Motherboard error: MAC address are invalid in both CMOS and Flash
Darren
1,936 (0.27/day)
System Name Cheap yet powerful gaming and entertainment rig!
Processor AMD Athlon 3800+ X2 Windsor, 1 MB L2 Cache (512k L2 Per Core), 65W Energy efficient, 2GHz @ 2.78 Ghz
Motherboard Asrock ALiveNF7G-HD720p Rev v5.0
Cooling Freezer 64, 2x120mm, 1x92mm
Memory 8 GB DDRII PC6400 @ 929 MHz OCZ (2GBx4) timing: 5-5-5-5-16-2T
Video Card(s) XFX ATI4830
Storage Seagate 320 GB SATA (16 MB Cache)
Display(s) 19' HannsG (1440x900 @ 75hz)
Case Coolermaster Elite 330 Black Case
Audio Device(s) Auzentech X-Meridian, Pioneer VSX-516 Receiver 7.1 with DD/DD EX/Prologic II/DTS/DTS-ES//DTS: Neo
Power Supply Cool Master eXtreme Power 460W PSU
Software Vista Ultimate X64 Corporate Edition
Yesterday I cleared the cmos via jumper and to my surprise started to get an annoying error message at boot up stating "MAC address is invalid in both CMOS and flash". I can bypass the message by pressing F1 or F2 and continue into windows however my network card would appear to have low connectivity due to it not sending or receiving data. I found an application called "Technitium MAC Address Changer v5" and I've managed to generate a random MAC address which has allowed me to connect online however I still get the error as I attempt to boot up.
My motherboard is: ALiveNF7G-HD720p R5.0
MY problem is similar to these persons http://forums.pcper.com/showthread.php?t=456922
Edit 1:
Did you look here ?
I briefly read it but stopped once I realised the link for the Asrock MAC tool is broken:(. Although I've managed to find my original MAC address on the rear parallel port panel as the link says.
Edit 2:
I think this is a setting. It was on my dad old mobo and got enabled by default. I think it was MAC boot rom, or Lan boot rom or something.
I'm not at home right now so cant check. see if you have anything in your bios and see if it is enabled or not.
I've tried disabling the built-in LAN but I still get the error on boot up. I'm emailing Asrock now.
Kreij
Senior Monkey Moderator
13,817 (2.13/day)
Cheeseland (Wisconsin, USA)
Did you look here ?
alexp999
Staff
8,012 (1.27/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
