Motherboard VRM cooling
142 (0.15/day)
Ballkans
My friend has been having a lot of issues with his MB VRMs overheating!
The motherboard that he picked was the cheapest AM5 one on PCPartPicker:
Gigabyte A620M S2H Micro ATX AM5 Motherboard​
The cpu that he bundled it with is Ryzen 5 7600X.
I suggested him to add some heatsinks to aid in cooling however I talked him out of using heatsink plaster as that stuff doesn't conduct heat that well and is pretty permanent! So are there any good thermal pads that are self adhesive or semi adhesive [either that or zipties :V]?
I don't know much about thermal pads because I haven't really used them that much.
41,510 (6.58/day)
AS5 thermal expoxy mixed with AS5 worked on bga ram on my MR9800 back in 2006 with tweak monster ramsinks. The mix made a semi permenant bond like certain grades of lock tite (a little force broke the bond so I could remove the heatsinks if ever needed
1,355 (0.85/day)
From my own experience the best solution is that he would have CPU heatsink/fan that blows directly at motherboard (and with that at VRM's) and not past it as so many coolers nowdays do ("tower" coolers).
41,510 (6.58/day)
If anything Id sell the board and get something better
71 (0.11/day)
System Name Hopes, dreams, donated parts, and electrical tape
Processor Ryzen R5 3600
Motherboard Asrock B450m Pro4
Cooling Stock Cooler
Memory Corsair Vengeance LPX 32gb 3200 CL16
Video Card(s) PowerColor Fighter 6500XT (Running at pcie 2.0...)
Storage Western Digital 2TB Black HDD, Samsung 870 Evo 512GB
Display(s) Asus VA something or other
Case Cougar MX331 MESH-X
Power Supply Corsair CX550m
Mouse Rosewill ION D10
Keyboard Corsair K70 (The old one)
VR HMD $4 Garage Sale Phone Holder and AprilTags
What does he use the 7600x for? If it's just for gaming reasons then he might want to first try setting it to 65w eco mode in the BIOS. You're not gonna lose any gaming performance and it'll set the power limit to 88w (because 65w eco mode means 88w...for some reason) which absolutely shouldn't cause any VRM overheating on that board.
Moreover, I'd be curious as to how he figured out it was the VRMs overheating versus something else. The S2H's VRMs aren't too bad so it surprises me that he would be getting throttled like that unless he was really pushing that 7600x to its limits in an all-core workload or something.
4,994 (3.86/day)
Colorado, U.S.A.
Software Windows 11 Home
Isn't that an issue with water cooling? any air that might have have got to the VRMs is no longer present (with the CPU fan gone).
Most CPU fans blow down on the heatsink, so the VRMs get warm air (better than none at all); but what if one turned the fan around so it now pulled air?
tabascosauz
8,034 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
I'd like to know what your definition of "aren't too bad" is. It's Gigabyte's favourite unheatsinked 4C06N setup with only 5 undoubled phases. That's comparable or worse current handling than 3 doubled lo-side found on absolute bottom of the barrel AM4 boards. It literally doesn't get any worse.
Since like 5 years ago it's common knowledge that even 65W (88W PPT) CPUs are a struggle for doubled 3-phase Vcore. 7600X is a 105W (142W) CPU.
First step is to get a spare small diameter fan (e.g. 80mm) and either lay it on the VRM directly or stand it up on the back of the GPU pointing at the VRM and just blast it with airflow. Also you've not said anything about the rest of the system, improving system airflow (especially rear and top exhaust in a conventional layout) also helps.
If it's still a problem, you can look for those tiny stick-on heatsinks for individual mosfets like this, and combine it with said airflow:
And find Eco Mode in BIOS to drop it down to 65W TDP (either 76W or 88W PPT, not sure which it will be for S2H). It's a 6-core, no reason to be running that much power day-to-day, especially given how aggressive Zen 4 is with any extra power headroom. 7600X is one of those SKUs that should not exist; turning it into a 7600 through Eco Mode will be easier to handle all around.
71 (0.11/day)
Didn't know this, thanks for the info.
Outback Bronze
2,001 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 32GB Hynix
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Gigabyte 34" Curved
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
This is why you generally need good air flow through the case, it has an all-round effect.
2,696 (4.57/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
heatsink plaster
It's generally a good solution, why not. Just make sure you don't overdo it. Apply just enough for it to stick, no more. The thinner the layer the merrier.
Any airflow directed to these heatsinks will be much appreciated as well.
As mentioned above, restricting CPU from triple figure numbers in wattage is a must here.
351 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
O, you could do what I did if you had water cooling =
freeagent
8,234 (3.72/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I would crazy glue a stack of like five pennies together and then glue them to the VRM. If you are gonna beat on it with a bigger CPU might as well give it a chance :cool:
41,510 (6.58/day)
Heck use AS Epoxy between the pennies and the AS Epoxy mixed with AS5 between the penny and ic lol
3,739 (0.58/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
One of the reasons I prefer 'downthrust' cooling like stock. Not absolute best for CPU, but helps vrms.
11,715 (5.60/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
I'm in the camp that recommends lowering the power target. That motherboard already has a heatsink, so it won't do any better with another one, either.
As a rule of thumb, it is not recommended to pair an X-suffix CPU with a budget A620 motherboard because they're equipped with terrible VRMs and can't supply enough power without running into thermal issues.
2,696 (4.57/day)
Russian Wild West
Wish my top-flow bad boy had a more massive heatsink. 85 W CPUs is its best. And no, additional airflow doesn't help, heatsink is the issue.
41,510 (6.58/day)
Need to be a 650 or 670 series
11,715 (5.60/day)
Midlands, UK
250 (0.30/day)
USA
Processor i9-11900K
Memory 4x8GB DDR4
Display(s) LG 27GN950-B
Power Supply Corsair RM1000x
Keyboard HyperX Alloy Elite 2
I did exactly that with an old raspberry pi. It works pretty well until it can't soak up any more heat. :laugh:
142 (0.15/day)
Ballkans
Well aparently he touched them and it left a burn mark on two of his fingers, I had told him to use a down blowing cooler but instead he got the Arctic A35x co :/
11,715 (5.60/day)
Midlands, UK
He will definitely have to get his power limits decreased. A 65 W TDP (88 W PPT) should do the trick.
142 (0.15/day)
Ballkans
I tried to talk him into doing it but he said "I'm not slowing down my system" I think I will try to glue some heatsinks on top of the VRMs :( it's a bad board after all.
Should I be looking for a good specific thermal adhesive brand or is the cheap heatsink plaster well enaugh?
3,106 (1.64/day)
Memory Micron DDR4-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1
Power Supply Corsair RM750x
Mouse Logitech M575
Maybe if you show him the pic of my fried motherboard he might reconsider. Having great VRM cooling on a MB that heats up because can't supply the requested power might be catastrophic.
11,715 (5.60/day)
Midlands, UK
Oh my... :( A truly facepalm moment. If only he knew how little performance he has to give up!
I'm currently running my 7800X3D with boost turned off (4.2 GHz constant) because I have to do something with my cooler mount (either repaste, or just remount properly), and I'm losing only about 12-15% scores in Cinebench. By doing a 65 W TDP limit on a 7600X, your friend would lose only a fraction of this. He would basically get a 7600 non-X.
Try showing him this:
3,106 (1.64/day)
Mouse Logitech M575
I like those too, and they way you wrote it makes it sound like a very manly PC cooler - very performance oriented. :laugh:
Well it would be interesting to put a temp probe on it. Maybe it isn't a big deal if its actually under 80c especially with some heatsinks and a bit of airflow on it.
Do you remember the mix ratio?
