MOSFET Cooling help.
6,776 (0.93/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
I am playing around with my test pc (in my signature - Jetway board). I am trying to get a stable OC out of my 5600. Last 2 days its hot here in Southern california and I have to drop my OC a few numbers. Currently @225*14 with memory running at DDR2 747.
I read online it might be because of poor quality/heating Mosfets/VRM. I have attached a picture of the mobo. The marked position is the mosfet area right?
Right now I have squeezed in a 80mm TT fan and seems to do the trick. What other methods are efficient?
Help please.
:respect:
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
stick some ramsinks on em and see if the temps go down. it will help the fan get more of the heat away!
Solaris17
Super Dainty Moderator
27,590 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
VR HMD Quest 3
5,052 (0.75/day)
Manchester, United Kingdom
Processor AMD 5800X3D
Motherboard Asus Strix B550-F Gaming
Cooling Corsair H100i
Memory 2 x 32GB Corsair Vengeance
Video Card(s) Sapphire Pulse 6800XT
Storage 1 x 1TB 980 PRO, 1 x 1TB Corsair MP510 Force
Display(s) 1 x Dell 27" 165hz
Case Lian-Li O11D Evo
Power Supply EVGA 1000W P2
Keyboard Logitech G915
Software Windows 11 Pro x64
The MOSFETs are the smaller chips in that are yes, the larger ones are...well I don't actually know, but they don't require cooling.
You want to pick up some Enzotech MOSFET heatsinks if you for them if you can.
By the way, cooling of the MOSFETs is of the highest priority when overclocking, they can burn out very easily.
6,776 (0.93/day)
System Name ---
Solaris17
27,590 (3.84/day)
Alabama
VR HMD Quest 3
as darknova said i think they sell mosfet sinks but as he also said cooling fets is imparative so yes. besides its not that much 4 ramsinks at most.
5,052 (0.75/day)
6,776 (0.93/day)
System Name ---
yeah this is a cheap $40 board that suprisingly have lots of OC features. Similar to Biostar T-Force. but I think has cheap parts and thats the reason it needs more voltage to push the cpu. I tested with 2 cpus before I bought the 5600. 1. A64 3200 which runs default at 1.25V and can be pushed to 2.6 from 2 at 1.3V on a cheap ECS board. But this one needs 1.35V
2. X2 3800 windsor - same thing can be pushed to 2.2 from 2 from 1.2V to 1.25V on ECS but on this one I need to pump 1.3V and will not go even one single HTT after that.
For the 5600+ when I set the Vcore as 1.35V in bios, cpuz and Everest shows as 1.4V.
6,776 (0.93/day)
System Name ---
35 (0.01/day)
Serbia, Belgrade
System Name Jorge Costa de Alfinho
Processor AMD BH-G2 @ 3Ghz (1.3V)
Motherboard GA-MA790X-UD4P
Cooling Alpenföhn Broken
Memory 4x 2Gb Black Dragons @900Mhz CL5 1.95V
Video Card(s) GA 8400GS
Storage WD 640Gb
Display(s) ASUS VW222U
Case MoBo box :)
Audio Device(s) SB0350
Power Supply ASUS U-75HA
Keyboard CM Suppressor
Software MAME32
Then no need for thermal tape, that ZALMANs have some sticky sh*t on himself. Just paste it on 'FETs... :)
1,065 (0.16/day)
System Name [Primary Workstation]
Processor Intel Core i7-920 Bloomfield @ 3.8GHz/4.55GHz [24-7/Bench]
Motherboard EVGA X58 E758-A1 [Tweaked right!]
Cooling Cooler Master V8 [stock fan + two 133CFM ULTRA KAZE fans]
Memory 12GB [Kingston HyperX]
Video Card(s) constantly upgrading/downgrading [prefer nVidia]
Storage constantly upgrading/downgrading [prefer Hitachi/Samsung]
Display(s) Triple LCD [40 inch primary + 32 & 28 inch auxiliary displays]
Case Cooler Master Cosmos 1000 [Mesh Mod, CFM Overload]
Audio Device(s) ASUS Xonar D1 + onboard Realtek ALC889A [Logitech Z-5300 Spk., Niko 650-HP 5.1 Hp., X-Bass Hp.]
Power Supply Corsair TX950W [aka Reactor]
Software This and that... [All software 100% legit and paid for, 0% pirated]
Benchmark Scores Ridiculously good scores!!!
Anyone have any actual data on cooling MOSFET's vs. not cooling them? I always thought it was just a marketing gimmick by the motherboard manufacturers, especially DFI. I mean, considering most MOSFET's are rated at around 145C, 150C or even 175C, which means they can take the heat. I do like DFI motherboards and I own one of their LanParty series motherboards, which has heatsinks on MOSFET's, but I never bothered to take them off and check out the difference in overclocking. (It would probably be hard to put them back on.)
265 (0.04/day)
Anaheim, California
Processor 9800X3D
Motherboard Gigabyte X870 Aorus Elite WiFi7 ICE
Cooling ID Cooling FX360 Pro
Memory TEAMGROUP T-Force Delta RGB DDR5 Ram 32GB 7200mhz
Video Card(s) EVGA FTW RTX 3090Ti
Storage Acer Predator 4TB NVME
Display(s) Viotek GNV34DBE2, Viotek SUW49DA
Case Hyte Y60
Power Supply Corsair RMx1000 white
Mouse Glorious Model O
Keyboard KBDFans Odin V2
Software W11 Pro
imperialreign
7,043 (1.09/day)
Sector ZZ₉ Plural Z Alpha
System Name УльтраФиолет
Processor Intel Kentsfield Q9650 @ 3.8GHz (4.2GHz highest achieved)
Motherboard ASUS P5E3 Deluxe/WiFi; X38 NSB, ICH9R SSB
Cooling Delta V3 block, XPSC res, 120x3 rad, ST 1/2" pump - 10 fans, SYSTRIN HDD cooler, Antec HDD cooler
Memory Dual channel 8GB OCZ Platinum DDR3 @ 1800MHz @ 7-7-7-20 1T
Video Card(s) Quadfire: (2) Sapphire HD5970
Storage (2) WD VelociRaptor 300GB SATA-300; WD 320GB SATA-300; WD 200GB UATA + WD 160GB UATA
Display(s) Samsung Syncmaster T240 24" (16:10)
Case Cooler Master Stacker 830
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro PCI-E x1
Power Supply Kingwin Mach1 1200W modular
Software Windows XP Home SP3; Vista Ultimate x64 SP2
Benchmark Scores 3m06: 20270 here: http://hwbot.org/user.do?userId=12313
some boards that use MOSFETs or VRMs are notorious for the chips running at thermo nuclear temperatures. I remember reading an article somewhere that was describing how the VRMs on a dual-CPU Intel board were producing temps a little over 120C :twitch:
not saying all boards are like that, but some do require extra attention. It matters not to me if the component is rated to be able to handle those kinds of temps; asides, the cooler the component runs, the better it performs, and the longer the component will live as well.
5,052 (0.75/day)
At stock you can quite happily leave your MOSFETs bare without any issues, but when you start upping NB and vCore you start running into issues as the MOSFETs burn out meaning no power gets to the CPU or NB, resulting in a dead board.
It's really not about gaining extra overclock, just keeping your board alive long enough to give you that massive overclock you are looking for.
35 (0.01/day)
Serbia, Belgrade
Storage WD 640Gb
Case MoBo box :)
Software MAME32
5,052 (0.75/day)
35 (0.01/day)
Serbia, Belgrade
Storage WD 640Gb
Case MoBo box :)
Software MAME32
Understand that, have some expirience.
I wanna say that neither heatsink can cool 'FETs more than PCB of MoBo. I think extra airflow (add some fans to blow on them) is effective more than adding any HSs....
5,052 (0.75/day)
So you want to radiate the heat into the motherboard's PCB? No thanks, I'll take a copper heatsink radiating heat away from the board thanks. Heat = bad. The faster you can remove it, the better, be it CPU's, GPU's, MOSFETs, PCBs...anything, keep it as cool as possible.
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
things have to be cool enough.. not as cool as possible.. i aint gonna say what cool enough is but if things are designd to run at 150c they are okay at 150 c..
good design has some spare capacity.. cheap poor design dosnt.. the fancy heatsinks on more expensive boards are part spare capacity and part go faster stripes.. its hard to say how much of each there is.. i think a fan blowing on the general area is probably good enough..
120 c is bloody burn your finger hot.. if they dont burn your finger they are probably okay..
trog
5,052 (0.75/day)
6,776 (0.93/day)
System Name ---
Hey I tried cooling the cpu area mosfets with a 80mm fan. Then shutdown the machine for about 30 minutes. Unplugged the 80mm fan. Ran the system with full load (Orthos + Prime95) for 20 minutes. Touched those mosys and they seem to work cool. I can touch the mosy for a long time. So I think they are pretty cool. Anyway I left the fan on, extra cooling will not hurt, except for extra durt.
One thing that I found out with this board is it doesn't like any temp monitoring software. When I leave the monitoring tool on and when the machine goes to hibernate and then wake up it hangs. I removed the tool and the machine works fine.
But I will try one of those mosy hs. Are those websites safe? I always buy from egg, but they don't have any of those. May be I will cut the Zalmans and try it out. Will it void the warranty on the board?
6,776 (0.93/day)
System Name ---
I used A64CPUAssistant (both Lite and Full version), Coretemeter and Core Temp. Everest works fine though.
35 (0.01/day)
Serbia, Belgrade
Storage WD 640Gb
Case MoBo box :)
Software MAME32
No man, I understand You but i fear You don't understand Me... if You stick some HS on FET, HS will "mess" heat and when HS "fill" of heat, that will be problem. You will have heat sandwich on FET and for sure higher temperature.
Mabybe first 5 minutes temps (of FET) will be better but later... ;)
FET's will for sure proceed heat on PCB of MoBo and that's relative huge area.
With airflow over FET you give him only extra cooling. You cool FET & MoBo' PCB... All that heat will be absorb from some outake fan and that's best way to deallocate heat. Thats why I like "ORB" CPU coolers. :)
I hope now Yo understand Me. :)
rege
4 (0.00/day)
Processor FX6300@4500
Motherboard Asus M5A97 Evo R2
Cooling Thermalright IFX14 3 fans
Memory 8gb Ballistix LP 6-7-7 1t 1600
Video Card(s) Gigabyte Windforce 7950 @ 1000
Storage Samsung 830 SSD
Display(s) Benq GW2250M VA
Power Supply ADATA 750w
I have to agree with Superstarr, most mosfets (like the ones on suraswami's board) don't benefit from having a heatsink on them. They dissipate heat into the motherboard pcb because they have a metal plate at the bottom where they are mounted. The top of these type mosfets also have a thick plastic insulation so they generally don't get hot to touch even if they are running hot, airflow around these type mosfet is more important and a heatsink might actually insulate them. I once had an old fic via board that had the mosfets mounted vertically with heatsinks pressed against the metal plate of the mosfet, those heatsinks got very hot.
On the other hand some mosfets like the ceramic ones and the small surface mount ones found on gigabyte boards benefit from having a heatsink, they are much more dense and don't dissipate as much heat into the mobo. You also need a fan or good airflow otherwise the heatsink just gets hotter and hotter.
