Motherboard & GPU blocks: Should I?
JrRacinFan
Served 5k and counting ...
20,125 (3.07/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
So here is a pic of my board and am looking into including it into my waterloop.
Should I? What blocks would I need? How would I cool the NF200?
For the 8800GTS 512MB; I usually run it at stock and it never reaches over 63C. Should I include it also?
The aspect of "if it isn't broke don't try to fix it" comes to mind. All advice considered and thanks in advance!
aCid888*
2,754 (0.45/day)
In a state of flux...
Why bother? The stock heatpipe layout and design looks fine to me, if anything, use a 40mm fan strapped to the Circupipe to cool the NB.
For the price of the blocks to cool the chipsets you could pick up another 512mb GTS and the gain would be far greater than water cooling your board.
Edit: Cooling the GPU(s) would be a good idea but I'd still get another GTS for now and crank out some more FPS in games.....cooling them can always happen later. :toast:
JrRacinFan
20,125 (3.07/day)
Youngstown, OH
Storage 20+ TB
Good point: Your thoughts about the video card?
1,143 (0.17/day)
New York
System Name AMD/ATI PHENOM MONSTER
Processor AMD Phenom II 965BE
Motherboard ASUS M4A785TD-V EVA
Cooling Air right know. Water later
Memory 4bg Corsair Dominator PC3 8500 9,9,9,24 2t timing
Video Card(s) Sapphire HD7950 Vapor-X
Storage 5x 500gb sata3.0 Seagate in RAID 0 - 2x 160gb Seagate for backup
Display(s) MAG INNOVISION 19in LCD 2ms 1600:1cr, 22in LED 2ms-5ms
Case Thermaltake Armor QuadFX edition
Power Supply 1000w Thermaltake toughpower
Software Windows 7 Ultimate 64bit
Benchmark Scores 3Dmark06 10712 single card and no oc, 12071 with cpu @ 2.8ghz and card oced, 13877 with crossfire.
Ya, I would leave the north and south bridge alone that heatsink is more than enough and if you do decide to cool them remember that your adding more connections which could cause more leaks and problems and the fact that you could take that extra money and buy something else. You could take the extra cash and use it to cool your gpu would be more worth it.
Edit: Also like acid said you could get another gpu!!
JrRacinFan
20,125 (3.07/day)
Youngstown, OH
Storage 20+ TB
I do have an 80MM fan blowing acrossed the northbridge currently. Temps usually stay mid 40's low 50's. So going SLI do that before getting GPU blocks.
Good idea guys! Thanks much!
