Motherboard Standoffs/Risers Help!?
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
Processor AMD Athlon II X4 640
Motherboard MSI 870 G45
Cooling Cooler Master Hyper 212+, Terminator 3 80mm LED, and 120mm Front LED
Memory Kingston HyperX Genesis 4gb DDR3-1600
Video Card(s) Zotac 1Gb GTS 250
Storage Seagate Barracuda SATA2 7200RPM 500gb
Display(s) LG Flatron 19" LCD
Case Aerocool Jetmaster Jr.
Power Supply OCZ ModXStream Pro 500W
Software Win 7 Ultimate 64 bit
Hey, sorry to bug you just I'm having an assembly issue right now, and idk who else to turn to but the geniuses of TPU :respect: So here's the thing, I have an AeroCool Jetmaster Jr. Case. and as you can see from the pictures below there are bumps in it.
These bumps are where the risers for an ATX mobo go. However, if I place risers on top of the bumps, My mobo (MSI 870-G45) doesn't line up with the I/O panel. :/. The case does come with risers, so I suppose I'm suppose to use em? but idk how. If i leave the risers out, my mobo lines up perfectly... what to do?
5,787 (0.95/day)
Switzerland, Heart of Europe
System Name Fractality 1.0
Processor Intel Core i7-860 @ 3.6GHz
Motherboard EVGA P55 SLI
Cooling Prolimatech Megahalems and four Fractal Design 120mm fans, sleeved
Memory 16GB Kingston Hyper RAM
Video Card(s) PNY GeForce 580 XLR8
Storage 64GB and 180GB SSDs / 1TB and 2TB HDDs
Display(s) 24" Acer V243W
Case Fractal Design Define R2, sleeved all I/O cables
Power Supply Corsair HX750W modular, sadly only stock sleeving
Software Win 7 64bit
Bleh, bumps. Yeah you don't need risers on them. However you should put risers in the holes where no bump is, but theres a hole in the motherboard for it.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
I thought not putting risers in hurt your case? and all the holes on the board are covered with the bumps? so I dont need any risers?
5,787 (0.95/day)
No you don't, the bumps are substitutes for the risers, so to say. I guess cheaper than to include a handful of screws. The tips of the bumps only touch the immediate surroundings of the holes in the mobo, so do the risers. There are no circuit lanes that could be damaged.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
you only apply thermal paste to either cpu or heatsink, right? not both? And if you do both is it harmful?
5,787 (0.95/day)
Can't you nag someone else but me :D /joking
Well it can turn harmful if you use way too much thermal paste (often referred to as TIM).
See TIM acts as a thin layer between CPU and heatsink that levels out tiny scratches on both surfaces, so the contact area and thus the heat transfer is as good as possible. Thats why you shouldn't apply too much TIM.
Now, there are plenty of techniques to apply it. Some TIM comes in tubes, some in syringes, some in small bottles. Some have a dispenser; a brush mostly or a grater. With that you can distribute the TIM evenly. Where? Best on the CPU.
There's also a common practice, mostly if you haven't any tools at hand, to just place a grain sized blob of TIM on the CPU. Then take your heatsink, place it on the CPU, twist and turn it for a bit, then check if the TIM has evenly spread. Then seat the heatsink.
By the way the opinions on how much TIM you should apply differs greatly, I've heard everything from a tiny bit to a pea sized blob.
You can also take a piece of paper to distribute the TIM.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
you're actually the greatest existing person in the world :D hahah
5,787 (0.95/day)
I just happen to be around and in the mood when you pose your questions lol. There are far greater guys on this forum. I have learned from them as you learn from me.
Its the ciiiiiiircle of life :D
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
so i left a really think layer on both processor and heatsink, i didn't wanna take the chance of trying to clean it, seeing as i didnt have any concentrated isoproypl alcohol nearby. In a PSU (OCZ ModXStream) is the top fan suppose to be faceing up or down?
95Viper
Super Moderator
13,158 (2.20/day)
Depends...
Either is fine, as long as your case ventilation is adequate.
Fan down will bring in fresh air from bottom(outside the case) and exhaust out back.
It will, also, draw in dust and stuff (if you have it in a dusty area).
Fan up will help draw air from inside the case to the outside.
However, you will be passing the case air through the PSU, whose temperature could be warm (again, depending on the ventilation in the case).
I have done both, and, found neither to be detrimental to the psu.
Just do house keeping when needed.:)
Edit:
After looking at that case(it is top mount psu); you will have to install with the fan down.
As, I do not see any ventilation at the top.
de.das.dude
Pro Indian Modder
9,176 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
drill a hole in the bumps and use as screw holes??
the risers are for any mobo which has a few non standardised screw holes.
i use risers too. only one though. beside the DIMM slots.
2,597 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
"A really thick layer' of TIM is usually not the best. It will probably work, just not as efficiently as possible.
There are many guides for applying TIM, just Google it.
Personally, I use the 'grain of rice size' method.
90% isopropyl alcohol is a must for cleaning. I also recommend using a paper coffee filter in lieu of Q-tips or paper towels, etc.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
Edit:
If i stall it with the fan up it fits in perfectly and screws match up nicely however with it downwards, only two screws fit, so I'm worried about safety. (Yes I have pushed it in every possible way to try to make it fit, it doesnt) Like the PSU will hold up with only two screw just it seems sketchy.
lol that was suppose to be thin :p But it's really thin on both processor and heatsink, I just didnt know whether if applying on both was harmful or not
Also when install my CoolerMaster Hyper 212+ the how tightly should I screw the bracket the holds the heatsink on? I've heard that if you screw anything into the motherboard tightly it can damage it. Of course I am screw all the screws in evenly little by little. I just don't knw how tight to make it.
5,787 (0.95/day)
The PSU will do fine. The case has support bars; it won't fall down. Two or even just one screw is thus enough.
1. The bumps do have holes. As I stated earlier, they are a cheap substitute for risers.
2. Non-standardized screw holes? The holes on any ITX, mini ATX, ATX and eATX are at the same damn place. Not any case has bumps. In fact, very few do have them.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
Yah It's an old case, I have risers, I wish i didnt have to use th bumps, but oh well
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
Another question, when I'm wiring the power buttons to the motherboard I don't know which is positive or negative. If i do wire it all and try to start it up, will it harm my motherboard if I have it backwards? Do you know of any way to figure out which are positive or negative?
913 (0.16/day)
nebraska
System Name TheBruise
Processor i7-960
Motherboard Gigabyte x58A -Ud5
Cooling Vantage ALC push pull/2x180mm fans/1x120mm silverstone
Memory 12GB Corsair Vengeance 1600Mhz
Video Card(s) 2 Sapphire Vapor-X 5870's in Xfire
Storage Ocz Vertex 3 Max Iops (OS) 300GB Velociraptor, 750 GB WD Black
Display(s) Asus 23" VS238H-P
Case Silverstone Ft01-BW Fortress
Audio Device(s) Creative X-fi Titanium
Power Supply Corsair HX-850
Software W7pro SP1
Blue or red is usually positive and white or black is usually negative. If your talking about the mobo, you should be able to find a diagram online thatll tell ya,or in the manual.
Personally i dont know if it will do harm. My gess is it just wont start, but i would just go the extra mile to make sure they are correct.
2,406 (0.43/day)
London, UK
System Name Slick
Processor Intel i5 2467M
Motherboard Samsung Series 5 Ultrabook
Memory 8GB Corsair Value
Storage Crucial M4 7mm 256GB
Display(s) 13"
Software Windows 8 Pro x64
Those bumps remind me of a thermaltake V3 case I built for friend recently. The motherboard just rests on the bumps and you screw directly onto the hole at the top of them.
I would suggest putting some tape over the bumps before resting the motherboard on it though. In my experience they are too close to some motherboard solderings sometimes and last thing you'd want is to short anything.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
Would some kind of electrical right around the threading be good for that?
2,406 (0.43/day)
London, UK
System Name Slick
Display(s) 13"
Yeah that's what i used. Just pierce a hole through the tape though so that you know when you've lined up the hole with the motherboard and so the sticky stuff doesn't clog up the screw thread.
saadzaman126
415 (0.07/day)
Ontario, Canada
System Name Cyclone
I see, cause if I dont tho this part of the metal from the risers can touch the mobo. kk gotcha
