1.3-2.0 or DisplayPort Connection
In any case. your machine is too much of a potato to run 144hz smoothly even at 1080p. Its not worth wasting the time, effort and money if you need to buy cables to get it working. your setup wont be able to push 144hz.
757 (0.36/day)
Have you manually set it to 144Hz in the control panel? What is your current GPU...?
Let’s not assume his profile is updated without asking first...
FreedomEclipse
24,169 (3.74/day)
London,UK
Id was considering debating this with you but its not worth my time.
In any case, Im going by what information is available to me. Im sorry that you dont find my response to your satisfaction given the situation. Report my post as you see fit.
757 (0.36/day)
Sheesh... someone’s defensive!
Assumption is the mother of all F ups. Always ask if unsure, though I get your justification.
I may be pleasantly surprised and find that his specs are updated. Who knows...? Let’s see what the OP says.
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
A Phenom II x4 B50 and 6GB of ram, yeah/NO!
Honestly............
:laugh:
I'm putting that in my quotes!
Regeneration
NGOHQ.COM
3,131 (0.45/day)
You'll need a special cable to use 144Hz with your outdated hardware. DVI dual link to DP, or active DVI dual link to HDMI.
3,352 (0.61/day)
Case Zalman S2
Yes I have different specs now. I am waiting for CPU mobo and ddr4 ram to come so again I will need to update.
But the GPU I currently have is a GTX 750 TI. Which will also be updated to probably Rx 580. But nothing to do with specs. The GPU runs pretty much a lot of titles above 100fps, titles that I play.
It has nothing to do with the power of the card.
When I run the game on exclusive full screen 144 Hz or when I change it on Windows and quickly run a game, it works. When I stay 10 seconds on windows with 144hz, it won't, it will just say no signal!! And sometimes it says 288hz for no reason. Maybe geforce drivers?
On windows it says no signal, on all games it works perfectly. I tested 10 games so far.
Also 120hz on windows 10 is stable.
silentbogo
5,560 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
You may want to check your HDMI | DP cable. Had similar issues on my main 4K monitor with a wonky displayport connection. Occasionally it would lose signal for no reason(until I re-plug the cable).
Another thing could be the monitor itself(scaler issues, cheap design, misrepresented specs). Try running it at 120Hz for some time, see if it helps. Some 144Hz monitors only work over DP, while HDMI is limited to 120Hz (without mentioning it in specs or locking this mode on HDMI).
8,253 (1.19/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
if it dosnt like 144 run it at 120 you wont see any difference..
trog
3,352 (0.61/day)
Case Zalman S2
42,611 (6.67/day)
207 (0.10/day)
Processor 3700x @ 4.3
Motherboard Crosshair 7 hero
Cooling Kraken X62
Memory 16GB Trident-Z 3200
Video Card(s) EVGA RTX2080 XC Ultra
Storage Samsung 960 evo 500gb NVME
Display(s) ASUS ROG Swift PG348Q
Case NZXT H500
Audio Device(s) Phillips SHP 9500s.....Audio Technica AT 2035 microphone.....Scarlett 2i2 audio interface.
Power Supply EVGA 850W Supernova G2
Mouse Model O
Keyboard Corsair K65
Get a display port cable. You're probably not even getting above 60hz in game. Game settings are probably doing 1920x1080 @60hz, that's why its working. Enable Vsync in game @ low settings and see where it caps you, I bet its 60 fps.
3,352 (0.61/day)
Case Zalman S2
Some games cap 60 some go beyond 144 on low settings.
The game I notice the difference the most are 2D games like dead cells.
207 (0.10/day)
Cooling Kraken X62
Case NZXT H500
Mouse Model O
If you right click on your desktop and go into Nvidia Control Panel under "change resolution" what is your refresh rate set to? Without a display port you may need a Dual Link DVI cable. I would wait until you grabbed the RX580 and use the display port cable that came with the monitor.
3,352 (0.61/day)
Case Zalman S2
22,673 (6.05/day)
The thing you most likely notice, is that your monitor refresh rate is not native when you run 120hz ingame, or just that the way it is calibrated is not optimal (many monitors use an overdrive of some sort that varies in quality). If the monitor has a 120hz native setting, use that to get around that problem. Because thén, there is no way you can possibly notice the difference between 120 and 144.
You can check this website to see if your monitor's adjusted refresh rate is 'true' and not having dropped frames or inconsistency:
There are a few others that can provide info on that, there as well. A native refresh rate gets extremely close to the actual number, like 119.98 hz for a 120hz monitor.
You can set your refresh rate in NVCP to make it a global setting, but I reckon you know.
Regeneration
NGOHQ.COM
3,131 (0.45/day)
You're using HDMI on non-HDMI 2.0 hardware. If you don't have DP output on the graphics card, you'll need to use DVI dual link to DP cable to get 144Hz.
7,412 (2.75/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
noticeable - yes,absolutely.
meaningful-not at all.
3,352 (0.61/day)
Case Zalman S2
I get 119,982 hz when in 120hz.
I think this has to do but it is really strange that only on windows the 144hz doesnt work.
All games run smoothly at 144hz.
This is the card I have:
I dont know if the card supports HDMI 2.0.
silentbogo
5,560 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
HDMI 1.4a is supported. GTX750Ti was one of the first if not the first Maxwell-based card. That's why I'm saying - try 120Hz. Formally the interface caps out at 144Hz FHD, but 120Hz seems to be the safe max.
Plus, I've looked up your monitor and some users had similar reports of HP Omen 25 blacking out only in certain games/applications/situations when running 144Hz over HDMI.
