Motherboard damage?
21 (0.02/day)
Processor R5 5600x
Motherboard asus B550-f gaming (wifi)
Cooling arctic freezer II 280mm
Memory 2x8gb corsair vengeance 3600mhz
Video Card(s) gigabyte rtx 3070 gaming oc
Storage WD Blue SN550 1TB M.2 SSD
Display(s) AOC 24G2AE/BK 24" 144Hz
Case Lian li 011 air mini
Power Supply 750w gold v2 cooler master ATX
Mouse razer naga trinity
VR HMD Oculus quest 2
Would this affect my motherboard? If you look you can see a black stain and you cannsee a faint white line beneath it on the right. It isn't clear on the picture but the line goes straight through those tiny black lines. Will this effect anything? Because the pc still works but is there maybe a performance issue that has arisen???
9,910 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
you mean this one?
looks like from the screw driver, you might cover it using nail polish to prevent any oxidation that may affect in long term
21 (0.02/day)
Processor R5 5600x
you mean this one?
is there any real damage though?
you mean this one?
And could you elaborate on why and how I am supposed to cover it with nail polish?
freeagent
8,731 (3.83/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
It looks like you just scraped the mask off, I would think it should be fine.
21 (0.02/day)
Processor R5 5600x
how about the stain? and is there anything I should do or should i just leave it?
freeagent
8,731 (3.83/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I would just leave it, looks like it was from the manufacturing process.. maybe someone grabbed the board with their glove to early or something, I've seen it before.. looks like a thumb :D
104 (0.07/day)
You should be good, you/they didnt break the traces there. If you get clear nail polish and swipe some over the length of the line it will reseal it so the copper doesnt oxidize and reduces the signals thru them. Thats what micropage was alluding to.
21 (0.02/day)
Processor R5 5600x
do I need to do this because the thought makes me a bit anxious.
and what would that mean (reduces the signals thru them) How would that effect my pc?
does it have to be clear nail polish?
5,137 (3.76/day)
Colorado, U.S.A.
Software Windows 11 Home
I would not bother with the nail polish; it's fine, enjoy your PC
If the stain bothers you, clean it off with isopropyl alcohol
104 (0.07/day)
No, you dont need to from the looks of it. Reduces the signals means when that super thin copper gets oxidized it creates electrical resistance in the damaged one, slowing signals to the traces connected to it and resistance creates heat which more heat creates more resistance etc... until you are on fire. This is a extreme example of a end result but nonetheless absolutely possible. Before that happened you would get signals like unexplained crashing, disconnects, weird errors etc... so dont panic. Yes, clear nail polish cause to make colors they use odd chemicals and compounds like titanium for white, as a example, and other metals for different colors and you dont want to add something like that to a electrical trace. Im not trying to scare you, just giving you the answers to the questions you asked. Like Shrek said you can just enjoy the PC and let it go, especially if its not a very nice board and something very middle of the road or lower.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
Some one eat pizza and dirty hands touched the board.
Cotton and alcohol for medical purposes, they can fight it.
Risk level of this incident = down to 0.5% = there is nothing there for you to repair, other than improving aesthetics by cleaning it GENTLY.
21 (0.02/day)
Processor R5 5600x
and these signals (unexplained crashing, disconnects, weird errors...) would this be like every day like 5 times (often) or like once evry month (rarely)?
I won't bother with the aesthetics but are you sure that the line won't effect anything? the stain is one thing but what about the line?
1,569 (0.30/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX/4.8 GHz cache | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge OC | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB+Crucial P5 1TB+480GB SATA SSD+2 TB HDD | Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE w LG SC9S Dolby/DTS | Realtek ALC1150 (Supreme FX) w 2.1 speakers
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
It won't affect anything since it is not a deep scratch. If you look closely, the copper is not even exposed and hence they won't even be vulnerable to oxidation in the long run.
As for the stain, take a q tip with some Isopropyl alcohol and feel free to rub it off.
9,910 (1.84/day)
Jakarta, Indonesia
Case Icute Super 18
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
For long distance reception of a professional advice, you all ready received the best free of charge.
For 101% valid evaluation, you have to visit me at my lab and pay me for my time.
2,221 (1.24/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Audio Device(s) Logitech z623 <---THE SUCK
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
PCB CLEANING 101
Turn off your rig.
Flip the power switch on your PSU.
Get a cotton swab, otherwise known as a q-tip.
Wet a tip with the highest purity isopropyl alcohol (usually 91%)you can get at the pharmacy, supermarket, corner store or medicine cabinet (what have you).
Clean the oily finger print with the now wetted swab using a gentle circular motion. Dry the now wet spot off with an old wash cloth or t-shirt before the alcohol dries or it may leave behind a whitish residue.
Now that you have properly cleaned any and all oil or grease from the pcb. Nail polish the nicked PCB like @micropage7 suggested and your mb is as good as new. Waalaa!
If the finger print persists. Leave it as is, knowing you have done everything within reason to remove it. It is now simply a harmless part of your mb. Let's call it... character :D
You now know how to properly clean any electronic pcb for the rest of your life.
*This method can also be used to clean thermal paste off of CPUs and GPUs.*
AsRock
TPU addict
19,105 (2.99/day)
UK\USA
To me it looks like a light scratch and a finger print. Maybe like some have already said a little wipe doen with a soft q tip and some high % isopropyl
47 (0.06/day)
Its fine... no traces theee but a copper plate under it.. If you cut a trace you can easily solder a wire from a to b to reconnect a trace
