Motherboard for Ryzen 5 2400g
190 (0.05/day)
System Name Budget Gaming PC
Processor Ryzen 5 3600
Motherboard Gigabyte B450 Aorus Elite
Cooling ARCTIC Freezer 34 eSports DUO
Memory Corsair Vengeance 16GB DDR4 3200MHz CL16 ( 2 x 8GB )
Video Card(s) Gigabyte GTX 1060 6GB
Storage ADATA SX8200 PRO 256GB
Display(s) Acer V246HL
Case Zalman Z3 Plus
Power Supply Sirtec High Power Plus 500W
Software Windows 10 X64-Bit
Hi, i want to build a new pc with these 2 : Ryzen 5 2400g and GTX 1060 6gb
I don't know what mobo and ram to pick
28,419 (6.76/day)
That depends on what you want to do with it. Do you want to overclock at all? If so then a minimum of a B350 chipset mobo and 2667mhz DDR4 ram. You'll need a 550watt PSU to keep things stable.
190 (0.05/day)
Case Zalman Z3 Plus
2600 is not cheaper, i don't want to overclock it, i'll take a b350 chipset then
887 (0.22/day)
somewhere
Just make sure it comes certified for Ryzen 2000 / Raven Ridge otherwise you will have to flash the bios with an A series APU or 1st gen Ryzen. It might be safer to get a B450 which comes with Raven Ridge / 2000 support out of the box.
How much is the 2400G vs 2600? because if its only a bit more expensive it's definitely worth saving up for it, you get 2x the PCIE lanes and 50% more cores and 300% more L3 cache. It's a vastly better CPU.
584 (0.26/day)
Most (if not all) boards sold new today already have a bios supporting Gen 2 or the Raven Ridge chips with Vega graphics.
This is an issue only for people who bought their board in 2017 and haven't flashed since.
@op:
2400G is a First Generation Ryzen QUAD core (one CCX) that also contains a "Vega 11" graphics chip, which you won't be using at all because you have a GTX 1060 !
2600 is a Second Generation (higher clocks, better IMC) Ryzen HEXA-Core ( Two CCX'2s, one core disabled in each), without graphics. Also what ArbitraryAffection said, more cache and 2x PCI-e lanes.
The ONLY reason anyone would buy 2200G or 2400G is if they intend to make an "office-type" computer without a dedicated videocard (Like the one I just made for a friend who doesn't play games - see second picture)
In any case, I recommend B350 or B450 since they support more features (as well as overclocking just in case you change your mind)
As for memory, any of these two chips support at least DDR4-3000 (CL14 or CL16), which seems to be a price sweet-spot today (CL16 ones)
2600 can support even faster, up to DDR4-3600 (or even higher if lucky)
887 (0.22/day)
somewhere
about september last year I bought an Asrock Ab350M from Amazon which didn't come with 2nd gen bios. It must've been sitting there in a warehouse since 2017. Guess i was unlucky.
edit: derp, that was liek 6 months ago. Was still thinking it was like yesterday lol.
Also @op Some boards i have used and can recommend, i think the cheapest one i can really recommend is what I just said, the Asrock AB350M. it doesn't have video outputs but i have used this with a 2600X no issues even with mild OC. It's a solid board. Also there's the Asrock B450 pro4 and MSI b350M mortar. Can recommend any of these boards.
2,171 (0.76/day)
Tanagra
System Name Budget Box
Processor Xeon E5-2667v2
Motherboard ASUS P9X79 Pro
Cooling Some cheap tower cooler, I dunno
Memory 32GB 1866-DDR3 ECC
Video Card(s) XFX RX 5600XT
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Antec P7 Neo
From my own experience, 2400G will do fine driving games. It has no trouble boosting to 3.9ghz by default, same as the 2600. The extra cores of the 2600 would be nice if you can swing it, though.
584 (0.26/day)
I could as well recommend this mobo, simply because I just bought it and it works fine for the purpose I needed it:
- Supports all Ryzen CPU's out of the box.
- Micro ATX, fits in any case
- 6-phase VRM (but no heatsinks like premium boards)
- 4 memory slots (Tested with DDR4-3000 CL16, works first attempt)
- 6 SATA ports + 1 M.2 that works SATA or NVMe
- RGB header
Was less than 80 Euro (it's probably even cheaper in US)
1,200 (0.17/day)
System Name Desktop / Laptop
Processor AMD Ryzen R7 5600x / Intel i5-4200U
Motherboard ASUS TUF B550-Plus / Lenovo MB
Cooling Arctic Liquid Freezer II 280 / Stock
Memory Corsair Vengeance 2x16GB DDR 3800 / 8GB DDR3-1600MHz
Video Card(s) AMD Radeon 6900XT / Intel HD 4400
Storage 2.5TB SSDs + 4TB HDD / Samsung 850 EVO 500 GB
Display(s) 34" LG Ultrawide / 12.5 " 1080p IPS Touchscreen
Case Fractal Design R6 / Lenovo X240
Audio Device(s) Onboard / Onboard
Power Supply Enermax REVOLUTION87+ 1000W / Lenovo 40W
Mouse Razer Basilisk X
Keyboard Dell Business Multimedia Keyboard
Benchmark Scores Chicken Invaders 5 @125+ FPS
Do you have these components already or do you plan to buy them? what is the total budget you have? Where do you plan to buy the components? Answering these questions would allow people to give you better advise.
Generally as others have advised I would recommend going 2600 (or even 1600) instead of 2400G if you have a dedicated GPU. Also most of motherboards have automated overclocking function and with Ryzen is recommended. A decent b450 board on the budget is ASRock B450M Pro4. For ram you should go for DDR4 3000MHz in dual channel so 2x4GB or 2x8GB depending on your budget.
190 (0.05/day)
Case Zalman Z3 Plus
853 (0.33/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
Also why GTX 1060?? A RX 580 will cheaper and faster than a GTX 1060.
190 (0.05/day)
Case Zalman Z3 Plus
They kinda have same specs, it's not a big difference and i preffer the 1060
1,192 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
2,171 (0.76/day)
Tanagra
Storage WD NVME 1GB
Case Antec P7 Neo
I can second the B450 I AORUS PRO WIFI board. Has all the features you need and the AC wireless is great to have ready to go out of the box.
1,192 (0.28/day)
Processor 11700
Case Deepcool
Power Supply RM 850
And for Ram 2666 stick to know brands like G.skill, Crucial, Kingston.
527 (0.24/day)
I went for the R5 2400G which has adequate performance for gaming with one or two video cards
I have a Corsair AX860i so I have enough for 2 power pig cards
42,874 (6.70/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
Difference between 580 and 1060 is not that much, smarter is to get the one which is cheaper.
I checked newegg lowest price for rx580 8gb is 151usd and gtx1060 6gb 199usd.
Mobo recommendation B450 I AORUS PRO WIFI or TUF B450m pro gaming or B450M Steel Legend
92 (0.04/day)
Processor Ryzen 7 1700
Motherboard MSI x470 gaming plus
Cooling coolermaster AIO
Memory 16gb Gskill tridentz
Video Card(s) ASUS Strix Geforce RTX 2060
Storage Crucial NVME M.2 1 TB pcie SSD and 1TB Western Digital HDD.
Display(s) LG 34" superwide 2560x1080
Case Phanteks Evolv X
Audio Device(s) USB Audio Interface with Stereo Studio Monitors.
Power Supply EVGA 600watt 80 plus
Mouse gskill "ripjaw" LOL
Keyboard Piece of shit Lenovo Freebie - best keyboard ever.
Software Win 10.
I have the MSI x470 gaming plus, and while it isn't as feature rich as a lot of the other examples costing twice as much, it is solid, stable and has been super reliable.
Also has the black/red look which is easy to coordinate in a build if you care about that stuff. It's compatible with a wide variety of memory and supports all the current (and probably future) ryzen chips.
I think the only thing that is supposed to be not as good is the power delivery, but I was somehow able to still overclock my ram and processor with no issue at all.
It uses less phases. But it's really no detriment that I've seen.
It's only 140 bucks. It has pretty much everything that matters and nothing that doesnt.
I wasnt sure I would like it, but I do.
  • Screenshot_2019-03-04 MSI X470 GAMING PLUS AM4 AMD X470 SATA 6Gb #47;s USB 3 1 HDMI ATX AMD Mo...png
1,025 (0.33/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
I recommend B450 motherboard, be that MSI, Asrock, Asus or Gigabyte. B350 might be also a good solution, but it might be risky if the BIOS version is older; meaning you'll need a 1'st gen AM4 CPU to update to newer BIOS so that MOBO can recognize 2'nd gen AM4 CPU like Ryzen 5 2400/2600.
I also recommend RX590 GPU, because it's either in the same price range or just slightly more expensive than GTX 1060 6GB, but approx. 12-15% more powerful.
Considering RAM, I recommend DDR4-2400 or 2666 from ADATA, G.Skill, Team. Team Vulcan DDR4-2400, for instance, is excellent memory for Ryzens: https://www.teamgroupinc.com/en/product/vulcan-ddr4
190 (0.05/day)
Case Zalman Z3 Plus
4,516 (0.82/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
I only have these sites to buy : www.pcgarage.ro / www.evomag.ro / www.emag.ro ,
I choose the Ryzen5 2600, GTX 1060/RX 590
Are these ram any good ?: G.Skill Ripjaws V 16GB DDR4 2666MHz CL15 1.2v Dual Channel Kit
Which mobo is better ? : ASRock B450M Steel Legend vs ASUS TUF B450M-PRO GAMING
Edit : Someone can give me an advice or smthing about this build ?
Up
Ryzen dosen't like CL15. You have to look at the QVL for TUF or QVL for ASRock to make absolutly sure that the RAM will work with your board. Others will most likely work as well, but stay clear of CL15 RAM unless it is mentioned in the QVL.
Edit: If you use your own link you will find that B450 is not on the QVL for the RAM so stay clear of that set unless somebody here or other places have tested it for you.
190 (0.05/day)
Case Zalman Z3 Plus
Is this good then ? or else can u recommend something off this website : www.pcgarage.ro ?
4,516 (0.82/day)
Denmark
NOT = No good. You have to do your own leg work. I gave you the links so spend a little time to match what they sell online in Romania and what will fit the mother board you want.
190 (0.05/day)
Case Zalman Z3 Plus
Found these , they also on the QVL list for Asus tuf mobo, so, should i go for them ?
Should i buy this gpu ? it's really cheap.
